Question about KitchenAid KUDS01FKSS Dishwasher
The bottom part of the door leaks ... how do we fix this?
  • 4,363 Answers
The door is not sealed, at the bottom, to it is the victim and not the cause.
So, check for the correct type and volume of soap. Wrong soap takes LONG time to flush out....
Posted on Oct 24, 2010
6ya staff
SOURCE:
When is a dishwsher supposd to drain? Is pump working correctly?
normal to fill pan during wash and rinse fix door seal if it leaks
Jun 15, 2015 | KitchenAid KUDE40FXSS Builtin Dishwasher
How can I fix my Frigidaire PLD4375RFC Dishwasher that leaks from bottom door even after new door gaskets 154576501 and 154701001.
It sounds like you are fixing the wrong area. If water is coming down between the inner and outer door panel and following the wiring harness, the leak is inside the door. Either from the soap cup mounting or the rinse agent area which I think is the same unit on your model. There is a gasket behind that part. Also check the inner door if its plastic for any possible cracks.
Apr 22, 2015 | Frigidaire PLD4375RFC Dishwasher
Water Leaks out of bottom of door
the first thing i would try is to loosen the hing screws couple of turns,push in on the bottom hinge and tighten screws.
Dec 10, 2013 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Water leaking into bottom of refrigerator section
Make sure you dry everything in the freezer when you have the door open and remove ice. It won't be a leak it will simply be the warm air inside the freezer that has turned into condensation. Double check the seal around the door to see if it curled up as that could be letting warm in and cold out giving same results.
Mar 02, 2012 | GE Profile PFSS6PKX Bottom Freezer French...
I have a Frigidaire Gallaxy Series top loading washing machine, 4 years old that seems to be leaking from the bottom. Is this something I can fix myself? THANK YOU.
Before you buy a new $100 door gasket, pull out the soap dispenser tray and look inside the washer where it normally sits. If there is significant soap accumulation (even 3/8 inch), the water can become backed up and trickle down the washer front to the door bottom, making it look like a door leak. Fixed mine this way.
Jul 30, 2010 | Washing Machines
Water leaks from the bottom door
The gasket that surrounds the door will fix it. If that's what you ordered, it'll be taken care of upon installation.
Jul 11, 2009 | Kenmore Dishwashers
Dishwasher door leak
at the bottom of the door is going to be the door seal starting to go bad. replace the seal
Nov 24, 2008 | Dishwashers
Leaking door
get a thin rubber ring of the same diameter of the door and fix it around tightly then the water wont leak out
Jul 25, 2008 | LG WM-2277HW Front Load Washer
Water leaking out the bottom of the door
You most likely need to make a small adjustment to the door. While the door is open push the bottom of the door towards the machine and pull the top of the door away from the machine, be careful not to go too far. that should take care of the leak. Before you do that make sure the water is coming out between the glass and the seal. I would remove the lower panel and make sure the seal doesn't have a small hole. You should see the seal leak from the inside. Hope this helps
Jan 13, 2008 | Frigidaire GLTF2940ES Front Load Washer
Open Questions:
KitchenAid KUDS01FKSS Dishwasher Logo
148 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Marvin
Marvin
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
