Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
Looking for Magnavox TV instruction manuel for model RR1337 W101 Some of my television channels do not come in. How do I adjust them so I can receive a program on that channel?
SOURCE:
SOURCE: Adjusting colors on a magnavox 46" projection TV
Replace the CRT fluid. It grows algea in the blue and green only. 9.99 from MCM electronics.
Posted on Nov 16, 2007
  • 1694 Answers
SOURCE: Magnavox TV
Bad IC inside tuner = replace tuner..............................T.
Posted on Nov 18, 2007
  • 5 Answers
SOURCE: convergence picture adjustment?
I had the same problem where all of a sudden it started bowing on top and bottom and the colors were bad. I read on here and other sites about the 2 convergance chips so I figured why not try as the tv was going to get thrown away because I could not find anyone that would touch it. Well I ordered 2 stk392-120's (I know others are saying use the 150's or 180's but I just wanted to put the same ones that were in there) I ordered them from electronix.com for 9.99 each plus 6.60 for shipping they took 3 days to get here and I installed them tonight and it worked great. The whole thing took only about 2 hours from start to finish. Here's a couple of tips....the chips are on the far left when looking at the tv from the back, make sure you mark with a marker where the wires go that you have to unplug as there are about 10 of them, each chip has 19 pins that you will have to soder make sure you have a soder ****** to get all the old soder up as you are heating them up, after you are done puting it back together leave the back cover off and turn it on, then go into your menu and go to pictureand go to manual converge and go to undo multpoint and restore factory as this will reset it all. Then if your color is still a little off as mine was there are 6 knobs in the back of the tv by the chips you were working on, find a channel with a lot of colors and try adjusting the top 3 a little at a time till you get the right color that you like. This should do it. It took 26 bucks and 2 hours for me to fix a tv I was ready to replace, thank god for the internet to be able to look stuff like this up. Good luck!
Posted on May 09, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Posted on Jun 14, 2008
Ecollier2012
  • 3459 Answers
SOURCE: The television I have the
This is a common problem with some older models. Check the site www.magnavoxhelp.com to see if they have a repair kit for your set.
Posted on Aug 13, 2008
PHILLIPS MAGNAVOX model # 7P6035 W101
Check that the lead has not become disconnected internally. The lead plugs in to circuit board.
Jul 09, 2012 | Philips Magnavox 9P6034C 60" Rear...
Philips magnavox 6P6030 W101 picture is too big and can't see the outer edge of the full picture
Not easy with a older set----look to see if a physical control exists in the set for Vertical size (picture too tall) and the adjustment may only exist in a hidden on screen menu.
Jun 11, 2012 | Televison & Video
Looking for manuel to print out on Magnavox MBP5120F/F7
You can download and print the instruction manual for Magnavox MBP5120F/F7 in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Jan 28, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
TV stuck on one channel will not change? help
Go to http://www.m4c.magnavox.com/ then click on product support, select your model, then click on software and downloads. Download the latest software release for your tv and follow the instructions for installing the software.
Aug 09, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
I can't setup channels for Magnavox tv/vcr.
Good luck! We are taking our unit back. We are both professionals dealing with multiple intense things, then we get home and can't figure this stupid POS out.
May 28, 2009 | Philips Magnavox MDV530R DVD VCR
Philips Magnavox Model 7P6033 W101 (60") moved tv and picture now has distorted vertical hold
ok..... I,m a dummy !!! but not DUMB .....enough to play this freaking game When I figure this **** out I will POST it
Jul 23, 2008 | Televison & Video
Magnavox RR1337 W101 skipping stations
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Aug 26, 2017 | CTX Televison & Video
3 Digit Product Code for Magnavox tv RR1337 W101 (13S401-00AA)
0807 works with a Philips Universal Remote on my Magnavox RR1337 101
Apr 28, 2008 | Televison & Video
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
32 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
