Question about LG LMV1630ST Microwave Oven
Lg lmv1630st microwave died suddenly, no lights or anything. Is there a reset button?
6ya staff
SOURCE:
MicrowaveSvc
William Miller
  • 9174 Answers
SOURCE: My microwave over my stove
We have the service manual for this model and have uploaded it to our site here to help you.
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
Ifthe fuse is good, it may be an open thermostat or thermal cutout (TCO)/ thermal fuse on or near the magnetron or on top of the cavity / bodyof the oven.
If it goes dead for a while during or after cookingthen comes back on, the magnetron is probably overheating and causingthe magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
Whenchecking thermostats, if it has a hood fan thermostat, that should readopen, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
Ifit goes dead or blows the breaker (or GFI) when you plug it in or open or closethe door, then there's a problem with a door switch or door switchmount.
If it's intermittent or random, it may be a badconnection, usually on the control board or a loose fuse holder, oreven an intermittent fuse.
You should do a continuity test onthe fuse while it's in the holder (with the microwave unplugged, ofcourse) then turn the fuse by hand or take it out and put it back in,then test it again.
If you remove the fuse, then press the meterleads against the ends, it can allow internal contact to be made andmake a bad fuse appear to be good.
ForGoldstar / LG / L.G. parts, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat8-5 CT) and choose the appropriate prompt from the menu or visit here.
We're happy to help you and we'd appreciate yourthoughtful rating of our answer.
Posted on Jul 19, 2008
MicrowaveSvc
William Miller
  • 9174 Answers
SOURCE: lg LMV1630st stainless steel microwave oven
I'm confused. If it's 6 weeks old, you can get it repaired free.
If it's 1-1/2 years old, the manufacturer will cover the part cost of the magnetron (assuming that's what's wrong) and you will have to pay for labor and any other needed parts.
Also, the subject line mentions a model LMV1630ST while your message body mentions model LMV1680BB.
For Goldstar / LG / customer service, help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Chances are your problem is a bad magnetron, but it may be another high voltage part.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
Anonymous
Make sure the door is aligned and closes safety switches.
Posted on Aug 26, 2008
Anonymous
  • 242 Answers
SOURCE: 14 month old LG Microwave. The control panel is
Very common , You need to replace the switch membrain , this is the entire touch pad , they are not to much $ , and you should find it easy online.
Phil
Posted on Apr 10, 2009
dmftrucker
daniel hendrickson
  • 1922 Answers
SOURCE: My LG microwave went completely dead. I is only 3
under the outer cover,its either a 10-15-or 20 amp ceramic safety fuse avail at most hardware stores, the amp rating is on the side of the fuse, if the new one blows then either the H.V. diode/capacitor or the magnetron can be suspects
Posted on Oct 05, 2009
Is there an internal reset button?
The short may have blown an internal fuse.
Jan 20, 2015 | LG LMV1630ST Microwave Oven
How do I reset the lg microwave. It's asking reset date but my touch screen
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Jan 07, 2015 | LG LMV1630ST Microwave Oven
Lg microwave over the stove will not heat up the food
Magnetron, the diode most use, or the large ac filter cap are all possible.
most people cannot test or even in some cases get at those
Dec 23, 2012 | LG LMV1630ST Microwave Oven
Some panel buttons are not working on my LG LMV1630ST
The problem is in the keypad control board and must be replaced, I would consider cost before you allow the go ahead.
Apr 05, 2012 | LG LMV1630ST Microwave Oven
LG LMV1630ST over the counter microwave has fan that will not shut off
Unfortunately, about the only thing you can do is to replace the switch. We don't service microwaves that often so I am not to sure of where the switch is located on your unit. So here is the layout for your unit, and you can find the correct switch on the diagram and then look it up on the right side.
http://www.searspartsdirect.com/partsdirect/part-model/LG-Parts/Microwave-Parts/Model-LMV1630ST/3204/0123370/Z1006010/00004
Jun 24, 2011 | LG LMV1630ST Microwave Oven
Turntable won't turn
Look at the front panel, at the bottom, in the middle.
Identify the button labeled "Turntable On/Off".
Push it.
Slap yourself on the forehead.
Next time you fumble to turn of the light in the dark, push the right button.
Dec 05, 2009 | LG LMV1630ST Microwave Oven
How do I replace a LG LMV1630ST microwave oven door handle?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Nov 23, 2009 | LG LMV1630ST Microwave Oven
My LG LMV1630ST has an issue with the clock. The
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Is it a US model (made for 60HZ power) being used overseas
(50HZ power)?
* * * * * NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for more FREE help & do-it-yourself advice.
William E. Miller
[email protected]
http://www.microwavedisplay.com
Sep 07, 2009 | LG LMV1630ST Microwave Oven
LMV1630st sparked and then stopped working.
http://www.fixya.com/support/t886241-power_turns_off
please use this link to view another servicemans explanaton of what your problem is and hopw to address. In essence, you should ALWAYs press the stop button before opening the door... Hope this helps you...
Sep 01, 2008 | LG LMV1630ST Microwave Oven
Lg LMV1630st stainless steel microwave oven
May 02, 2008 | LG LMV1630ST Microwave Oven
LG LMV1630ST Microwave Oven Logo
90 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
