Question about Sport & Outdoor - Others
I have a Peak 2,500,000 candle power cordless rechargeable spotlight (PKCOTN) and it's not recharging. I tried to recharge on the wall outlet and connect the recharger on the bottom of the handle to the wall outlet as well. The halogen light on the bottom is working but the big spotlight is barely lit. Can you please send me a picture of the charger how it looks like? This one belongs to my brother who passed away 3 weeks ago. I cld. not find the instructions and the box it came from. Pls. send your response to my wife's email address. Thanks, Dan
  • Randy Jones
    Randy Jones Jul 01, 2019
    I just decided to look up information on my Space Searcheye 2,5000,000 Candle Power Flashlight it will not charge either light, it was a flashlight my Deceased wife got from somewhere and it hasn't been used in about 4 years, can you tell me what I need to do to get it fixed. I removed the 2 screws from the lens and looked inside but have no idea what is wrong with it. Thanks Randy
    New Friend:
There is a panel on the back which opens up to expose a 120 v house current charger. You must use an extension cord (not supplied) which will fit in the narrow channel. The supplied 12 volt car charger plugs in to the bottom of the handle. A red LED lights up when either charger is used. The manual suggests 24 hours of charging before use. My condolences.
Posted on Dec 16, 2010
PkCOTN Peak spotlight won't recharge? You need to replace battery 3FM4 6volt battery. EBay has them $10.00 and take a few screws out. Reassemble. Charge and your good to go
Posted on Apr 11, 2019
SOURCE:
Where can I purchase a VEC 184POB spotlight
Black and Decker bought Vector in 2006. As such look for a black and Decker 2 million candle power light.
https://www.amazon.com/Black-Decker-VEC157BD-Rechargeable-Spotlight/dp/B000EJS91O
Sep 23, 2017 | Camping, Backpacking & Hiking
Where can I purchase a spotlight VEC 184POB
I NEED A POWER CORD CHARGER FOR THE 3,000,000 CANDLE POWER HALOGEN SPOTLIGHT. WHERE CAN I FIND ONE
If this is the usual sort of halogen spotlight, it is usually supplied with a mains charger adaptor and a lead to charge it from the car cigar lighter socket.
Both those items are also commonly supplied with a range of car-related rechargeable items, torches, jumpstarters and so forth.
I have several such items and I find the 12 volt lead and mains charging adaptor completely interchangeable between all of them. Rechargeable halogen spotlights generally have a very disappointing battery life of around 20 minutes unless a very expensive professional model is bought.
If it is not a rechargeable type that must be permanently connected to the car cigar lighter, the power cord is usually permanently fixed to the lamp but if it isn't, the cable will need to be substantial enough to carry several amps - something similar to that of perhaps a large coolbox.
Apr 11, 2017 | Camping, Backpacking & Hiking
How do you replace light in Peak rechargeable spotlight
Sorry I don't know how to change the lights, but I need to know the charger volts and mA. Could you look at your charger and let me know please? ian 83877 at gmail
Jan 18, 2014 | Peak Performance Rechargeable Led Lamp...
FIXIT TOOLS rechargeable halogen spotlight wih 3,000,000 candle power will not recharge
The battery is probably done. Try replacing it or make sure the charger is working.
Aug 23, 2011 | Camping, Backpacking & Hiking
How to replace a bolb in a dorcy 41-1088 spotlight
I charged the battery overnight, and it was working before I charged it, and now it will not work. What could be wrong with it. The bulb doesn't look blowed.
Tommy or Kathy Ingram 304-425-1120
Nov 03, 2010 | Dorcy International Dorcy 5 Million Candle...
I need 3 light bulbs for a 3 million candle power spotlight from Gordon 12Volts
Hello! I have a marinepro, 12-volt, 3 million candle power spotlight (mpn #MPAT-996). I found out that the manufacturer is RoadPro (866) 622-7979. After contacting them, they said the replacement bulb is an "H3 12v (volt) 100w (watt) and can be found in the Walmart camping section or should be available at any car parts store. I'm going to go to Walmart to find mine. Hope this helps others!
Mar 08, 2010 | Vector 3 Million Candlepower Rechargeable...
What is the recharge time for a 3million candle power vector model vec139br. batteries are fairly new
You should charge it for at least 10-12 hours, but not any more than that or you will overcharge the battery.
Feb 12, 2010 | Vector 3 Million Candlepower Rechargeable...
I am looking for a 1 million candle or more hand
Try this link, lots of good sugestions under $20. Your local Kmart/Wal mart or Meijer should have them also try Home depot or Lowes as well
http://shop.ebay.com/i.html?_nkw=cordless+candle+power&_sacat=0&_trksid=p3286.m270.l1313&_odkw=rechargable+candle+power&_osacat=0
Aug 06, 2009 | Seachoice Products Compact Halogen...
Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
  • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
  • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
  • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
  • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
  • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
  • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
  • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
  • INCLUDES AC AND DC CHARGING ADAPTERS
  • INCLUDES BUILT IN HANDS FREE WORKSTAND
Sep 07, 2008 | Vector 2M Pwr Rch Spotlight
Sport & Outdoor - Others Logo
2,734 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
