I need schematics for the SCR-3000 AM/FM Cassette Receiver. Model number 31-1996. Trade name: Realistic.It doesn't turn on and I'm trying to figure out what's the problem.
2 Suggested Answers
SOURCE:
dunnbiker
  • 8546 Answers
SOURCE: Need to hook up a
Be advised that the engagement of any device in a Tape Monitor loop on a late-model Audio/Video Receiver will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
The connections themselves are fairly simple but it pays to understand what happens in the loop.
In general, any Line-Level external processor (EQ, dynamic range expander, etc) will go into a Tape Monitor loop on a receiver. A Tape Monitor, when engaged, sends the stereo analog signal Out to the Processor, massages it and returns it to the receiver via the Tape Monitor IN connectors to be passed on to the receiver's internal processes (volume, tone, whatever).
Old school analog stereo-only receivers consistently work this way. Newer digital and audio/video receivers introduce a couple of problems: 1) digital sound processing to simulate a variety of soundfields; 2) multiple output channels, either discrete or digitally-generated.
The latter requires that whatever signal is being processed experiences a maximum of one analog-digital-analog conversion.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose a STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Monitor as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? They would NOT be processed. That logical problem also plays into the decision to defeat digital sources if the Tape Monitor is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Okay, back to the hook-up: Receiver Tape- or VCR Out to the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-In; Receiver Tape- or VCR In from the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-Out.
So, to sum up, you can only use the EQ for analog stereo sources. If you actually want to use an analog recording deck you could place it within the typical Equalizer's own Tape Monitor loop(s). Many have two to facilitate equalized dubbing between decks.
[Or you could obtain a dbx Program Route Selector (check eBay, I highly recommend the 400x, of which I have two) and it would, while only using one receiver Tape Loop, allow for three discrete attachment paths for processors and three for tape decks with the added flexibility of front-panel selection of any and all, with the processors being before, after or between the source or tape decks. Plus it has a dedicated facility for an inline dbx Noise Reduction Processor that can also be juggled around via pushbuttons. Pretty neat.]
Posted on Jan 18, 2011
Can't figure out how to change the time on the Fujitsu Ten am/fm cassette player in a 90-something model Toyota Camry. Please help!!!
You hold down mode button for 3 seconds then use selector knob to select time ,then adjust time to suit
If you need to turn demo mode off hold down mode button for 3 seconds ,select demo then turn knob to off
Feb 15, 2013 | Car Audio & Video
I have an old zenith is4070. I am trying to figure out how many watts it pushes out to my speakers.
Model # IS 4070
AM/FM Stereo Receiver
With Phonograph and Cassette Play/Record
Serial # W288209
Power Source AC 120 V 60 Hz
78 Watts 0.65 Amps
Unswitched
AC 120V 60 Hz
200 W Max
Jul 09, 2011 | Zenith Audio Players & Recorders
Trying to find realistic sta 2000d receiver owners manual
Try going to Realistic.com They usually have schematics and manuals.
May 09, 2011 | Audio Players & Recorders
I have an Amana microwave Model RRL-10C. The magnetron modulation SCR has delaminated from the foot mount and shorted in the closed position due to thermal failure(thank goodness the nuke still works but...
I wouldn't suggest trying to modify the triac control circuit.
Without a schematic I couldn't begin to advise you on how to do that or to value or the parts that might be bad.
And I truly doubt that the schematic can be found.
I would kind of expect the opto to be bad, and maybe a resistor or two.
They would need to be replaced with the right values and an acceptable opto.
You may get lucky and find that the opto and resistors are all okay.
You can find the triac here. Looks like the GLC16-50 or GLC16-50S would work for you.
That's about all the help anyone can provide you, honestly.
Good luck and be careful!
Jan 18, 2009 | Microwave Ovens
KENWOOD KRC-2007 CAR AUDIO CASSETTE RECEIVER
It seems the problem is the fm tuner pack.
You can get it from pacparts.com
Part number is W02-1576-08
Jan 17, 2008 | Kenwood KRC-2007 Cassette Player
97 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
