Question about Acer TravelMate 4220AWLMi Notebook
Spilled red wine on right side of4220 laptop keyboard minimal amount made it on to the board .Have had it dried and cleaned etc but still dead In a nutshell BEST SOLUTION?
SOURCE:
  • 108 Answers
SOURCE: Sticky keyboard
You can carefully take off the keys and pop them back on. Use alcohol to wipe up any stickiness.
G'luck
Posted on Oct 24, 2008
  • 265 Answers
SOURCE: How do i clean a laptop keyboard
This is the keyboard you will need, Click Here
Click Here for the service manual to help you remove the keyboard.
Please Rate
Posted on Feb 17, 2009
  • 3 Answers
SOURCE: coke spilled on to the keyboard for my laptop.
Hi
The keyboard has to be taken to service centre, As the coke becomes gummy substance after dried up and the whole keyboard membrane track has to be cleand with isopropyl alcohol and the keyboard controller strip cable leads and connectors has to be cleaned with isopropyl alcohol or with any component leads cleaning solution
Posted on Mar 18, 2009
  • 73 Answers
SOURCE: Keys on the right side of the board are not working
i got to agree with micromend
Posted on Mar 25, 2009
  • 16 Answers
SOURCE: spilled pop on laptop now completely dead
YEP! Walk away from the laptop. You killed it! And it will be costly to fix!
Estimate that at least a keyboard, and probably a motherboard will have to be replaced. That is almost the whole computer. Better bet- buy a new Toshiba Toughbook - that is practically impervious to the spilled drink. But expensive!
Posted on Sep 22, 2009
Spilled coffee on keyboard now screen flickers
I wash once a laptop keyboard after someone spilled beer on it. Try to unmount keyboard and wash it with water and soap. It works for me. Let keyboard to naturally dry one day.
Jul 21, 2012 | Computers & Internet
Keybd keys are sticking
Be prepared to buy a new keyboard... Remove AC and DC power before working on laptop. Many laptop keyboards come off with the removal of 1 to 5 screws from the bottom. Some, however, require the palm rest to be removed, then a couple of screws that hold in the keyboard. Be careful when removing and replacing cables.After removing keyboard, rinse with water and let dry thoroughly before re-attaching and powering up. You cannot remove individual keys, so don't try.
Apr 12, 2010 | Fujitsu LifeBook S6510 Notebook
Spilled red wine on VAIO NR38Z laptop
Most likely, the fix will be a replacement palmrest and motherboard.
Sep 29, 2009 | Computers & Internet
Wine spilled on keyboard
You have to open up the laptop and remove the keyboard and dry it.
Also clean other parts properly where the wine has reached.
Sep 25, 2009 | Acer Aspire 7110-2069 Notebook
Spilled wine in keyboard
it really depends, on the logitech stuff they have the accidental spill holes in the bottom so liquid doesn't pool but there is a possibility that it could have saturated the board and ruinied the internals, just try to dry it out as best you can and hope for the best
Apr 18, 2009 | Logitech Cordless Desktop EX110
I spilled a glass on wine on keyboard. now get blank screen yet, all the power lights and sound is still on.
You May Have Shorted Out The Video Card Which Is Usually Located under the keyboard you can get a replacement through Tiger Direct...
Apr 03, 2009 | HP Pavilion dv6000z Notebook
Very short freezes constantly
There was more damage than just the keyboard, your fault appears intermitten and possibly some connectors and sockets are not making good electrical contact. You need to dismantle the laptop completely to inspect and clean what ever you can with distilled water and let it dry throughly. It still may not work because there may be some electrical damage to some chips and components, especially if the laptop was running at the time of the wine spill.
There is not much help I can offer you except to advise you to buy another laptop, and if the hard drive in the old laptop is OK then buy a USB hard drive case and insert the laptop hard drive in this case and use it as an external USB hard drive. You need to delete all the old system files etc. to maxmise the hard disk space.
Dec 04, 2008 | HP Pavilion dv9000z Notebook
Spilled Grape Juice
To give it a good cleaning, you will need to remove the keyboard and clean anywhere you can see juice or feel stickiness. You can buy the expensive computer cleaners, but I suggest 50/50 rubbing alcohol and Q-tips. Remove the battery and C-mos battery to make sure there is absolutely no power to the machine what so ever. After cleaning inside, you will want to give it a good 24 hours to dry, ensure that there is no moisture before applying power. If the juice reached the bottom of the machine, you may need to remove the screen, split the cases, and take the motherboard out, in order to clean the bottom side of the board. If you leave juice anywhere on the board it will gum up, and the acids in the juice will corrode and detierate the circuitry on the board causing a motherboard failure. Now the keyboard, in order to thoroughly clean the keyboard, I suggest that you spray a good amount of the rubbing alcohol in the keyboard, shake it or blow it out with air, then take paper towels and daub up the rest. Repeat this two or three times, then let it dry approx 24 hours. Sometimes the keyboard won't recover after a spill and will need replaced. If it works properly, then, after using the keyboard for a while, you will notice if any of the keys are sticking. Take the sticky key or keys off and clean them individually. I know it's alot of work, but it'll teach you not to keep open drinks around your laptop. It did me, I've ruined one machine, two keyboards, and thoroughly cleaned a third very expensive machine of mine to keep it working, but I finally learned to drink from a sippy around my laptops.
Jul 21, 2008 | Dell Inspiron E1505 Notebook
Acer TravelMate 4220AWLMi Notebook Logo
157 people viewed this question
Ekse
Alun Cox
