Question about Quasar SP-3232 32" TV
What is the Quasar TV code when using a Direct tv REMOTE?
  • mikev986 Oct 25, 2010
    Doesn't work. The Direct TV remote doesn't have a "setup" button.
    Top Expert:
  • Quasar Master
  • 76,140 Answers
Hello
There is only one four digit remote code for Quasar TV with me. Here it is. You just try. Proceedings are also given. Ok.
[0716]
Proceedings
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Posted on Oct 25, 2010
SOURCE:
I have a Quasar SQ5000 50inch and need remote code for direct tv remote
Here are the three directv codes for your brand of tv
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand:
Model (optional):
The following codes work with your brand. 10250 10650 10051
Setup Instructions
  1. Set the "Mode Switch" to TV.
  2. Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  3. Enter the 5 digit Code above.
  4. Try your new code and tell us how it worked!
Dec 05, 2014 | Quasar Televison & Video
What is the codes for universal remote control
If you have a universal remote control, you can use its "code search" feature to find a code that will enable some or all functions of your Quasar TV. If a search does not yield a code or codes, the code library in your remote may not have have one that will work. Youmay have to try using another programmable remote.
Aug 01, 2014 | Quasar Televison & Video
How can i find remote control codes for my quasar tv
Hello
Three digit universal remote codes for Quasar TV are:
003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Four digit univeral remote codes for Quasar TV are:
0171 0148 0054 0170 0062 0374 0381 0003 0070
Direct Code Entry
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand. NB: Switch OFF and switch ON your TV, WITH ITS FRONT PANEL POWER CONTROL SWITCH, each time before trying an other code.
OK.
Feb 23, 2011 | Quasar VV-1301 13 in. Combo
I have a Nextech TV remote control. What are avalable codes so I can match up to my Quasar TV
Scott at Nex-Tech here.Had your question about remotes codes here on fixya forwarded to me and wanted to help. The answer depends on which remote control you are using.The Titan remote control codes for Quasar TV's are 10250, 10051, 10165, and 10650. The Quasar TV remote codes for the Atlas remote is 0051. If you look at the previous links, you should be able to identify your remote. If you have any questions or need help inputting your codes, you can always call our toll free tech support at 888-565-3200, they'd be happy to walk you through the process. Thanks for your business, hope this helps.
Feb 21, 2011 | Televison & Video
What is the TV Code for programming the remote control for Quasar TV model # v v 2018 w ? Thank you.
Hello
Four digit universal remote control codes for Quasar Tv are:-
Three digit universal remote codes for Quasar TV are:-
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
OK.
Dec 08, 2010 | Quasar Televison & Video
Need tv code for Quasar LSSQ0227 its a comcast
had this problem myself and I assure you that a) Comcast is populated by idiots without training, and b) that Quasar hasn't 'deliberately designed' their tvs to not work with Comcast remotes, which is what Comcast will tell you.
Solution: Add a 1 to the code, ie 10250, 10051 etc. Quasar is a 5 digit code, not 4 as Comcast believes.
Feb 06, 2010 | Quasar VV-1302 13 in. TV/VCR Combo
Universal remote + Quasar TV = no luck. pls help!!
Do Research on the remote with the tv brand name in google. you will find something such as an manual.
Jan 05, 2010 | Televison & Video
Older Quasar Video TV combo Model UU1220AW, SN VSOS1226
can you please send me the tv vcr combo code for my philips remote, to the old quasar tv. thank you [email protected]
Apr 20, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
Quasar vv2020 remote codes
Quasar tv/vcr 0374 0381 0035 0162
These are the only ones I found for the combo's
Mar 18, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
Televison & Video Logo
1,337 people viewed this question
Top Quasar Televison & Video Experts
Steve Allison
Steve Allison
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
