Question about Kenmore 96422 / 96424 / 96429 Electric Kitchen Range
I have a Kenmore range, model 665.95775890, it's atleast 10 years old and the bottom element doesn't seem to get hot. We bake a pizza and the top is done and the crust is not. I changed elements and no change at all. Is there a thermostat or something else that is bad? The top element works very well. I called Sears tech and spent 45 minutes and they couldn't really tell me anything!! I was real disappointed in them.
5 Suggested Answers
SOURCE:
milten1
  • 1304 Answers
SOURCE: I have a Kenmore electric
sounds moree likely that you lost one side of your power
check your voltage at the outlet
l1 to ground 120
l2 to ground 120
l1 to l2 220
Posted on Oct 05, 2009
SOURCE: The bottom element in my Kenmore oven just got red
Yes. Unplug the range, remove the screws, holding the element, remove element, disconnect wires on the ends of the element. Installation is the same in reverse. Complete model number is needed for the part# of the element
Posted on Mar 04, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore range oven model 880, broil element stays on
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 23, 2010
  • 24 Answers
SOURCE: have a kenmore electric range.
Before you got through the major expense of replacing the board. try replacing the thermocouple. sometimes the simple selution is the best solution.
Posted on May 10, 2011
My Kennmore 790.95312300 will not heat up on Bake
If the element tests good, the clock / control is most likely the problem and will need replacing.
Oct 20, 2017 | Kenmore Kitchen Ranges
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Mar 04, 2010 | Kenmore 96422 / 96424 / 96429 Electric...
KitchenAid Oven Temp.- Bottomside of Pizza or Cake stays uncooked
I have a 2yo Kitchenaid oven, and my advice is first, don't use convection for cakes or pizza. Use the thermal oven. For pizza preheat to 500 degrees, then put the pizza on the lowest rack, and bake for 7-8 minutes.This way the bottom browns, and the top doesn't get broiled from the top element coming on during the bake cycle.
As for cakes, again place them on the low rack so that they get bottom heat. I keep my eye on the oven and when the broil element comes on I stick a piece of foil over the cake until it goes off. Otherwise it will set the top and the cake won't rise as much. Even doing that cakes don't rise as much as they did in my old oven, and they brown too much on top.
The convection oven does a good job of cookies, and the broil mode is okay.
I wish I hadn't bought this oven, but I didn't know about the upper (broil) element coming on during the bake cycle until I'd had it for awhile, and it was too late to return it.
If anyone's shopping for an oven, ask questions, and don't get one that maintains the oven temperature by activating the broil element when baking.
Jun 24, 2009 | KitchenAid Architect ® II KEBS208S...
I have a Kenmore Stove and the bottom (bake) element does not heat up. The top Element is fine. I have replaced the bottom element and checked the fuses and they seem fine. Could it be a control panel that...
You could very well have an Electronic Oven Control (EOC) board problem. There two separate circuits that control the oven BAKE and BROIL functions. If you have replaced the BAKE element, and have ensured it connected properly, the only other component that controls that function, is the EOC. If you post back with your complete model number, I can double check to make sure. The model number will be located on a nameplate somewhere around the oven door opening or lower drawer opening. The reason I need to confirm is because some ranges have a separate relay control board.
May 28, 2008 | Kenmore Kitchen Ranges
Kenmore ultra bake cook top indicator light
is there multiple lights(one for each burner?) of so thers an issue with the sensor on the element and the element would need to be replaced, check your manual generally a loner possibly 5 year warr on elemnts
Apr 09, 2008 | Kenmore 92022 / 92024 / 92025 / 92029...
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
Mar 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven will not heat to requested temperature
Shaffy, When baking only the bake element should heat. When broiling only the broil element (upper) should heat. Your oven is a Kitchenaid, you have a 5 year warranty on any electronic element or control board. You may have a temperature sensor that is not working right. The oven just might need to be calibrated, the instructions would be in your owners manual. Your bake element might be failing, it would have to be ohmed out. You also need to verify that the bake element is getting 240V. when turned on. Catriver...post back
Sep 07, 2006 | KitchenAid KERC507 Electric Kitchen Range
Kenmore 96422 / 96424 / 96429 Electric Kitchen Range Logo
106 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
