Question about Frigidaire ATF6000ES Front Load Washer
Washer wont spin out clothes when it is in the final spin
    New Friend:
I have a atf6000fs1...I washed a load and i thought it was done but items were still wet. So i turned on the spin cycle and it flashed err and turned itself off. It wont run. Any suggestions???
Posted on Oct 25, 2010
SOURCE:
Why are clothes dripping wet after final spin?
There is a balance sensor in the machine that checks to see if the load is distributed for high speed, When that sensor goes bad, the machine wont spin the water out of the clothes. YOu need to check for spares
Apr 22, 2016 | Tricity Bendix AW1000W Front Load Washer
Kenmore washer model #417.42042100 is not spinning the clothes all the way.
First you need to open the cabinet and remove the boot from the tub to the pump and clear the filter. Try that then run a cycle and post back the results.
Dec 05, 2012 | Washing Machines
Wont final spin
sorry have not come across that model its not within my expertise
Nov 14, 2011 | Washing Machines
Wont go into final spin
The final spin on this model requires an additional lock from the computer to the door. Remove upper rear panel and look at board. Find the tiny resistor that says R-11. If it's burnt looking the board and the wax motor (at the lock) need replaced
Mar 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Damp clothes at end of spin cycle
Time to check out and clean your filter...........
Mar 01, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Wet clothes after final spin cycle
There are two speed (or three) on most washer motors and what happens is that a motor speed will stop functioning--it will wash the clothes, but the high speed will not function. This also could be the controller, but more likely it is centered at the motor. It the motor is functioning, it coulfd be in the transmission of the machine--which may be the problenm since you heard a loud noise. I am not familiar with your machine, there could be an electronic switch for the transmission to go into high speed as well that has gone bad. I wish I had more direct knowledge of your machine.
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
My washer wont do the final Fast Spin
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Do this - I had the same problem and this fixed it. It takes about 10 minutes.
Oct 27, 2008 | GE WSXH208A Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
415 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
