Question about Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore ultra wash quiet guard 3 dishwasher problem
I have a Kenmore Ultra wash Quiet Guard 3 dishwasher and the green flashing light that states its clean stays on and stays flashing. I have turned off the breaker , hoping it will reset its self and the light still stays on I can not even get it to start a wash cycle. please help.
  • 18 more comments
  • txqueenb1 Jun 23, 2008
    I have a Kenmore ultra dishwasher and the washing light is blinking and i can't get it to start a new cycle. I don't have the heated wash button, so the sequence won't work. I did push sequence wash / air drylock buttons and all it does is cause the quick wash button to blink.
    The buttons I have are :
    under cycles
    pots/pans, normal wash, water miser, china gentle, quick rinse
    under options
    high temp wash, sani rinse, air dry.
    DO you have a solution to reset my dish washer?
  • Anonymous Jun 24, 2008
    I have the same problem. Any solutions?
  • itworked Aug 24, 2008
    I had the same problem as tulu93's and jeanlea's 4 button sequence worked! Thanks so much Fixya!!
  • zipsunsrasca Aug 25, 2008
    Tried the sequence and the dishwasher runs for a short amount of time (5-10 min), and goes back to the clean light blinking.
  • Anonymous Aug 29, 2008
    Same problem here but the sequence fixed it. THANKS!
  • jrobles2708 Sep 03, 2008
    no lights on or flashing and will not turn on
  • ericg647 Sep 16, 2008
    I have the Ultra Wash Quiet guard 4 model. The "Clean" green indicator light flashes 7 (seven ) times, pauses, then flashes 7 times again. It will not start despite having unplugged and replugged it in. Any idea what the problem is or how to reset it??? Thank you in advance!
  • Anonymous Oct 18, 2008
    the sequence worked!! Awesome.
  • CallTheMan Nov 27, 2008
    Exact same problem here. The sequence seems to have fixed it -- which is a good thing seeing that we have family coming for Thanksgiving today!
  • Anonymous Dec 20, 2008
    thank you thank you thank you!! worked like a charm....was ready to pull my hair out!! or the little left that my husband has!! :-)
  • marcie12_04 Jan 01, 2009
    i had the same problem of the clean light flashing - i used the 4-button sequence and it worked - awesome - I didn't want to pay for a service call!
  • L4IQ Jan 02, 2009
    I have a Kenmore Ultra wash Quiet Guard 3 dishwasher and the green flashing light that states its clean stays on and stays flashing. I can not even get it to start a wash cycle. please help.
    What is the button sequence that everyone is talking about that clears this?
    Thank you.
  • sugavkmn Mar 20, 2009
    I just saw this sequence trick! I'm gonna try it for sure.
    I'm wondering if I need to press the 4 buttons simultaneously or one at a time, in that order...?
  • bethr828
    bethr828 Aug 23, 2012
    W just moved into a rental that has the Kenmore Ultrawash Quietguard 3. The sequencee
  • luannolson
    luannolson Sep 02, 2012
    did you ever get an answer I have the same problem just have air dry
  • candyman Aug 12, 2013
    it works ...hopefully lol
  • Anonymous Mar 13, 2014
    There are not any display lights when turned on but it still washes
  • Anonymous Mar 20, 2014
    has power. will not run. wash indicator light is flashing.
    Lately, when using the dishwasher it leaks water everywhere. It comes right under the main front panel. Could be the water level getting to high because the base isn't draining well or the rubber lining?
    water everywhere on floor when running wash
  • 4 Answers
Call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Posted on Jul 01, 2008
  • 1 more comment
  • JeanLea Jul 01, 2008
    QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
  • Regina Roberts
    Regina Roberts Feb 02, 2014
    thank you !!!!!!!!!!!!!!!!!it worked
  • Jennifer Williams
    Jennifer Williams Jul 28, 2014
    It worked! Thank you soooo much!!!!
D'oh!!! Found the magic 4 button sequence that resets the dishwasher at this site. Dang, the dishwashers even have computers/brains now. The sequence is press Heated Dry, then Normal Wash, then Heated Dry again and finally Normal Wash again. Basically turning both on and then turning them off. Then ALL THE LIGHTS on the dishwasher came on. Looked like a x-mas tree. Hitting the cancel button cleared it.
It still left me with the blinking green clean light but I did "the 4 button sequence" again, waited several minutes with all the lights on and then hit the cancel and now my dishwasher is able to work again. YEAH!!!
Note: I did clean out underneath the filter (required 2 tools) which had some stuff it it but that didn't fix the problem by itself. May help in the long though. I also found the manual and it said the blinking green clean light is a problem in the heating coil (or a water temperature problem) and suggested calling service. Point is, it the blinking green light returns again, you might actually need service to deal with the real problem that's triggering the flashing green light. Nite and good luck.
Posted on Jan 02, 2009
Drinks on me! You saved us a $65 service call, not to mention no dishwasher for three/four days until the repairman can get here. Thanx for the "secret" codes - heated dry then normal wash ... heated dry then normal wash.
Posted on Apr 05, 2009
The sequence of "Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses)" worked for us. Many thanks!
Posted on Oct 14, 2008
  • 9 more comments
  • r3dbird Sep 13, 2010
    It worked!!!! Thank you so much :)
  • a971 Oct 29, 2010
    it worked for me too!!!!
  • Glenn Overy
    Glenn Overy Feb 08, 2011
    Thank you for posting this information! I hate hand washing dishes. You are a life saver.
  • Mel9966 Jun 20, 2011
    The internet is absolutely amazing! Had exact same problem and Google directed me here. Would have never guessed it would be so easy to fix! Thank you so much for this website!!!
  • Amber Quinn Nov 21, 2011
    Yay!! I worked for me too!! Thank you!
  • gellis1976
    gellis1976 Jan 13, 2012
    Worked for me!!
  • paul Jan 30, 2012
    Holy hell It worked for me as well. thanks for the solution
  • paul Jan 30, 2012
    holy hell it worked thanks
  • Erin Apr 09, 2013
    AWESOMENESS
  • Donna Harris Jul 08, 2013
    Wowie Zowie! It worked. I thought it was dead this time! But it's back to life
    i tryed that lets hope it will work
Have kenmore quietguard3 ultra wash dishwasher. have the same problem with green light flashing and cannot run the dishwasher. would appreciate help w/o having to call repair. thanks. i see something about a sequence? thanks!
Posted on Sep 16, 2008
I have a kenmore ultra quietguard 3 and the clean light is flashing. I do not have heat dry option on my dw just air dry is that what i should use for the 4 code sequence instead of heat dry? I want to correct the problem! I tried using the air dry and going normal wash air dry, normal wash and then air dry but nothing! Do i need to unplug the dw and try again or what? Help!!!
Posted on Feb 08, 2010
  • kali Jul 16, 2013
    Many thanks! I'm so happy!
Help! Mine is locked and i cant get it to do anything. Heated dry and normal wash are lit but so is lock on and the start button is flashing.
Posted on Jan 15, 2010
  • kali Jul 16, 2013
    Many thanks! I m so happy
Yes thank you very much, your 4 sequence code is awesome, just what a busy parent like me needed to get my dishwasher jump started.
Posted on May 29, 2009
    New Friend:
The tech used the same code on ours. He said it is from running dishwasher while using sink. Not being able to drain properly is the cause. To avoid it don't use sink while dw is trying to drain.
Posted on Feb 16, 2014
Press Heated dry, normal wash, heated dry, and normal wash again. Worked for us. Saved us a service call. You would think they would have that in the manual. Guess they need the servical money. Dishwasher is probably preprogrammed to do that after 3 years or so.
Posted on Nov 24, 2009
  • kali Jul 16, 2013
    Thanks!!!! I m so happy!!!
  • Kenmore Master
  • 2,699 Answers
If the clean light flashes 7 times it's an error code telling you that there's a heat problem, it will be either the heater or computer board is bad,if you remove the bottom kick panel you'll find the tech sheet inside the plastic bag,it will tell you how to read out the heater from the board,if the heater is good most likely the board is bad.i see people just resetting the board,yes it will run but after 7 loads it will start over again,it's an error code
Posted on Feb 25, 2018
    New Friend:
The sequence totally worked and now I'm my parents favourite child!!! Well I'm the only child but still.....brownie points!
Jan 9 2016
Posted on Jan 09, 2016
    New Friend:
Totally worked for me, too...thanks for the info! :) Saved me a lot of time and money.
Posted on Jun 25, 2015
2 Suggested Answers
SOURCE:
  • 523 Answers
SOURCE: My Kenmore Ultra Wash Quiet Guard
take kick plate off get book out how to reset board
Posted on Apr 24, 2010
My kenmore quiet guard My partially fills and therefore does not clean. any suggestions
Possibly low water pressure; possibly a clogged inlet screen on the inlet valve; possibly a bad inlet valve (replace it).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Nov 14, 2014 | Kenmore Dishwasher With Ultra Wash And...
Why is my kenmore ultra wash quiet guard blinking clean?
You can go to Kenmore's website, list your machine model and the
problem and you can get an answer. Usually you have to re-program
those machines every 400 hours. Hope this helps
Jul 06, 2014 | Kenmore 24 in. 17482 / 17484 / 17489...
Why are there no lights on my Kenmore Ultra Wash Quiet Guard 3 dishwasher?
So I would guess you can't get it to work at all? It could be the circuit which is inside the door....I would never suggest anyone fix these things themselves. It's always fairly expensive but worth it for peace of mind knowing a job professional done.
Jun 25, 2014 | Kenmore 24 in. 15689 Built-in Dishwasher
I see the pressure tower for a Kenmore Ultra Wash Quiet Guard dishwasher laying in the bottom of the dishwasher. I've just rented the house and haven't used the dishwasher yet. Does this pie
No, the designers put it in there for a reason; it won't work as well without it, as it would with it in. Probably the mounting tabs are broken or sprung. A new tower isn't very expensive. You can probably get one from SearsPartsDirect.com, RepairClinic.com, EasyApplianceParts.com, or AppliancePartsPros.com.
Mar 28, 2012 | Kenmore Dishwashers
Apr 24, 2010 | Kenmore 15899 Built-in Dishwasher
Hi. I have a Kenmore Elite Ultra Wash with Quiet
This may or may not help in your situation, but the following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Aug 19, 2009 | Dishwashers
Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Jul 30, 2009 | Dishwashers
The IRONY of my Quiet Guard!! SO LOUD!!!!
Yes the wash arm can be removed to get to the sump area. Take the model number for your dishwasher and enter it into a site like partselect.com. There you can get a blown up diagram of the components that need to be removed to get to the cause of the grind noise. Usually a seed or some other hard object has found its way down there.
Feb 06, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Quiet guard 3 dishwaher
Sep 23, 2007 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore 24 in. 15689 Built-in Dishwasher Logo
25,211 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
