Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Will not cool, tempature remains at 77 degrees in the refridgerator and 78 in the freezer
  • Maytag Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 25, 2010
SOURCE:
Freezer works refridgerator only cools to 52 degrees
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 02, 2011 | Magic Chef Refrigerators
Refridgerator will not go below 50 degrees
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Jan 07, 2011 | Kitchen Ranges
Freezer works fine. Refridgerator wont get below 60 degrees.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 08, 2010 | LG 26.0 Cu. Ft. Side-by-Side Refrigerator...
Will not cool
First, make sure the thermostat is turned down low enough to call. Listen and see if the compressor is running. In rare circumstances the equipment can develop a refrigerant leak any where along the way from the factory to your home. A warranty call may be in order.
May 01, 2010 | Samsung 25.8 Cu. Ft. Side-By-Side...
Can not get temp below 77
Is the thermostat set up for automatic change over from heat to cool? If so, the heat is probably set for 75, you will need to lower the heat setting in order to Lower the cooling. the stat won't let these settings with in 2 degrees of each other so the heating and cooling don't fight each other.
Aug 25, 2009 | Heating & Cooling
Not cooling as well as should be
THe low side should be 34 degrees f. Which is about 65psi.
May 09, 2009 | Heating & Cooling
Cooling Problems
Your filter is clogged. Not the one at the bottom of the unit.The one above the unit. It is like a raditor coils, kind of a bear to get to. We have cats and dogs the filter gets most of the hair but not all.Usualy about 6 bolts to take out.The proublem will be at the bottom of the top filter.
May 09, 2008 | Honeywell Electronic Programmable...
Tempature on fridge won't stay @ 38
might be freezing on the evaporator faulty defrost timer or drain is blocked water should run down back bottom tray
May 10, 2007 | Samsung RS2630SH Side by Side Refrigerator
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
