Question about Precor 956i Experience Series Treadmill (Used)
On my Precor 956 i the Stop Key prompt appears
    New Friend:
There is a micro switch under the red "Stop" button. The switch is stuck and needs to be replaced.
Posted on Dec 07, 2010
SOURCE:
How to change password on precore 9.35 treadmill?
Hello!
According to the manual (included in the link), there is no way to change the password on the Precore 9.35 Treadmill from its default setting.
If you would like to disable the password, follow these steps:
1. At the Precor banner screen, press STOP, SPEED?, SPEED?, ENTER, PROGRAMS very quickly
2. At the SELECT UNITS screen, press ENTER
3. Using the arrow keys, select DISABLED at the PASSWORD prompt
4. Press ENTER to accept these settings
https://www.precor.com/sites/precor.com/files/manuals/48854-103%2520933i_9.35i%2520Lit%2520Kit_1005_EN.pdf
Sep 18, 2017 | Exercise & Fitness
When push quick start button, why does it display Erro 30 and doesn't run?
Hi There....This is a great message for ALL PRECOR 956/966 owners. This failure usually relates to a "communications" error between the upper and lower electronics. This particular failure is a direct result of a failed IFT drive module, or the lower drive "box" that is made by Advanced Drive Technology. The brains of this lower controller has failed and cannot "talk" to the upper board anymore due to several failed parts inside this box. You are lucky to have this failure arise over a fatal blow-out. Now replacements thru Precor or a distributor will be $550+ and are usually low stock items at places, but you can get repairs and exchanges of this Precor IFT drive by emailing gregATbuyfitnessrepairpartsDOTcom for much less than all other vendors. Currently these IFT drives are 380 exchange and 199 repair and turnaround is one day. Good Luck!
Feb 11, 2016 | Precor 956i Experience Series Treadmill...
How to change precor932i lenguage
When start-up prompt "PRESS ENTER TO BEGIN OR PRESS QUICK
START" appears, access the Club Program by sequentially pressing
STOP, SPEED , SPEED , SPEED , RESET, SPEED , SPEED , and
SPEED . (Numbers on the display appear in sequence: 4, 5, 6, 5, 1, 5, 6,
and 5.)
Note: You must sequentially press each key within 4 seconds of each other
or the display reverts back to the start-up prompt.
6. Maximum Speed: Use any or key to designate a speed limit between
1 and 15 mph (1 and 24 kph). The speed you designate limits the speed of
the treadmill. Press ENTER when the desired speed appears.
7. Maximum Workout Time: Use any or key to designate a time limit
between 10 and 240 minutes. The amount of time you choose limits the
length of a person's workout. (This does not include the automatic 5-minute
cool-down period.) Press ENTER to accept the time limit.
Note: Continuous pressure on the arrow key lets you scroll through the
numbers being displayed.
8. Language: Use any or key if you want to change the language. You can
choose between English, German, Spanish, or French. When you change
the language, you affect all the prompts and informational messages that
appear on the display. Select the language being displayed by pressing
ENTER.
9. Custom Courses (C964i only): The course profile appears in the center
display. (If you want to customize course number 2, press ENTER.)
When you enter custom mode, you have the ability to "draw over" an existing
God bless you
Feb 22, 2013 | Precor 932i Treadmill
My precor c954i displays message STOP KEY and will not run? How come?
1) adjust the reed swithc, clean , and tigh the wire connectors very well
2) run the software calibration for diagnostic and troubleshooting.
God bless you
Jun 19, 2012 | Precor C954i Commercial Treadmill
Power keeps cutting out when clients are running on it.
When a running belt has excessive wear, it creates a lot of friction which causes the drive motor to work harder. When the drive motor works harder it will start overheating. If the belt is not lubricated periodically, it will ruin the deck, the drive motor, and cause other electrical problems such as tripping the breaker [after a while, the circuit breaker on the treadmill will need to be replaced.
It is suggested to lubricate the belt every month. At this point, you may need to replace both your deck and your running belt.
With your model and serial number, you can visit our website and view the products we have available for your particular machine.
Precor Parts for 952i 954 954i 956 956i Treadmills SPORTSMITH net
Apr 16, 2011 | Precor C956i Treadmills with HR /...
Error code 05 appeared on screen. We have tried to reset. Hit stop, enter, & quickstart buttons as decscribed. We also tried the reset button. The error code remains. We unplugged and tried again, but...
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Apr 11, 2011 | Precor 933 Premium Series Treadmill
Stop key sensor on
Call me 574 272-0509 I am a Precor teck
Apr 08, 2011 | Precor Exercise & Fitness
Precor 9.1 won't turn on, outlet is good. (When unplugged, switch is OK & stays in on position. Once plugged in, switch flips off and won't stay on.) Site wouldn't allow me to choose correct model -...
I'm guessing the internal fuse is blown, which is part of the safety feature when you pull the magnetic key off. You need to put the little magnetic key onto the "stop" area after each use, and it will re-set. If you take the key off "start" and the machine stops, you can't start again until you put the key on "stop". Once you do that, the main switch should work again.
Aug 21, 2010 | Precor 9.21 Treadmill
Key STuck Error
The key pad is not functioning properly thus this error is flashed you will need to replace key pad. Since I don't know where you are then the place to get the part is from precor directly the will ask Model & Serial #s
WORLD HEADQUARTERS20031 142nd Avenue NE
P.O. Box 7202
Woodinville, WA 98072-4002
T: 425-486-9292
T: 800-786-8404
www.precor.com
Jun 30, 2010 | Precor C954i Experience Treadmill
Intermittent ''error 27'' fault / PRECOR C 956 treadmill
You probably have a worn deck and running belt.
Apr 07, 2009 | Exercise & Fitness
Precor 956i Experience Series Treadmill (Used) Logo
1,153 people viewed this question
Top Precor Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Bill Boyd
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
