Question about Xantrex Technology Heart Freedom 30 Inverter/Charger, 3000w 130a, 81-3011-12
When it is charging (2500 watt Heart Interface Invertor) it is not inverting, I do not have a manual to refer to answer any questions or suggestions of what the problem is or how to fix it. Some one told me I could go to this site and download a manual for a 2500 watt Heart Interface Invertor. Is this true?
  • 2 more comments
  • nacerlibre42 Oct 25, 2010
    That was not the answer to my question. What I have is: Freedom Marine 25, 2500W, 130A+(2)15A, for Large typical loads; large AC appliances, recommended fuse 300A. Dimensions: 7.9"H x 11.5"W x 13.2"L and weights 50lbs. Model 148036, Xantr#81-2511-12. As before I mentioned I do not have a manual for this Inverter, when it is charging it is not inverting. Can you help?
    I did in my second request. It is a Freedom Marine 25, 250W, 130A (2)15A, Large AC appliances. 300A, 7.9"H x 11.5W x 13.2L, 50 lb, 148036, Xantr # 81-2511-12.
    Thank you very much Tim, I think I may have over reacted but I do appreciate your time and consideration.
    Thank you again,
    [email protected]
    Thank you for being there to offer a very good service, I am very happy to know that you are there. Thank you again for your help.
    [email protected]
    President:
  • 2,777 Answers
I am looking for this manual for you now, please confirm, is it a Xantrex Technology Freedom? Please confirm the exact make and model number for the device and I will find it for you.
Thanks! Just reply here and I will get back to you
Tim
Posted on Oct 25, 2010
Testimonial: "Yes and thank you very much, your help with this has enabled me to at least get some facts and figures. Thanks Tim "
  • 1 more comment
  • Tim Grayson
    Tim Grayson Oct 25, 2010
    Oh I see, I couldn't see that response until you sent this one, it's strange how the site here works... Checking for it now for you.
    Tim
  • Tim Grayson
    Ok I found it here for you, these are not easy to come by. I have put it on my personal webserver for you. I would recommend you save it locally to your computer.
    Here it is:
    http://micromatikal.dlinkddns.com:8000/c...
    Thanks,
    Tim
  • Tim Grayson
    Weird, you requested a refund for this question? I thought for sure I helped you here... you even acknowledge it in your remarks there? Just wondering what happened out of curiosity?
    Thanks
    Tim
  • 2,973 Answers
The following site gives you an idea. Please download the manual from there in pdf format.
http://www.xantrex.com/documents/Discontinued-Products/Freedom%20Jazz%201000%20-%201500%20-%202500.pdf
SOURCE:
Where can I bring my Heart interface freedom marine 10 1000 watt 50 amp inverter charger to get repaired... I live in merritt island florida
Hi Nick!
I would strongly suggest contacting Xantrex service. IF your unit is still under warranty, it could save you some cash. If not, here's their contact info:
http://www.xantrex.com/power-products-support/overview.aspx
Nov 15, 2014 | Boating
Hi Nick!
Manual for black and decker 1200 watt invertor
some idea for inverter, collect inverter circuit Books from market.
May 28, 2012 | Black & Decker Vector Cable Kit for 1200...
Can this equipment be used bidirectionslly? i.e.
you can use an invertor to power a battery charger to charge the boat battery but you could not use the invertor to charge the battery it was running from as the invertor will use power faster then the battery could be charged
Apr 05, 2010 | Vector MAXX 400 Watt Power Inverter -...
Fan does not work.
Two things...one the fan only workk when the unit get hot or you created short the inversters are very sinsative and if you make mistake you are dead...see try it for ferw min and see...but first try to reset the unit and that by disconnecting the negative and positive from the back and turn the unit on to get all charges in the unit out then reconnect the cables do not forget to ground the unit to avoid sparks.
Sep 09, 2009 | Vector VEC053D 1200-Watt Power Inverter
Heart interface 30 marine quit charging
the charge fuse may have broken or the charger is bad
Jul 15, 2009 | Xantrex Technology Heart Freedom 30...
I just bought a RoadPro 2500 and i want to buy like a dorm fridge how many watts or volts size would work??
If you are referring to the RoadPro RPPI-250
  • 2000 Watts Continuous Power
  • 2500 Watts Power Output @ 10 Minutes
  • 5000 Watts Peak Power Output.
  • A small fridge will use about 500 -700 watts, with startup wattage at around 2000watts.
  • So, a dorm fridge will work fine.
  • the RoadPro converts DC to AC voltage, so a regular 120 volt dorm fridge will work.
  • Jul 05, 2009 | RoadPro RPPI-2500W Inverter
    Is this inverter powerful enough?
    You are right. This is not enough to operate this freezer. You are going to need a bigger invertor it get it to work properly 900 or 1000 watt should be efficient even though it is not the best way to run the unit. If the unit has a problem you would be replacing the inverter all the time. Just FYI
    Feb 20, 2009 | Black & Decker Husky 750w Power Inverter
    Heart Freedom invertor 25/12 - cannot get invertor to function
    Batteries could be too low, or unit could think batteries are too low because it is not set up for your battery configuration. (voltage, amperage, deep cycle, wet, gel, agm etc.)
    I am not sure how you set up that model but the manual should explain it. If you don't have one you can get it online from xantrex.
    Jan 08, 2009 | Xantrex Technology Heart Freedom 20 12...
    Xantrex Technology Heart Freedom 30 Inverter/Charger, 3000w 130a, 81-3011-12 Logo
    617 people viewed this question
    Top Xantrex Technology Boating Experts
    concpumper
    Level 1 Expert
    ray gallant
    ray gallant
    Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
