Question about Roper Dryers
Trying to put belt back on dryer have know diagram
I got the belt around the big tub but can't get this thing that has a little wheel on it , it tightings the belt
  • 525 Answers
Follow the link to the belt diagram page and it will show you how to route the drum belt for your particular dryer.
http://www.repairclinic.com/0079.asp#DiagramK
Posted on Jun 08, 2008
I have an older kenmore 70 series dryer. the belt broke and im trying to figure out where the pulley is supposed to go and how the belt is supposed to go
If you are referring to the tension pulley that keeps the belt tight on the drum, it is common for it to come loose when the belt breaks because there is no longer any tension holding it in place. Just follow these steps to reinstall:
1. Make sure the drive belt is looped around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place with your left hand, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H.
If you have any questions, please post back with your MODEL NUMBER (located on a nameplate around the dryer door opening) so that I may be able to confirm your dryer configuration. I hope this helps you.
Feb 24, 2010 | Kenmore Dryers
I have a Maytag DE50 dryer and the drum belt broke. Anyone have a diagram or instructions on how to put the new belt on?
Ignore gas references if electric dryer.
Unplug dryer and shut off gas. Disconnect gas line. Tip dryer onto its front. Remove back panel. Unscrew and remove inside back manifold. Place belt around drum and fit into pulley wheel(s) on motor shaft. (There may be a spring loaded tension arm on one of the wheels. Install the belt on it so that it pulls the belt tight around the drum and pulleys.) Check friction gasket (that the drum rotates on) on manifold and replace it if worn thin. Install manifold. Install back panel. Reconnect power and gas.
Aug 11, 2009 | Dryers
Can't Put Belt On
You have to remove the front of the dryer to
access the drum. First unplug the dryer.There are screws at the bottom of the front to remove the lower section. Once you remove that you can get to the screws for the door section. The front of the drum rides on the inside of the front panel so when you remove the panel the drum will drop down. Try to keep the drum in place with something to hold it up. Remove the old belt and place the new belt around the drum. Slid the belt back to where the belt used to ride and then loop the belt around the motor and the tension wheel. Make sure the tension wheel is tightening the belt. Hold up the drum and put the front panel back on. You may need a helper to hold things while you do this. Rotate the drum by hand and make sure it moves smoothly. Plug it back in and give it a try. I hope this helps. Any questions feel free to ask. Please rate me so I know if I'm Helping. Thanks.
Dec 30, 2008 | Frigidaire FEQ1442ES Electric Dryer
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Putting dryer back together
from front with belt around drum ..gather slack and push under idler and around motor pulley right to left...recommend doing it before reinstalling front place rollers on front panel under front lip of drum and lift ..easier than trying to reach under front panel and will a little more slck in belt
Sep 13, 2008 | Kenmore 63012 Electric Dryer
Replacing dryer belt
  • Just like this but imagine the roller as being a semicircle.
put pressure on the tensioner with the belt and loop the belt under the tensioner to the motor.
  • this is a diagram for a whirlpool/kenmore/roper/estate dryer, i don't know the brand of dryer you have.
look here is more diagrams of different brands. http://www.repairclinic.com/0079.asp
let me know if you need more help Mike
Jul 04, 2008 | Dryers
Dryers Logo
114 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
