Question about Jenn-Air Refrigerators
The refrigerator doesn't get cold. The condenser ices up. When I thaw it, it begins cooling again, but only for a few days at a time. What causes this and what do I do about it? Thanks, R. Scoggins
  • rollinalong Oct 25, 2010
    The refrigerator is Jenn Air model # jsd2789ae. Can I get a diagram showing the location of the parts you mention?
  • 2,299 Answers
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Posted on Oct 25, 2010
  • 1,891 Answers
This is caused by the defrost system not doing it job .. there is a timer in some models and aditive defrost control in newer models . it knows when to defrost the frig . if it does not defrost properly the cold coil gets blocked with ice and stops the cooling . if the control ic not bad then the heaters may have failed and there is a defrost terminator that may also bee at fault . most common would be the heater / then terminator / & then the A D C. .. . hope this helped mm..
SOURCE:
How can I defrost my Kitchenaid Superba Freezer without unplugging the entire unit?
the air from the freezer is what cools the fridge so no way to separate the cooling process for defrost
Apr 24, 2017 | KitchenAid Superba KSRS27CN Side by Side...
Why is my brisk air duo therm rv ac freezing up on the inside.
Where you see frost all the time, wait for unit to thaw and start cooling again and carefully slide hand up in that hole and see if you can feel cool air leaking in from divider that separates cool and return air, that will cause freeze-ups as well. Use foil tape if necessary to stop any cool air coming in to return air from around divider. Also, if you have any diffusers closed, (on ducted system in ceiling) or partially closed, open them all up full flow. If you restrict the cold air from coming out too much, it can also cause freeze up. One more thing, take cover off where cool air box is and double check that something isn't restricting the flow of cold in to the duct work if it has ducted system.
Jul 12, 2014 | Dometic Rooftop RV Air Conditioner
Have an Amana fridge, 22.6 cu ft, 12 years old, side-by-side, water/ice on door. Freezer quit working over a 3 day period. All the food thawed. Not sure if the fridge part is getting warmer also -- not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 20, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Maytag Model MBB2254GEW, bottom freezer: intermittently freezes and do not always feel cool air coming through the fridge. This is on and off for the last few months, where we find ice cubes all melted...
heatman101
May 24, 2011 | Maytag 21.9 Cu. Ft. Bottom-Mount...
I have a Kenmore Coldspot Side by Side that is about 13 years old. It appears to work for about 12 hours or so and then both sides quit working and then the cycle begins again. The ice will all melt...
Hi, from my experience dealing with repairs of refrigerators and freezes, it is a fact that you likely have a bad condenser coil, condenser fan or condenser motor whenever your refigerator switches itself off and put it self on again. So you have to check one after the other to ascertain the faulty part and replace it...
May 15, 2011 | Kenmore Side by Side Refrigerator
Open Questions:
Refrigerators Logo
633 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
