Question about Roper RAS8244LQ Washer
After opening the waching machine to rebalance the load, the basket will not start spinning again after you close the lid. The machine simply makes a racheting sound when it tries to start spinning the basket. I then took all the clothes out of the machine and it still will not start and still makes the same racheting sound. Any ideas what is wrong and how to fix?
    President:
  • 1,554 Answers
The problem is in the clutch assembly particularly the thrust washer. Check the condition of the clutch assembly to verify this condition. Disconnect power then remove the agitator. Once the agitator is removed, lay the machine on its back then unclip the pump from the drive motor. Disconnect the motor harness and remove the bolts attaching the gearcase to the base. Carefully pull the motor and gearcase assembly out. The gearcase assembly includes the clutch assembly.
Posted on Oct 25, 2010
6ya staff
SOURCE:
Whirlpool gold ultimate care ii
Possibly motor coupler joining motor to transmission or maybe transmission part (clutch, basket drive, transmission itself, drive block, etc)
Aug 22, 2017 | Whirlpool GSX9750 Top Load Washer
Sometime the wash cycle stops when the spin cycle should start.
From what you're describing it sounds like the lid switch is faulty. Open & close the lid slowly & listen carefully for the click of the lid switch. If you do not hear the lid switch, you will need to replace the lid switch. Other testing will require accessing the controls & using a meter to make some more checks with. If the motor is not running & the lid switch checks good I suspect the timer. If the motor is running in the spin cycle but the basket is not spinning I suspect the drive block, basket drive, transmission or clutch.
Mar 04, 2011 | Maytag MAV7200 Top Load Washer
Ue error code on my LG WASHER
Hi there
hope this helps you .
UE - Unbalance switch error Unbalanced load is sensed three times during a spin operation. Open lid. Rebalance laundry load and close lid.
· Check wiring harness
· Check unbalance switch
· Check circuit board thank your for writing to fix ya.
Best regards Rich
Dec 08, 2009 | LG WD-16115FD Front Load Washer
Machine makes loud banging noise during the spin cycle
The load is out of balance. Open the lid and redistribute the contents. When it's empty, grab the basket and give it a slight push sideways. It should move a little but, not free swing. If it doesn't have much resistance, the "snubber" has dried out and should be replaced. It is simply a piece of rubber in a metal bracket, that rests on the tub. When the basket spins,the snubber keeps it from jumping around.
Aug 31, 2009 | Frigidaire FWT449
My whirlpool does not work in the spin cycle
Check the spin cycle activation switch located on the lip of the machines casing where the lid comes down to close.
Often the switch that activates the cycle either goes out and simply needs replaced. Or has worked loose from it's bracing and when the lip comes down to make contact { push it in } the switch body shifts and doesn't receive enough pressure to activate the cycle.
Replacing the switch is both easy and inexpensive if you replace it yourself and avoid a tech service call that would generally cost more than the part itself.
Jul 27, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Rinse and spin
there is a safety switch on the top...and when you close the lid it pushes down on that switch. investigate that switch and see if its just corroded or needs replacement...i have that same problem when i leave the lid open on my washer...then it works fine when i close it...so im figuring that your's thinks its still open. I hope this helps you out ! and give your wife a hug 8-)
Jun 05, 2009 | Washing Machines
Motor comes on and water gos out but basket will not spin untill lid is opened then closed again . this is on all spin cycles .
HI, you will need to replace the lid pressure switch. it is faulty or the wires may be worn or lose.in most cases, it will be a faulty lid switch.
May 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
LG WM 14225FD eu code
EU --- error means ---Unbalanced load is sensed three times during a spin operation. to resolve the issue ----Open lid. Rebalance laundry load and close lid.· Check wiring harness
Mar 14, 2009 | LG WD-1280FHD Front Load Washer
Spin Cycle Problems / Noise
Have notice some spring below or in the floor ? the drum basket need a balancer spring in order the drum will control it movement and soundless .available in any apliances center.
Jan 01, 2008 | Whirlpool LSN1000LW Top Load Washer
Washing Machines Logo
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Gerry Harvey
Gerry Harvey
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
