Question about Mtd 46" Dozer Blade, Fits All & Yard - Man Lawn & Garden
When removing tire from MTD GOLD riding lawnmower I broke the nut off holding it on. Tried an Easy out to remove old nut, but that also broke off inside old nut. have tried to redrill but have gone through 5 bits and still not made any head way. Any ideas Thanks
  • 3,074 Answers
I would take a cutting torch then re-thread it, might have to go a little bigger once it is all said and done. Good Luck Tim
Posted on Oct 24, 2010
SOURCE:
When taking off the blade for replacement one side of the attachment assembly broke off. i can't figure which nuts/bolts to loosen to remove that part for replacement
The spindle assembly is usually held in place by bolts through the mower deck. The deck will need to be removed from the mower to get to them. There will be three or four of them at the base of the spindle assembly, remove these and the spindle will fall out the bottom
May 15, 2016 | Mtd Garden
Greenfiled ride mower 13hp
the mesh cover should have screws in it or the center cup holds it in place. youll have to remove center nut or bolt to get flywheel off
May 26, 2014 | Mtd Garden
Need to know how to change blades on 42in zoom z turn
To make it easy for repair, jack up lawn mower from the front, use jack stands to support the front frame, if you have a engine puller handy you can hook a chain to the front frame. There should be a 5/8 or 9/16 bolt or nut on lawnmower blade, need a impact driver to remove, do not remove with a wrench or hand tools or you risk of breaking the mandrels. Be sure to check the splines that hold the blade on place for ware and when installing them be sure you have a snug fit and hold the blade in the slot and insert nut or bolt back in place, if the blade is not in the slot you can strip the shaft and it will have to be replaced. It is good to put anti seize on the bolt or nut threads to make it easier to remove and install.
May 19, 2014 | Ariens Zoom 42 In 165 HP Briggs Stratton...
My MTD riding lawnmower is burning thru the new belts I just purchased.The new belts are 954-0371A which replaces 754-0371A. The old style belt lasted 5 years. Even before engaging the clutch, the belt...
My idea is not about the belts, but is about the deck. If the tensioning mechanism on the deck is getting stuck in an intermittant position than the belt may be just tight enough to turn blades while slipping through the pulleys, this may cause enough friction to start melting your belts. If this is the case you will have to remove your mower deck and see what is preventing the mechanism from functioning properly.
Jul 07, 2011 | MTD LAWN MOWER PART 1909404 BELT
My riding lawnmower by Yard Machine, Starts, Blade Engages, however will neither move forward nor at rear
Hi there. It sounds to me like you have a worn drive belt. Go to http://www.mtdproducts.com/webapp/wcs/stores/servlet/OwnersCenterView?storeId=10500&catalogId=20500&langId=-1 enter your model numbers in the center field and download your manual. It will show how to remove and re-fit a new belt. Take the old belt with you when purchasing the new one. Hope this helps
May 30, 2011 | Yard Machines MTD Gold 20 HP Lawn Tractor...
John Deere Gator HPX 12 Volt Ride on Toy by: Can anyone tell me how to get the tires off of a j...
1. Remove the center caps from the rear wheels
2. use a 13mm wrench on each side and loosen the bolts
3. remove the rear wheels
May 18, 2010 | Peg Perego John Deere Gator HPX Ride on...
Yard Machines by MTD..Riding lawnmower starter draws energy from battery but doesn't turn. Never replaced a starter. Don't know for sure where it is and what's involved.
ITS NOT HARD UN HOOK THE BATT CABLE THEN RE MOVE THE CABEL FROM THE STARTER REMOVE THE 2 BOLTS THAT HOLD IT ON PUT THE NEW ONE ON HOOK UP THE CABELS AND TRY IT LET ME KNOW IF THIS HELPS
Oct 07, 2009 | Garden
Need to remove rear wheels to replace tires on MTD riding mower.
most likely rust has taken over
find some liquid wrench or pb blaster and spray the axles liberally and let it penetrate the axles and wheel hubs where the axle goes through.
use a 2x4 and a hammer to tap against the wheel hub to try to move it down the axle then tap in back on to try to free it up as the penetrating oil works in, spin the wheel and tap in different areas of it
the worst case cenario would be to use a torch and heat the axle and hub up and drive it off, but it sounds as though you are moving it some and with some patience they eventually should come off
when you put them back be sure to coat the axle with some grease and do not forget to reinstall the key stock in each wheel, if they have it
the bolt in the center of the axle is all you need to remove and note where the washers came from and where they go back.
hope this helps you some
Jun 14, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
MTD Riding Lawnmower
Sounds like the axle slipped out of the differential. There is usually a snap ring on the axle which holds it in place. This could have broken, came loose, etc,
Major surgery needed.
May 09, 2009 | Mtd Garden
Mtd 46" Dozer Blade, Fits All  & Yard - Man Lawn & Garden Logo
126 people viewed this question
Top Mtd Garden Experts
lnbn1975
dannydoesita
Joseph Mueller
Joseph Mueller
Are you a Mtd Garden Expert? Answer questions, earn points and help others
