Question about Garmin Forerunner 405 010-00658-20
It does not hold charge. It goes blank as soon as charger is removed.
  • cmcaceres Oct 25, 2010
    It does not hold charge, it fades and goes blank as soon as charger is removed. If I have to replace the battery please let me now how do I do it.
    It´s Garmin Forerunner 405.
    President:
  • 2,777 Answers
I see, it sounds like the battery has failed in the device, which is pretty common on Garmin units, I have personally had a few that have had batteries just go out on them. It shows in your question that you are asking about a Garmin Forerunner 405, I can't imagine that is correct, is it? It's probably a GPS system you are referring to? If so, what is the model number of the system?
Let me know, just reply here and I can tell you how to fix it.
Thanks
Tim
Posted on Oct 25, 2010
  • Tim Grayson
    Tim Grayson Oct 25, 2010
    Ok in that case, you will need one of these batteries here, may as well buy the two pack just in case you need to ever do it again, and it's only $2.80 with free shipping:
    http://www.amazon.com/gp/product/B0002DS...
    Plus you will need a jeweler's style Philips head and flat head screw driver, you can buy this set here that has everything for $4.40 with free shipping:
    http://www.amazon.com/gp/product/B000X1G...
    Then follow these steps:
    1. Remove the 4 screws holding on watch back plate
    2. Remove the metal back plate
    3. Carefully peel the white sticker off the back of the battery,
      paying attention to the orientation of the sticker. Along with a small
      strap, this sticker helps hold the battery in place.
    4. Place the watch face down and familiarize yourself with the
      parts. The battery is held on by a metal strap. At one end of the strap
      is a small brass spring. Position the watch so that the spring is
      sitting towards you at the bottom left.
    5. Insert a small jewelers flat head screwdriver behind the top
      clip and pry gently to release it. The clip and the clear plastic
      backing should slide off.
    6. Place the plastic backing, with the clip still on top of it
      on the table, keep it oriented in the same position it was on the watch
    7. Replace the battery and lay the clear plastic backing and clip on top of it.
    8. Hook the bottom left of the clip on the battery and press the
      top right clip back down to hold the new battery in place. Be careful
      not to move or cover the brass spring. There is only one right way to
      position the plastic backing so that the spring is not covered.
    9. Replace the white sticker over the clip. Do not cover the brass spring.
    10. Place the back onto the watch and screw the top right and bottom left screws in place.
    11. Turn the watch over and verify that the View, Mode,
      Start/Stop and Lap Reset buttons are all working properly. If they are
      not, remove the watch back and verify that you have the clip and plastic
      backing placed correctly
    12. Put in the last two screws
    Thanks much! Let me know if you have more questions.
    Tim
  • 2,973 Answers
The battery is dead. Please replace it.
  • Rinoo Kumari Oct 25, 2010
    To replace the batter you must put it upside down and remove the back cover. Underneath you will find the battery. Remove it and replace it with an exactly the same one. You will have to take it to the store to get another of the same specifications.
SOURCE:
My phones are going blank on screen after I dial out or while dialing.
While the screen goes blank, does it drop the call? Are the handsets fully charged, or are they on the charging dock whenever they are not in use?
The batteries may need to be replaced. Bad batteries can in some cases cause the phone features to not fully work. They are located in the back, bottom of the handset.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mike_005777b2fc6bfc30
Nov 21, 2014 | Uniden DECT15803 3 handsets and Chargers -...
Pioneer r1 tablet won't hold charge
My Pioneer R1 Tablet ALSO will not Charge only works when plugged in if i unplug it goes off! Charging stays at 0%.
Mar 19, 2014 | Tablets & eReaders
My kobo wont turn on
Try this, it worked for me
Turn off phone
Remove battery
Wait 10 seconds
Plug in charger
Insert battery
Turn on phone
Dec 12, 2017 | iPhone Apps
The power on the Panasonic Palmcorder IQ PV-A206 turns itself off. I've tried plugging directly and with a fully charged battery, no luck.
please make this test and fix it. God bless you
If the video camera doesn't work, make sure the battery is charged (see The Battery Recharger Fix-It Guide) or replace a battery that won't hold a charge. Make sure the AC adapter is connected properly. Clean any dirty contacts on the battery, charger, and AC adapter with a cotton swab dipped in denatured alcohol. Remove corrosion with a clean pencil eraser, then wipe the area with an artist's brush to remove any debris. Find and test the fuse, if any.
If the power goes off soon after starting, recharge a low battery. Also, turn the video camera power off, then turn it back on and eject the tape. If the problem persists, check the fuse
If the battery won't charge, clean the contacts and fully discharge the battery, then recharge it. If the problem persists, replace the battery
If the video camera works intermittently, remove and reseat the to establish good contact. If necessary replace the fuse
Nov 08, 2013 | Sharp Panasonic Palmcorder Iq Model...
Audio sonic portable dvd player
the inbuilt battery is not holding charge needs replacement , the charger needs to be replaced to with the original one
Jul 12, 2013 | Televison & Video
How to turn the console on
one the QD model it is on the right side near the top. It is thru the rubber so you have to press hard.
Jan 07, 2010 | Nokia Video Game Consoles & Games
Screen goes blank 2 seconds after powering up and then wont work
contact your service provider for a repacement phone if you have warranty or phone insurance. its and internal problem.
Apr 26, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Garmin Forerunner 405 010-00658-20 Logo
726 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
