Question about Philips AJL700
Philips ajl 750 37 won't connect to comcast cable. I set it for each of the cable options it offered, but when searching it won't identify legit channels. My cheap old tv will identify the cable channels, so I know the line is good. What am I missing?
    New Friend:
Same problem for me
Posted on Jan 07, 2011
  • marciommss Jan 17, 2011
    same for me... I was trying to proceed a Manual Scan. This function is presented but not available. Did anyone solve that?
SOURCE:
Can't print wirelessly with Brother MFC 8690 DW
Let the machine grab an IP address from DHCP instead of a static and run the installation disk again. If you don't have the disk log into Brother Support site, enter your model number in the search box and download the software. It's a very user friendly site.Go for the full software package and off you. The installation wizard will ask you what way you want to install the machine wired ,wireless or usb. Once your pc and the machine are on the same network they will find each other.
Nov 16, 2017 | Brother Mfc-8690dw All-in-one Laser...
Undercounter 7''TV/radio AJL 750/37 Serial No GSlA1012001257
On the back of the TV there should be a cable connector. Follow the instructions included with the digital converter box.
Jul 25, 2010 | Philips Televison & Video
Can not connect with my home computer.Router and modem working,just won,t connect
Configure the Router 1. Step 1
Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
May 14, 2010 | HP Pavilion dv6000z PC Notebook
I get inconsistent results in using the auto channel search such that I can't synch the TV to the Comcast cable box. Any thoughts? This is a new Pyle 15 in. LCD TV TV/DVD.
use any other connections to your tv, not the one thru rf input.
i.e: audio/video, component,hdmi, etc.looks like there is a tuner issue, plus you'll get a better picture quality by using other options. if that' hd set, you will take advantage of this feature, if not, just improved picture and no hassle to screw in that "comcast's" thick RF cable in.
Good luck,
Alex's TV.
Feb 22, 2010 | Pyle 15 in. LCD TV/DVD Combo
I have a Philips DVDR 3575H. using Comcast's
Try this set up-
Use an RCA audio/video cable for this set up (Yellow/Red/White).
Connect from the Video out (Yellow) connection on the back of the cable box to the Video in on the back of the DVR.
Connect the audio (Red/White) cables from audio out connection on the back of the cable box to the "Audio in" on the back of the DVR.
This should still get you a decent picture but not a true HD picture for your recordings.
When you set the timer to record set it to record either E1 or E2 depending on which input you connected the cable box to and ensure that the cable box is tuned to the channel you wish to record.
*** NOTE: If you keep the HDMI cable connected as you have for the cable box and watch normal TV through the HDMI input on the TV you will get HD programming for your general viewing but still have the option to record with the DVR at a lower quality. ***
Good Luck and please rate this solution....
Jan 07, 2010 | Philips DVDR3575H/37
Dear Sirs, I purchased a 42'' DLP Vivitek from Shop NBC in 2006, we just moved and have Comcast Cable. They cannot program the remote as you are not listed with them at all. As I understand some how you...
most cable company remotes have a manual search option for tv codes usually a code listing book with the remote or on or under the remote battery cover see if you can manually search for the code that way however some tvs cannot be programmed to all cable company equipmet
May 13, 2009 | Vivitek Televison & Video
Closed captions go on and off sporadically
if the comcast box is not hd then the control is with your tv/remote.
If the comcast box is hd, then you can control it from the comcast remote. To do this press cable, then power and in 2 seconds press menu to get to the hidden hd setup menu, scroll down to closed captions and set it to enabled or disabled then press power twice to get back to you rtv
Nov 26, 2008 | Toshiba 42LX177 42 in. LCD HDTV
Magnavox 20" tv with vcr and dvd, Model #CT202MW8
call comcast they should know the correct code its there unit.
Jan 17, 2008 | Philips Magnavox 20MC4304 20 in....
HD compatibility - Not
You need to nail down where the problem is by finding another source of 1080i signal and prove if it is the TV or not, then hold Proton's feet to the fire if it is.
Dec 30, 2007 | Protron PLTV-32 Television
Philips 50 inch Plasma - no audio on occasion
Try swapping the HDMI cable. They occassionally fail.
Nov 21, 2007 | Philips 50PF9630A 50 in. Plasma Television
Philips AJL700 Logo
475 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
