Question about Microsoft Xbox 360 Console
We keep losing connection to internet when playing xbox 360 live. will be playing and screen freezes up for 15 to30 seconds then kicks us from xbox live.have a router with 3 xboxs hooked up.its unsecured because dont know how to do that .i am on a laptop that is connecting to router but lose connectoin all the time also.im not computer smart but have some friends that can help with any suggestions.dont know how to get ip address or set up security on router.
    Top Expert:
  • 935 Answers
If it's unsecured, there is a possibility that other people nearby are logging on to your internet connection through your open router. The more connections through the router, the slower it becomes. And the Xbox will drop is the connection becomes too slow.
As for a better answer as to why your losing your connection, try relocating the router. Often moving it higher up will allow a better signal. Other times a wall or shelf which contain metal objects is the cause. The signal weakens as it passes through construction materials, and nearby metal objects will definitely cause signal degradation. Try moving the router, sometimes only a foot or two is sufficient.
You should definitely learn the process to secure your router. It's like connecting your computer with a network cable to all of your neighbors computers and inviting them to see what you have stored on your machine. If their computer savvy, they can even watch what your doing in real time and even activate your camera and microphone! (It's been known to happen).
Securing the router involves the use of a network key (think of this as a password). Most modern routers have the default password printed on the body of the router. Using a special program installed when you installed the router, you can access the router and set the password. For example I use a Netgear router and the program that it installs is called "Netgear Genie". You access the router through the program using the routers user name and password (default as shipped is usually "admin" for both. Then set up the router to use security. After this all of your devices you authorize to connect to this router will also need to use the same Network Key (password). It's actually an easy process. For example, after you set the security, the labtop will attempt to connect and finding the system secured, ask you to enter the "network key" or password, to allow it to connect. It should ask you to remember this password so it can connect without assistance in the future
If your still uncertain, try running the router's setup program again. Most are designed to walk you through the process quickly. Just remember that all your devices will need to use the same password, the one that is printed on the side or bottom of the router. Usually it's something silly like "wonderfulwater456879" or whatever. Good luck and be more careful with your data in the future.
Posted on Jun 16, 2017
SOURCE:
SOURCE: wireless connection of xbox 360
I think the problem is (for comcast users) the device given by comcast as arris touch-tone-device. Eventhough connected to a router this device doesnt allow to share the IP betwen the PC and the Xbox..........
that's very sneaky and tricky for comcast...and i also i find it unhonest...........
other internet services as [email protected] make easy to connect to xbox live by using share isp....gateways and routers
Posted on Nov 27, 2007
  • 148 Answers
SOURCE: ip addresses
the wireless adapter is when you have a wireless router,take off the adapter and plug the ethernet cord from the modem to your xbox
Posted on Jul 13, 2008
  • 52 Answers
SOURCE: xbox 360 setup
it way be that your modem and/or router does not recognize the ethernet cord. the contacts on either the cord or port might be fried. try plugging the xbox cord into the laptop port if the laptop is hooked up by cord or try using a wireless adapter for your xbox if the wireless seems to work fine with your laptop.
Posted on Oct 14, 2008
  • 10 Answers
SOURCE: ip address failed
In order to connect your XBOX 360 to your laptop (if the laptop is connected via dial-up), you'll need a cross-over ethernet cable. It's a special type of ethernet cable, which is typically the same price as a regular ethernet cable, but it allows two devices (in your case) to communicate with each other. Then, you'll need to configure your laptop to allow incoming connections via your Control Panel -> Internet Connections preferences.
Hope this help!
Robert W.
Posted on Jan 09, 2009
  • 23 Answers
SOURCE: xbox 360 ics apipa
(this is a solution that i gave someone who had a wireless router... you will also need to forward the same ports even if you have a wired router...)
Ok... I have the best solution to this problem... Obviously you have wireless internet... so that means you have a wireless router... you need to login to the wireless router settings... usually it is192.168.1.1 that you type into your browser by default... if it is not192.168.1.1 in order to find your router address you need to click on start.... run... type in cmd... then in the command prompt type in ipconfig/all... your router address will be the number next to default gateway... put that into your browser and login to the router... dont exit the command box just minimize it because you will need it later...if you have not changed the password its usually either password...admin.... or nothing at all.... once you are logged into your router you need to forward the open the ports for your xbox 360 for it to be able to connect to xbox live with an open NAT... (meaning you can connect to everyone without problems) once you get to port range forwarding you are going to have to put in 6 ports for best performance... name them all XBL or XboxLive... and forward these ports... 87-89 UDP.... 3073-3075 UDP..... 80-80 TCP... 88-88 UDP...3074-3074 BOTH... and 53-53 BOTH... make sure they are enabled... find out what your start ip address is... i changed mine to 192.168.1.200with a maximum number of users at 50... (this will come in handy and i will tell you why later...) turn on your xbox 360 and go to network settings and manually change your settings... so if you have your ip address range from 192.168.1.200 - 192.168.1.249 like me... change the ip address of your xbox 360 to 192.168.1.240 (the computers that connect to your wireless router always take the low ip addresses... so setting your xbox 360 ip address to 192.168.1.240 will make it so there arent any ip address conflicts...) remember the box i told you to minimize? you are going to have to input the numbers in the command box into the boxes in the xbox.... 255.255.255.0 for the subnet mask...default gateway for the gateway... enter in th e dns settings... first one is primary... second one is secondary... save and you are done with that... if you have your ethernet cord hooked up from your computer to your xbox 360 click on start... control panel... network connections...click and highlight the network bridge and your wireless connection...once you have them both highlighted... right click... and click on bridge connections... and everything should work fine...
Posted on Jul 10, 2009
When I did the xbox live test from were it keeps kicking me off saying not enough banwidth while I was trying to play battlefield3 it said service alert and it gave me a bunch of codes 20A8-4840xbox360...
don't simultaneously use other device connected when you are on xbox live , then you ll have difficulty playing on xbox live .
Make sure you disconnect all other devices connected to internet before you connect you xbox to internet
if you have no devices connected to your internet then may be some one has hacked your wifi
change the wifi password , it ll fix the issue :)
Jan 23, 2013 | Microsoft Xbox 360 Console
Could you tell me in steps how to conect to xbox live
Step 1 Form your Xbox 360 you need to be connected to the Internet by a straight LAN line or wirelessly. You can test you connection by going to the setting screen on your Xbox 360.
  • Step 2 Once connected to the Internet for your Xbox 360 go to your main account screen and find the tab that says "Join Xbox LIVE" click on that link then follow the simple instructions that the Xbox LIVE will provide. At this point you should have a name in mind for your gamer tag.
  • Step 3 Xbox 360 LIVE has several different options available for memberships. They are a monthly, 3-month and 12-month membership accounts. I would recommend a simple one month account if you just wanted to check out the features offered on XBOX 360 LIVE. If your an avid gamer and love to play games online with friends, the 12-month Gold membership is the way to go.
  • Step 4 Once you've completed the process of joining Xbox 360 LIVE, they will send you a confirmation email confirming your membership. Now you can log on to Xbox 360 LIVE and start doing this like customizing your avatar and playing online multi-player games.
  • May 26, 2010 | Microsoft Xbox 360 Elite Console - Black
    Xbox 360 live; trying to play Mercenaries 2 - won't connect to EA
    Problem seems to be the XBOX Hard Disk Drive (HDD). Run the game and play it once for about 30 mintues, then try again with the HDD inserted. It should now work.
    The problem seems to be a conflict with the HDD or with the EA servers, as the XBOX Live account will try to connect to the now dead EA servers for this 2008 title.
    If all else fails, you will need a portable memory card, not the HDD to play this game. It's okay if this is the case. Create an offline profile. The game no longer connects to the EA servers anyhow.
    Jan 24, 2010 | EA - Electronic Arts Mercenaries 2: World...
    My xbox keeps freezing while playing
    If your Xbox keeps on freezing up during games then this is normally the start of the red lights, it happens when the GPU and the CPU lose connection, to fix it you need to send it in or you can use a recomended Xbox 360 Repair guide to fix it.
    Jan 01, 2010 | Microsoft Xbox 360 Console
    I keep losing connectuin to xbox live
    if you unplugged your modem it probably changed your ip, that happens to me alot lol. and if you have a from from the xbox to the network, that means your connection is wrong. make sure that the ethernet cable is connected from your xbox 360 and modem, then try again.
    Dec 09, 2009 | Microsoft Xbox 360 Elite Console
    My Xbox freezes after a few seconds.
    ;( if your connected to xbox live try to remove the cord
    Nov 23, 2009 | Microsoft Xbox 360 Console
    Freezing in the middle of play
    If u r playing on xbox live it can be the internet connection or memory problem.
    Mar 27, 2009 | Microsoft Xbox 360 Console
    MY XBOX 360 NBA LIVE 09 KEEPS FREEZING UP ON ME. PLEASE HELP ME OUT THANK YOU
    Try playing your game without Xbox live at first. If it doesn't freeze up, then you have an internet connection problem. Try reconnecting wires. If it does freeze up without Xbox live, it may just be the game.
    Feb 21, 2009 | Microsoft Xbox 360 Console
    Screen freezes when i sign into xbox live.
    That must be login problem, what it update or something who may disturbing online failure.
    Jan 14, 2009 | Microsoft Xbox 360 Console
    Screen freezes
    xbox 360 , halo 3 . every thing is set up for xbox live but my ip address keeps failing.
    p.s.english please
    Aug 26, 2008 | MTV Games Rock Band Bundle for Xbox 360
    Microsoft Xbox 360 Console Logo
    88 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    Ekse
    Nathan Hamilton
    Nathan Hamilton
    Paul Castley
    Paul Castley
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
