Question about Jenn-Air JGR8850 Gas Kitchen Range
Oven flame not consistent goes on and off and heavy burning smell
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
I have a kenmore gas range md 79072909012 the oven lower burner has delayed ignition to the point that temperature is loss in oven and heavy gas smell in home....I am a licensed mechanical contractor in...
If its lighting with the panel and baffle removed, but now with them installed, but you get a heavy gas smell its likely the gas mixture is too rich (i.e. the covers are too tight, gas pressure pushes all air away from burner so only gas and very little air occupies the space above the burner and its too rich to light, oxygen starved.) Not an issue when the covers are removed, so it lights fine. Try adjusting the burne for less gas an more air, see what happens.
Aug 25, 2014 | Kenmore Kitchen Ranges
Burning smell from underneath the bottom oven plate
Something spilled into the area where the flame is Those big gaps in the bottom plate is how the heat gets into the oven from the burner . Try letting the oven burn off whatever spilled in it
Jan 04, 2014 | Samsung FX510BGS Gas Ranges
Popping noise, flames between oven and wall and burning plastic smell from Kenmore gas oven. We had noticed the smell off and on for 2 months, but the oven still worked properly until last night. I...
sounds like the insulation on the cord has been worn through and is shorting out. turn off the breaker pull out the oven and look where the cord goes into the oven and look for black burn marks.
I’m happy to help further over the phone at https://www.6ya.com/expert/troy_065b1fb8718d7670
Apr 09, 2017 | Kenmore Ovens
Wolf oven heavy burned smell. LPG
there should be an adjustable air shroud around the burner tube
for safety sake and to ensure that what you suggest is the real problem and not a symptom, get in gas fitter to diagnose the fault
faulty power turns off a breaker
faulty gas explodes a house
Dec 13, 2017 | Wolf Range KFS-0-27-SCB-36 Gas Kitchen...
I have a garland oven model st286 it wont light even though there is gas getting to it and the spark is working. It lights if you light it manually
Instructions
  1. Access the burners inside your oven by removing the access panel in the front of the oven or by opening the broiling drawer, depending on your particular model.
  2. Determine if the pilot itself is lit, since some ovens have a small flame on the pilot at all times that then grows and extends to the burner when the oven is turned on. The lack of a pilot flame indicates the oven thermostat is malfunctioning or there is a problem with the gas hose. Check the pilot itself to see if it is clogged with debris or grease that could be preventing the flame from staying lit.
  3. Determine if the pilot flame will grow if it is lit by turning on the thermostat. If the pilot flame doesn't extend, the thermostat itself likely needs replacement. If the flame is extending but the gas valve is not opening, the safety valve could be dirty or defective. The flame should be blue in color. A yellow flame indicates the pilot is dirty and is not burning hot enough to get the main burner to ignite.
  4. Light the burner on the top of the oven with a match if the igniter doesn't appear to be effective. If it lights manually but will not light automatically, the igniter is likely faulty. Do not do this if there is a heavy smell of gas in the kitchen, since there could be a risk of a fire. In that circumstance, turn the oven off, ventilate the room and call a technician.
  5. Listen for any sounds of gas hissing or a clicking sound indicating the oven is trying to turn on. If there is no response from the oven at all, the gas may not be functioning properly and will need to be examined by a technician for safety purposes
Jan 26, 2011 | Ovens
Smell gas- does it have a pilot light?
I'm not sure about your question, if it is an ordinary ELECTRIC microwave oven you are not suppose to smell GAS although you could smell ION gas if the high voltage is leaking trough the insulator this means STOP USING IT and have it checked by a professional it could burst into flames... or it could be food leftover burning inside the chamber...
Jan 12, 2011 | Microwave Ovens
Burner flame shuts off during use and then you smell gas
all ovens, when they reach temperature they go off and on to kip the temperature, but if you smell gas the oven ignitor needs replacing, the ignitor gets red hot to ignite the burner ,but when ignitor does not get hot enough, it will have a delayed, that's the reason you smell gas.
Dec 10, 2008 | KitchenAid KGST307 Gas Kitchen Range
Smelling gas at when stove is in prelight then going away
Welcome tkrogers,
You said,smelling gas at when stove is in Pre-light then going away.
In some stoves this is normal as long as it is a slight smell and it goes away when the stove or oven ignites.
You know gas really has no smell, but this smell is added for our safety!!
What is the Make,year ,and Model number of your range?
The gas must start somewhere until the flame ignites it.
So we smell a slight smell of gas until it burns.
Thanks,
Huuum
Please remember to lave a solved rating before you leave.
Oct 11, 2008 | Frigidaire Kitchen Ranges
Gas Oven, lights and terrable smell, and flame shoot out
yea sounds like you have a stive set for natural gas hooked up to propane gasm you need to convert that thing instructions are simple to follow in installation manual, or if you paid someone for installation id get them back
Feb 28, 2008 | Kitchen Ranges
Jenn-Air JGR8850 Gas Kitchen Range Logo
Top Jenn-Air Kitchen Ranges Experts
Thomas F. Schneider
Paul Carew
Ismael Rodriguez...
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
