Question about Ovens
GE JKP15 built in electric oven malfunctioning. Oven door lock light comes on and can't use for baking. Occassional error code, but most frequent error is locked oven door. Is replacing the EOC board the solution? How do I replace the EOC board?
  • tmpollet Oct 25, 2010
    GEJPK15 built-in electric oven. Problem with locked door. In the middle of baking, locked door light will come on, shutting off the oven baking. Sometimes the door actually locks, other times the oven just hums like the door is trying to lock. Sometimes can bang, pound or otherwise jiggle the oven door to get the locked door light to go out. Often the problem repeats itself several times until finally the locked door light stops and the oven will then resume baking. I've cleaned the oven as recommended but not sure this is going to fix the problem. Is the problem with the EOC? If so, how do I replace the EOC? If not, what solution might I try. Thanks.
  • 1,711 Answers
Your problem with door lock circuit is not the EOC-Clock. This usually due to pinched wires between control and door lock switches on motorized lock circuits So we advice to check wiring and test operation of door switches. This is tricky problem and need very good attention to the door switches and mechanism.
We have here below the parts layout of the door lock and also all the other parts of your oven which will help you to find the door lock.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=215273&diagram_id=21135727#d21135727
Posted on Oct 25, 2010
  • Ovens Master
  • 4,924 Answers
The issue is not with the board ..but with the lock of the door...Probably it needs a real good cleaning and something to lubricate it and always be sure you push it in a little so that it locks proper..On this sequential task devices..if a task is not complete in order the other will not follow..and the device is stopping ...In our case the locking and unlocking of the door is the first and task when you want to use it ...and the last when you close it ..so if this is not functioning proper..it will not go further ..Even if the door is locking if the sensor is not aware of this ..the program will not allow the next task ..
SOURCE:
What does the F-9 code for a Ge oven mean
An F9 error code on a General Electric (GE) oven indicates that the oven's electronic control system has detected a problem with the automatic door lock. The automatic door lock mechanism prevents the oven door from being opened when the oven is set for "Clean" mode. The malfunction may be a jammed door lock mechanism, a pinched or broken wire, a faulty lock switch or a fault in the control board itself.
Jun 17, 2011 | GE Ovens
JKP15 Electric Single Oven: Oven keeps beeping with F7 error...
F5 Loss of relay drive circuit If this fault code cannot be cancelled, replace the oven control (also called clock or ERC).
May 07, 2010 | GE JKP15 Electric Single Oven
My oven has power but it does not work. When I
Your control panel is faulty and will need to be replaced. You can get another one at repairclinic.com or partselect.com
Jan 13, 2010 | GE JKP15 Electric Single Oven
Oven comes on for 5 min then shuts down everything even the keyboard
Same problem here on JKP15WOW1WW. The cycle starts like this:
1) Open circuit Breaker
2) Open oven panel and push ribbon connector to ERC. Replace planel.
3) Close circuit breaker
4) Run to oven, notice clock flashing some time but not 12:00 and start Bake. Bake button beeps and starts bake coil.
5) Within 5 minutes hear a beep and all buttons on panel are unresponsive. Bake continues. if oven light is on it continues to glow. Only button that responds with a beep (and not to clear bake or oven light) is Clear botton.
Rinse..wash..lather...repeat...
Nov 11, 2009 | GE JKP15 Electric Single Oven
Oven door locked and i have no idea how to unlock.
its not locked its got cracked internally.so it not getting opened and showing locked.click the link and check out http://www.applianceaid.com/micro2.html
Mar 09, 2009 | GE JKP15 Electric Single Oven
GE JKP15 Electric Single Oven - Code F7
If possible i will need the letter that come next after the JKP15.
Aug 19, 2008 | GE JKP15 Electric Single Oven
Inglis F5E1 Oven model: IJP85801
The error code F5 E1 is normally associated with problems cleaning
in this case latch not locking. If you did not initiate the cleaning mode then (as u indicate - was baking) then we have a bigger problem. The controller (clock) has malfunctioned. Press any key for about a minute - F2 should appear - then press cancel observe for about a minute - try operation - either back to normal or change control board
Aug 18, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Oven door won't unlock
try hitting self clean again give it a few seconds for the eoc to think the door is locking then hit stop/clear or cancel let me know if this helps if not i can call ge tech after holidays
Dec 28, 2007 | GE JKP15 Electric Single Oven
Ge oven not sure the model it is 12yrs old
Check all connections to control board. If all check ok then replace control board.
Nov 16, 2007 | GE JKP15 Electric Single Oven
Ovens Logo
59 people viewed this question
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
