In Copernic Agent Pro v. 6 i get all the files I believe except Document Manager which is reported "Missing." I have code numbers etc, but no use. Any ideas where Document manager is hiding? Thanks, Mike.
  • mmcgarry120 Oct 24, 2010
    Yes, but in the end I seacthed through a bunch of CDs and found my original ,exe v. 6.12 file, set it up and away we went!!!
    Thanks for your prompt to search back a bit.
    Cheers, Mike.
  • mmcgarry120 Oct 25, 2010
    Hi Ninal, thanks for the comments, and I'll likely give Tune-Up a try, though I do have some speedups since I'm still using XP.
    I've been using computers or their earlier equivalents since the 1970s but am still nowhere a geek.
    Thanks agaion for your tip to look back. Mike.
    President:
  • 3,278 Answers
Hello, Mike.
I'd suggest to go to Add/Remove Programs, remove Copernic Agent Pro, restart your computer and reinstall.
If problem just occurred with Copernic Agent Pro, the program worked previously and reinstall doesn't solve your problem, then I'd suggest System Restore. Boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
Hope this helps.
Posted on Oct 24, 2010
  • NinaE Oct 25, 2010
    You are welcome. Thanks for using FixYa.
SOURCE:
I DONT KNOW HOW TO PROGRAM MY CONTROL REMOTE
Download the free "Copernic Agent Personal" search program ans set it up. Then in very precise words type in the search engine block what is you are in need of. I believe you need the code and instructions for programming your specific remote.
I find the Copernic search engine to be a fantastic tool for finding information on the web.
Aug 16, 2011 | Panasonic PV-7400 VHS VCR
How to print auditron report (copy) from workcentre pro 128? Need step by step instructions- have no manual
Printing Service Reports
1. To access Service reports, follow the Entering UI Diagnostics procedure.
2. After entering the Access Number, press the Machine Status button on the Control
Panel.
3. Select the Billing Meter/Print Reports tab on the display.
4. Press the Print Reports/List button.
5. Press the CE button.
6. The following reports can be printed.
• Debug Log Report
• HFSI Report
• Jam Report
• Shutdown Report
• Failure Report
• Protocol Monitor Report
7. Select the required report and press the Start button. The selected report will be printed.
Jun 11, 2010 | Xerox WorkCentre Pro 123/128 Printer
Missing text and top of some text is missing
* Perform Step 2 in the following HP web link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01446637&cc=uk&lc=en&dlc=en&product=3643612
If the issue persists, please print a self test page from the unit and verify whether the unit prints the test apge fine. Step are given below:
  1. Load U.S. Letter, A4, or legal size paper into the input tray.
  2. Press the Setup button.
  3. Press 1 to select Print Report , and then press 1 to select Self-Test Report .
  4. Press OK . The self-test page prints.
:) Dr Tony
Apr 20, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Can't Get wireless to work
first: - goto the PC website and download the wireless driver
http://www.gd-itronix.com/index.cfm?page=Drivers:Selection&locale=en_US under XP it has this device GIGAWLAN V.5.2.0.117.07
HOW TO USE:
1. Download the .EXE file to a directory on your hard drive.
2. Execute the downloaded file, and follow the instructions.
3. After the files are unpacked, the folder containing the extracted setup files should open automatically. The setup program (utility\setup.exe) is located in the "utility" directory and must be run to install the software
I would remove the wireless adapter from the device manager - right click and uninstall Now reboot the PC - it will detect new hardware, and start to install the wireless adapter, it should now automatically find the driver from. if not when asked browse to the extraction files
Hopefully the switch and light will now work - and wireless will be enabled
Feb 18, 2010 | General Dynamics Itronix GoBook Notebook
How do i open a document which is saved on my desktop into Document Manager viewer. when i click the file am able to go to Document Manager Client.
If you go to the Document Manager client when you click the file, it sounds like the file is a .gml, which is a DM document link.
If it was e.g. a Word-file, it would've been opened just like Windows normally handles that filetype.
But, if you want to open document directly from viewer, launch the viewer from the DM program folder, e.g. C:\program files\ibm\db2 document manager\dmviewer.exe
Oct 14, 2009 | IBM DB2 Document Manager
Seagate Free Agent Go Problem
Install the seagate manager on a different computer and decrypt the files there first then move it back to your computer using the basic copy/cut and paste.
May 27, 2009 | Seagate FreeAgent Pro 500GB External USB...
Code 39 on DVD Philips SDVD8821
Download the latest driver from Acer site or phillips site.
Uninstall the device driver.
Reboot
Windows should detect new hardware and start the wizard. Point to your drver installation file and install the driver.
Reboot. this should fix the problem.
Apr 26, 2009 | Acer TravelMate 4220AWLMi Notebook
Help for Seagate Free Agent 500 GB external hard drive
465.66 x 1024 x 1024 x 1024 = 499,998,617,764 bytes. The problem is the definition of gigabytes.
May 10, 2008 | Seagate Free Agent Go Small 12 GB USB...
Open Questions:
Computers & Internet Logo
67 people viewed this question
Ekse
Marvin
Marvin
