Question about DISH Network IR Remote Control
My daughter sat on the dish network remote and now there is no sound. All other devices hooked to the audio receiver work (DVD and Radio Tuner), but not the satellite. Any thoughts?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 358 Answers
Dbuerck
I would check to see if the "Mute" button was accidently pressed when your daughter sat on the remote. If not, unplug the receiver from your electrical outlet for 10 seconds and plug back in. This will cause the receiver to reboot and re-acquire the satellite signal. After the picture returns, see if you are getting audio. I hope this helps.
Ray Calo
DISH Network
Posted on Jan 22, 2011
SOURCE:
How do I hook up a Pioneer VSX-918V receiver to Sat.Dish box?
For the audio portion, you must have either a digital coax, optical connection or analog L/R composite RCA jacks plugged into the "Sat.audio in" on the rear panel of the chassis. The other end of THAT connection must come from the "audio out/ variable out" from the T.V. or from the Sat.Dish box.
Sep 12, 2014 | Pioneer VSX-918V Receiver
Tip
DISH VIP612 Amplifier Control
DISH Solo DVR VIP612 Amplifier / Receiver Control
Would you like to program the Universal Remote that came with your Dish Solo DVR VIP 612 to control the volume of your receiver, tuner, or stereo instead of your TV's volume?
The first step in using the Universal Remote Control that came with your Dish Solo DVR VIP 612 to control the volume level of your receiver, tuner, or stereo is to program the remote to control your audio device using the AUX mode button.
Once your remote controls your audio device in AUX mode, you probably want to continue to control the volume of your stereo even if the remote is in SAT, TV or VCR mode.
To setup your Dish Solo DVR VIP 612 Universal Remote to control the volume of your stereo regardless of which mode it is in, follow these steps:
  1. Press and hold the AUX button until all the mode buttons are lit, and then let it go.
  2. Press the POUND (#) button.
  3. Press the PLUS side of the VOLUME button.
  4. Press 0.
  5. Press the POUND (#) button. The AUX button flashes three times to tell you the programming is complete.
  6. Confirm the VOLUME buttons are operating the tuner/amplifier's volume control by pressing SAT or TV, and then adjusting the volume. Your tuner/amplifier's volume should change rather than your TV's volume.
Your Dish Solo DVR VIP 612 Universal Remote is now setup to control the volume of your stereo regardless of which mode it is in
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 | Televison & Video
Tip
  4. Press 0.
I hope that helps.
on Jul 05, 2010 | DISH Network ViP 612
Pioneer 409 setting up for surround sound
I think there is a switching problem in the surround receiver. I would take the receiver to a qualified servicer. There is nothing user serviceable in the unit. Question .Why are you using optical output from ps3. I recommend you connect all you a/v devised to the tv. Then connect the opt out of tv to receiver. that way what ever you are viewing will send audio via opt out of tv to receiver. that way you do not have to switch input on receiver. Hope this helps.
Jan 07, 2014 | Pioneer VSX-D511 Receiver
I have dish network and a new rca tv with dvd the
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Mar 11, 2010 | DISH Network 322 DTV Receiver
CAn get audio but no video
On the top of your dish remote there are several buttons to control different devices..... pres the TV button to access the TV's menu. This should have been set up by the installer unless you did it your self..... Dish is very helpful with answers.....
Feb 14, 2010 | RCA RTD300 DVD/VCR Home Theatre System...
After programming my NEW Harmony One Logitech remote I can't get it to change channels on the Dish HDTV DVR along with a bunch of other problems.
To control a Dish Network PVR/Satellite, it needs to be set to respond to the default Remote Address (1).
To reset your Dish Network PVR/Satellite to the default Remote Address:
1. Press SYSTEM INFO on the receiver's front panel. The System Information screen displays on the nearby TV and shows the Remote Address.
2. Using the original Dish Network remote, press and hold SAT on your remote control for about three seconds, until all of the mode buttons light up, and then release SAT.
3. Using the NUMBER PAD, press the 1 button
4. Press POUND (#). If you entered the address correctly, SAT will flash three times.
5. Press RECORD. Make sure the Remote Address you see on the System Information screen is 1.
6. Press the SELECT button on the front panel to close the System Information screen.
7. Your Harmony remote should now control your Dish Network PVR/Satellite box
NOTE: Dish Network PVR/Satellite receivers sometimes have two tuners, allowing them to be used in more than one room on different TVs. Harmony remotes can only control a Dish Network receiver's main tuner while still in the same room with direct line of sight to the device.
What other issues are you having with the remote?
Dec 25, 2009 | Logitech Harmony One Advanced Universal...
No Sound In Home Theater with Dish HDTV DVR Dual Mode Remote Connection
HDTV is not carried via coaxial cable from tuner, you need HDMI or the 5 RCA cables that are different colors. I forget if they are called component or composite, I think they are called composite, the R and W are sound. If you run the HDMI or composite cables to your TV, there should be a variable out or audio out on the back of the TV that outputs ANY sound coming into the TV, like Wii, DVD, tv, etc. So if you want to listen to tv sound, just pipe the audio out to the receivers available input and turn it up. Cant be used with mag input (turntable) all others are compatible. Did this answer your question? Sat cables are usually kept under 130 ft from the dish, and the dish receiver can output coaxial signal over 400ft on RG-6 cable. HDMI is limited and can get very expensive. Does your sat box have a coaxial digital out (orange RCA) you can use that if your receiver can read it, usually associated with the DVD input or video input, but only for digital encoded programs.
May 19, 2008 | Insignia 5.1-Ch. Home Theater System with...
Programing dish network remote control for aiwa av-x220
You will have to call Dish Network.
800-825-2557
Feb 22, 2008 | Aiwa AV-X220
DISH Network IR Remote Control Logo
Top DISH Network Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
