Question about Ovens
I have a Franke wall oven. I am guessing someone has tried to force the timer to the off position but it just stays where it is set to.
  • morley474 Oct 25, 2010
    I want a timer that works and need to know if there is a way of resetting it or is it broken and needs replacing?
  • 2,299 Answers
Are you wanting to replace the timer?
Posted on Oct 25, 2010
  • Rodney Clark
    Rodney Clark Oct 25, 2010
    I would not know if it is broken without looking at it. If it is stuck then I would say it is. But really can't tell without seeing it to troubleshoot. Do you still have the manuals that came with the oven? If so, call the customer service and they will direct you where to get the replacement. If not, call your local appliance repair in the yellow pages to get the timer. It can be replaced. So call someone local and you can just go pick up the part.
SOURCE:
What are the dimensions of a chef baroness integra gas wall oven
You need the Chef Model number, then click on the model and then on 'More'.
chef integra baroness wall oven 92 60 chef Compare Cheap chef integra...
Chef EXC627W Wall Oven
Compare prices $849.00 Chef EXC627W 60cm electric fan forced wall oven with separate grill and 60 minute timer in white Separate grill 60 minute timer Easy clean formed shelf supports Cooler door temperatures with air cooled door Wall installation Cooling fan Oven size (cm): 60 Oven - internal dimensions (h x w x d) (mm): 376 x 475 x 432 Separate grill - internal dimensions (h x w x d) (mm): 216 x 475 x 432
Specifications Style of Oven
Separate grill/wall
Oven Type Electric
Width 888 mm
Depth 595 mm
Height 573 mm
Or contact them direct
Welcome to Chef
https://www.chefappliances.com.au/Explore Chef's range of products! ... The simple touches that make Chef functional and easy. Fingerprint. Anti-fingerprint. A special stainless steel finish means our ovens stay free of messy prints. Cooktop options. Gas, electric solid or ceramic. image 1. Boils faster than gas? Easy. The Induction cooktop provides modern, ...
Apr 08, 2018 | Ovens
(90s) Jenn-air single wall oven locked
The timer may think it is still in clean. The easiest way to try and fix this is to set another clean cycle and let it run all the way. Set it for the least amount of time that it will let you for example try a 15 minute clean cycle. Once it goes through it and turns off automatically it may release the lock, if not you will most likely need someone from service out.
I hope this helps
May 13, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
I have a 40 year old Tappan electric wall oven. It has an analog clock with 3 timers on it (2 small timer...stop and start and a large timer with 3 hands on it). Which position do the timers need to be for...
I have one of these too. the TOP small clock should be set to the time you want the oven to start and the BOTTOM small clock should be set to the time you want it to turn off. Be sure to set the oven settings to what you want and the correct temperature.
Try testing it first just to see if it works correctly. It's also important to make sure the other large clock on the oven is set correctly.
May 01, 2010 | Ovens
How to operate a franke electric oven
hi i just need to know how to operate the oven for general purposes such as baking. I need to know which symbol stands for what. thanks
Feb 07, 2010 | Ovens
MY 24 INCH BUILT IN SINGLE WALL OVEN DIGITAL TIMER
turn power off at main box the back on retry st set clock . if it won;t set / replace it . it has gone bad .mm
Dec 09, 2009 | Maytag 24" Built-In Single Electric Wall...
My oven stays on, only way to shut off it to shut breaker
Do you mean it continues to heat, or the indicator "says" it's on ? These wall ovens have notorious problems with the erc (clock/timer) could be a relay stuck in the closed position. trip the breaker, pull out the erc and visually inspect it, or if you're really inclined check to see if the relay "cycles" (clicking on & off/open & closed) through out operating.
Sep 26, 2009 | GE Profile JTP18 Electric Single Oven
Oven-part of Franke Stove not working.
I have a Franke gas stove top and under one burner knob the spring is broken. Model #AD 72 M WQ
Jul 10, 2009 | Ovens
Chef classic wall oven with digital clock change time?
Press the TIMER button (the leftmost one with a little bell icon) and the "cooking" button (the one next to it with a "hot saucepan" icon) briefly at the same time. Within four seconds start changing the time with the + or - buttons. When you have the correct time just leave it and it will leave time setting mode four seconds after the last button press.
Apr 12, 2009 | Ovens
Old Gaffers& Sattler oven won't heat up. I suspect timer setting?
The most common failure in any electric oven is the heating element.
Jun 20, 2017 | Ariston Technologies Ariston FO98P...
Westinghouse 745 wall oven
First thing, remove the plug from the wall power for at least 10 minutes, maybe even thirty minutes and allow it to reset........ if that does not work write me at [email protected] and give more model info so I can investigate for you or check out a volunteer site, allexperts.com and you will find me there also.
Nov 10, 2008 | Ovens
Ovens Logo
50 people viewed this question
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
