Question about Powerware Invensys 9120 Model 1000i (05147362-5502) UPS System
I recieved a Powerware 9120 1000 with no batteries. It appears all three batteries attach in series. Is this the case? Thanks! Russ
    Scholar:
  • 39 Answers
Batteries are connected in series on your PW9120-1000. Connect the battery farthest from the end that faces the front display of the UPS with the incoming red wire to the red terminal on that battery. Connect the short cable from the black terminal on that battery to the red terminal on the next battery (these batteries will face each other, but one set of terminals will be at the top and the other set will be at the bottom). Connect the longer wire from the black terminal of the second battery to the red terminal of the last battery (which will face opposite the 2nd battery). The black terminal on the last battery will connect to the thick black wiring coming in from the rear of the battery case.
The only batteries for the PW9120 that I will use are the PowerSonic PS-1290 F2, rated at 9.0 Amp. Hr. These will fit and the 9.0 amphr rating is the only one that will match the original battery life.
Posted on Feb 08, 2011
    New Friend:
  • 45 Answers
Hi, here is the Eaton page (Eaton acquired Powerware about 5 years ago) with the user manual for the 9120. It doesn't make sense for a 1000 9120 to not have batteries: http://powerquality.eaton.com/EMEA/Products-services/Legacy/Legacy-Products.asp. Also, here is the form to ask for help on this product: http://tools.mgeops.com/form/support/index_hard.php. I'm assuming that you're probably not in the United States so this is the UK-based form.
Posted on Oct 26, 2010
SOURCE:
Alarm #191 open cell voltage powerware 9130
Remove the front panel plastic cover where the batteries are located, then plug the two connectors together, restart the UPS, and it should be fine.
Aug 13, 2013 | Powerware Series 9 9170 UPS System
Alarm error #191 comes from a battery test, where batteries are put under load for 25 seconds. (If the alarm is unexpected, you might have enabled the periodic 30-day battery test.)
#191 is test failure for battery internal resistance. So, need to locate and replace the bad battery, then run the battery test manually. If batteries are good, make sure no battery connector is corroded or loose.
Feb 04, 2013 | Powerware Series 9 9170 UPS System
Powerware 9120 6000i model indicates a charger failure. It is the first time that we opened this unit and we do not know the location of the charger circuit (we do not have a schematic diag). Could you...
The charger in powerware 9 series 9120 6000i ,the fan is of a quality that it fails and the heat sink does not get sufficient cooling ,it runs on 12 volt ,i replaced it with a cpu fan from a mainboard on a pc and it works perfectly now. make sure that the fan is running else the charger might go in protection or can fail due to the transistor on heat sink fails.
Feb 08, 2011 | Powerware 9120 UPS System
I have a powerware 9120 and had to replace batteries, unfortunately I had a blonde moment and didnt take note of how the 3 batteries were connected, so my question is are they all connected together with...
Batteries are connected in series on your PW9120-1000. Connect the battery farthest from the end that faces the front display of the UPS with the incoming red wire to the red terminal on that battery. Connect the short cable from the black terminal on on that battery to the red terminal on the next battery (these batteries will face each other, but one set of terminals will be at the top and the other set will be at the bottom). Connect the longer wire from the black terminal of the second battery to the red terminal of the last battery (which will face opposite the 2nd battery). The black terminal on the last battery will connect to the thick black wiring coming in from the rear of the battery case.
Feb 03, 2011 | Powerware 9120 UPS System
Hello, my Powerware 3105 beeps 3 times every 30 seconds or so. I think the battery is not working anymore because when I unplug the power source everything connected turns off. Can you confirm bad battery...
Your problem is showing up under the Powerware 9305 (a very large UPS) but your comments are about the 3105. It sounds like your battery is dead. If your UPS is over 3-5 years old, that's most likely the case. The website address to view the user manual is www.eaton.com/3105 You can contact Eaton directly, too. Eaton bought Powerware about 6 years ago. Here's the contact info. Be sure to have your serial and model numbers ready from the rating label on your UPS.
Toll Free: 1 800 356 5737
E-mail: [email protected]
Dec 16, 2010 | Powerware Series 9 9305 (PW930525KVA) UPS...
How to adjust the display screen britness
Here is the documentation page: http://www.zoomerang.com/Survey/WEB22BKRKCECDW/
You can also contact Eaton. They purchased Powerware about 6 years ago. They retained the Best Power/Powerware service network and technicians:
Toll Free: 1 800 843 9433
International: +1 919 871 1800
Dec 12, 2010 | Powerware Best Power Unity/I Three-Phase...
What are the dimensions and weight of the Powerware Series 9 9159 UPS System?
Here is the documentation page for the 9150: http://powerquality.eaton.com/Products-services/legacy/9150-info.asp Looks like 28 inches high x 16 inches wide x 29.5 inches deep. 510 pounds (231kg). If you need further support, you can call Eaton (Powerware was bought by Eaton)
1 800 843 9433
Nov 09, 2010 | Powerware Series 9 9150 UPS System
Powerware 9120. 1500i UPS
You can download the manual and other literature at
http://www.powerware.com/EMEA/UPS/9120_info.asp
The contacts for support in India are found at
http://www.powerware.com/India/Service_Support/IN_Office_Contact.asp
They offer a battery monitoring software package, at
http://www.powerware.com/India/Service_Support/IN_Battery_Services.asp
You can email support at http://www.powerware.com/pp/Check.asp?key=code1
Good luck
Feb 20, 2008 | Powerware 9120 UPS System
Open Questions:
See all Powerware Invensys 9120 Model 1000i Questions
Powerware Invensys 9120 Model 1000i (05147362-5502) UPS System Logo
249 people viewed this question
Top Powerware Computers & Internet Experts
Marvin
Marvin
geekyshrink
geekyshrink
Level 1 Expert
B.Th. Pluijm
B.Th. Pluijm
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
