Question about HP Pavilion a705w PC Desktop
Hp media center pc M470n won't turn on after electricity went off. No lights No sounds. I used surge protector. LED on back of the pc is not on. Any ideas?
  • HP Master
  • 7,733 Answers
To start with some try to change the CMOS battery that is inside the PC and is look like a dime.
Post back!
Posted on Oct 25, 2010
SOURCE:
Sony KDL 46HX820 turns on, then off and red light blinks four times.
Re: Bravia KDL46EX720. Red LED blinks 4 times and TV wont turn on. What is the problem?
Do a Power Reset.
1. Turn off the TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If the issue still persists after performing power reset, that may be an indication that the TV needs service. You may refer to this link to locate the nearest Sony authorized service center in your area.
Oct 21, 2014 | Sony KDL-46HX820 - 46" BRAVIA 1080p LED...
I have a HP Compaq Presario Media Center computer, it is plugged to a surge protector, the other night the electricity went out and my computer was turned on, and now I cannot get it to turn on at all, the...
try removing all power cables of your computer that are connected to the surge protector. reset the surge protector. wait for about 5 minuets before you turn on the surge protector. then plug all cables that your remove from your computer the turn on the computer.
Jun 03, 2010 | HP Compaq Presario Media Center SR1750NX...
If I open and close the printer it starts as if it is doing printer prepeartation, but nothing comes on. The screen will not turn on.
  • SOLUTION 1 If the HP All-in-One is turned off, press the On button to turn the unit on.
  • Unplug the power cord from the back of the HP All-in-One.
  • Wait 15 seconds.
  • Plug the power cord back into the HP All-in-One.
  • Turn on the HP All-in-One by pressing the On button.SOLUTION 2: Reset the power module and test the power Step one: Reset the power moduleThe power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
    1. Unplug the power supply from the rear of the product.
    2. Unplug the power cord from the electrical outlet, power strip, or surge protector.
    3. If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
    4. Wait 15 seconds.
    5. Reconnect the power cord to the power module.
    6. Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
    7. Check to see if the power module has an LED.
      • If the power module does not have an LED, continue to the next step.
      • If the power module has an LED, check to see if the LED lights up.
        • If the LED does not light up, contact HP to replace the power module. To buy a compatible power module, right-click the following link, How to Buy HP , and then click Open in New Window .
        • If the LED lights up, continue to the next step.
    Step two: Test the power on the All-in-OneFollow these steps to test the power on the product.
    1. Reconnect the power supply to the rear of the product.
    2. Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold the button down.
  • Apr 07, 2010 | HP Photosmart C6180 All-In-One InkJet...
    I have a sony bravia 60'' projection tv kds-60a3000. the problem is after a couple of minutes i will get no sound or picture. i disconnected the plug from my power strip for 5 minutes to cool down, then...
    The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
    If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
    1. Turn off the television. Unplug the television power cord from the electrical outlet.
    2. Let the television remain without power for 60 seconds.
    3. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
    4. Turn on the television.
    Sep 22, 2009 | Sony Televison & Video
    Computer will not boot up after i disconnect power
    If the component with the blinking green light is on your network card, it has nothing to do with your problem, but does demonstrate that *********** board is NOT fried or there would be no voltage available to make the light blink.
    Something on your board may be fried, but not the entire board.
    Unit needs board level service, so obtain an RMA, if available and submit the unit for bench testing and service.
    Mar 29, 2009 | HP Media Center m1195c (PJ475AA) PC...
    Hp media center pc won't turn on after electriticy went off & came back up & use surge protecter. LED on back of pc comes on & then off very quickly when power cable is plugged. any ideas?
    Unplug the power cord and hold the power button in until the light on the front comes on and fades out,The plug the power cord back in and start as normal.
    Mar 13, 2009 | HP Pavilion a705w PC Desktop
    Computer power won't turn on
    First thing to do is try to plug the pc in another wall socket to see if it goes on, If not, the MB could have gotten fried, even though the other plugs seem to work. Hopfully you just need another surge protector as that could have gotten damaged.
    Jul 20, 2008 | Computers & Internet
    Power outage, now pc will not power up at all.
    sounds like the surge protector didn't protect. I would change the power supply.
    Jun 12, 2008 | HP Media Center m7060n PC Desktop
    OK FIRST A POWER SURGE PROTECTOR WILL ONLY PROTECT YOU 7 % OF THE TIME, WHICH YOU JUST REALIZED. SO YOU NEED TO BUY A BATTERY BACKUP ALSO KNOWN AS A UPS.... I CANNOT STRESS THIS ENOUGH. BRING YOUR PC TO BEST BUY AND THEY WILL TEST YOUR POWER SUPPLY, IF IT TESTS OUT OK THEN YOU BLEW SOMETHING IN YOUR MOTHERBOARD. GET A BATTERY BACKUPS/UPS!!!!!!!!!!!!!!!
    HP Pavilion a705w PC Desktop Logo
    170 people viewed this question
    Top HP Computers & Internet Experts
    Ekse
    Thomas F. Schneider
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
