Question about PfaFF Sewing Machines
How do i oil my pfaff 2027 - PfaFF Sewing Machines
I have not used my machine PFAF 875 hobbymatic in over 10 years. It has been in storage. No repairmen around my area. How can I ensure that it is ready to sew? It is running but it is slow
Hello, Angie -
First, give your sewinig machine a thorough cleaning and oiling (light touch of oil in the hook raceway, only), following instructions in your PFAF 875 Hobbymatic user's manual.
If you do not have the manual, you can find it here to download:
http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/Pfaff_874_875_876_HobbyMATIC_Extra-manual-EN-DE-FR-IT.PDF
If the machine still seems to run slowly, then I suggest you look for a nearby business which sells Pfaff machines and ask where you can have your machine serviced.
If there is no business in your area which sells Pfaff machines, perhaps you can find a generic sewing machine repair business near you.
If you have not contacted the Pfaff company regarding service for your machine, this is the link to the Pfaff Machine Support page:
http://www.pfaff.com/Support-and-Updates/Support
Best wishes.
Jan 23, 2018 | Sewing Machines
How to replace power foot pedal cord pfaff 2027 sewing machine
under the anti-slip strip there are screws to be eased off and the pivoting shaft can be pushed out. The difficult task is to re-assemble - the contact wiper is springy and is hard to keep away from the small resistor strip when closing the top. Not recommended for DIY.
Oct 27, 2015 | PfaFF Sewing Machines
Hobbymatic 927. How do I clean and oil?
Pfaff - Machine Support
help is here. Whether you've simply misplaced your manual or you require a more creative solution, you're in the right spot.
Sep 08, 2015 | PfaFF Sewing Machines
Buttonhole feature
try changing the needle
make sure the button hole lever is pulled down, it should be on the left
hand side of the needle, if your machine has one
it's also possible that the machine needs to be checked to see if
there is something wrong with a gear or just needs some type of
adjust inside of the machine
Sep 04, 2012 | PfaFF Sewing Machines
My Pfaff Classic Style Quilt 2027 is getting large thread snarls on the underside of the fabric.
Top tension problems. Tighten the tension.. and make sure you hold the threads when starting a seam.
Sep 02, 2012 | PfaFF Sewing Machines
How do i take the side panal off of my pfaff 1472 so i can clean it.
you might contact pfaff & ask them if you can oil your machine or does a sewing machine service technican have to do it
May 21, 2012 | PfaFF Sewing Machines
Can i oil; my own sewing machine..quilt expressions 2048 pfaff
you will have to contact pfaff customer service about the oiling of the machine, cause from what I've learned, some machines have to oiled by a repair technican.
May 16, 2012 | PfaFF Sewing Machines
ClassicStyle Quilt 1527 PFAFF Sewing Machine Oiling?
contact Pfaff customer service about the oiling
Mar 04, 2012 | Sewing Machines
Where do you oil the PFAFF Synchrotronic 1229?
1229 or majority of PFAFF's needs to be oiled in the bobbin cage and nowhere else.If you start oling the gears lint will build up and slow your machine down. So only apply a few drops where where the bobbin is attached to.
Feb 10, 2010 | PfaFF Sewing Machines
Sewing Machines Logo
116 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
MissFixIt828
Level 1 Expert
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
