How do I turn off the Adaptive Intelligent Recovery feature in a Honeywell TH8110U1003 thermostat?
SOURCE:
SOURCE: How do I change the
Try adjusting the heat range up. Set it a 77 then try the cool.
I believe the Honeywells have a max range between cool and heat.
also sometimes there is a lock out code on them you'll need the book.
Good luck
Posted on May 20, 2008
  • 124 Answers
SOURCE: My furnace cycles too often.
recovery has nothing to do with on off on off. you have a new digital stat that holds an exact to the degree temp a change of a half a degree can bring it on.. so stat needs to be above main return 5 feet off floor. away from any drafts , doors supplys etc. also be sure the hole in the wall is sealed . the cold air in the wall is more than enough to make stat come on . they are incredibly sensitive.an old mercury bulb stat would have a swin g of 3 or 4 degrees . so set at 75 it may heat up to 78 and stay off till temp fell to 73 so you get a longer run cycle or and longer off cycle. the new ones are on off on off keeping a perfect temp 75 exactly. thory is the heat exchanger is already hot and a quick short cycle is more efficient than being off 20 minutes and reheating the heatexchanger from scratch again. having said that if you look aT the installer set up instructions that came with the stat it may give you an option to reset or adjust the stat so it will have a one (default) two, or three degree adjustment , so 75 equals up or down three degrees on call for heat.see honeywell toll free number in their literature
Posted on Oct 24, 2008
  • 700 Answers
SOURCE: How to program Honeywell thermostat for remote sensor
Remote Sensor (Setup Function 0340): If an optional outdoor sensor is installed, the thermostat can display the outside temperature. If an optional remote indoor sensor is installed, the thermostat will display the temperature at the sensor location (the internal sensor in the thermostat is not used).
\ 0 No remote sensor
1 Outdoor sensor (display only)
2 Outdoor control sensor (select heat pumps
Posted on Dec 31, 2008
  • 12 Answers
SOURCE: Can anyone tell me if the Honeywell RTH7600B OR
no circ fan on those two models. That is the difference between retail and the Trade models.
Posted on Jul 23, 2009
SOURCE: Honeywell T2060 UtilityPro Demand Control Thermostat
The user manuals don't show all the codes that the thermostat has....
If you can find an installer manual for this thermostat, or a similar one, it will provide the installer-only codes. Search for 69-1894ES.pdf - I think you want code 0530, and set it to 0. You access the installer codes by pressing two buttons - the ones each side of the centre button that you press for the user codes
Posted on Dec 04, 2010
Heat pump with Honeywell T6 Pro thermostat. It's programmed for 69 during day and 65 at night. But the Adaptive Intelligent Recovery causes the house to heat up about 90 minutes too early. Options
For the T6 Pro model, I found the installation manual; search for 33-00181.pdf. I pressed Menu and + for 3 seconds to get into Advanced Mode; then Select to enter ISU ("Installer Setup"); then Select several times to get to option 425 (Adaptive Intelligent Recovery). I then pressed "-" to make the setting zero (OFF); then pressed HOME to save the setting.
Dec 08, 2017 | Honeywell Heating & Cooling
I want to turn off the adaptive intelligent recovery feature on my TH8000 Series programmable Honeywell thermostat. How do I do that?
You only need to turn it off if you are using program mode. Very nice stat btw. Heres a link to the pdf and I will also explain. http://customer.honeywell.com/techlit/pdf/PackedLit/69-1896EF.pdf Use the system select button so that the heat option is flashing. Look at the bottom of the screen and you will see 7 boxes. First one done and seventh one cancel with all boxes in between blank. Now at the same time hold the 3rd and 5th box (buttons) for approx 5 sec. A new screen will appear with a number sytem staring at 0120 with up or down arrows and 20 with up or down arrows. Push the left up arrow till the left number reads 0530. The right number will read 1 if its on. To turn it off select the down arrow so it reads 0. Then select done and your all set.
Feb 26, 2011 | Honeywell Programmable Thermostat Heater
How do you reset a honeywell th8110u1003 thermostat honeywell 800 # will not tell me but he said it needed to be reset because off ee code on screen
http://www.pexsupply.com/Honeywell-TH8110U1003-VisionPro-Thermostat-1-Heat-1-Cool-3909000-p YOU MAY FIND THE ANSWER HERE BUT IF NOT YOU CAN FIND IT RESET BUTTON IN THE (FURNACE?) UNIT. THE REASON HONEYWELL WILL NOT GIVE THE INFORMATION IS BECAUSE THIS CONDITION USUALLY MEANS THERE IS A PROBLEM IN THE SYSTEM AND GAS IS NOTHING TO FOOL AROUND WITH. FYI HAVE YOUR IGNITER CHECKED OUT.
Mar 05, 2010 | Honeywell Programmable Thermostat Heater
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Feb 16, 2010 | Honeywell Electronic Programmable...
Chronotherm Three thermostat vs Buderus Logamatic Computer.
The outdoor thermostat senses the the temp of the outside air, and adjust the boiler water temp according to what it knows is best. The reason that the boiler is running longer is the old boiler used to be constantly sending 180ish degree water to the baseboard, now that water may only be 140ish degrees. The idea behind this is to reduce off cycle heat loss, as the greater the temp difference between the air temp and water temp, the quicker you loss heat. The theory in boiler run time is this, the less times it starts and stops, and the long run times will give you the best efficiency. Hope this answers you questions.
Sep 28, 2009 | Honeywell Power Humidifier: Furnace...
Heater comes on at 5:10 am prior to the programmed setting
Access the installer setup menu (You will need the installation manual from the t'stat to do this) and turn off the "intelligent recovery" feature. This feature turns the equipment on in order to bring the conditioned area up to temp at the set time. Or you could set the "wake time" to 6:50!!!
Dec 15, 2008 | Honeywell Programmable Thermostat Heater
Non-deletable schedule in VisionPRO TH8000
The thermostat has a function called "Adaptive Intelligent Recovery".
This feature allows the thermostat to learn how long the furnace and air conditioner take to reach programmed temperature settings, so the temperature is reached at the time you set. For example: Set the Wake time to 6 am, and the temperature to 70°. The heat will come on before 6 am, so the temperature is 70° by the time you wake at 6.
You can turn off this function. Download the installation guide at the next link:
http://customer.honeywell.com/honeywell/ProductInfo.aspx/TH8321U1006
and look for funcion number 0530 Adaptive Intelligent Recovery. In this manual you also find the way to do a reset with the function number 0710.
I hope this solves your problem.
Nov 19, 2008 | Honeywell Programmable Thermostat Heater
Adptive intelligent recovery
On the Pro4000 model you hold the 2 arrows until you go into setup mode. Then arrow up ONLY til you get to option 13. The display will read 13 and 1, press the DOWN arrow and it will read 13 and 0. This turns off Adaptive Intelligent recovery. Now hold the 2 arrows til you see the normal display screen. You are done.
I just did this with a Honeywell tech rep on the phone.
Nov 15, 2007 | Honeywell Programmable Thermostat Heater
Honeywell deluxe programmable thermostat 69-1402m
Solution #2 as above worked (thank you very much!) to get to the programming mode, but on mine keeping Function #13 on the default setting of "0" maintained the AIR.  Toggling the Temp button to "1" changed the system to conventional on/off at the programmed times.
Oct 16, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
285 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
