Question about Dewalt 7,000 Watt 13 Hp Portable Generator With Electric Start #DG7000E
My DeWalt dg7000 generator shuts down after running 5-10 minutes. The gas flow is ok and oil level is ok. Can you help?
  • Dewalt Master
  • 7,733 Answers
Try clean a clogged carburetor / gas filter!
Posted on Oct 25, 2010
SOURCE:
Natural gas generator shuts down after about 5 minutes and won't keep running.
How big a unit? Model number? Alarm codes? If it runs for 5 mins check the obvious, coolant level, oil pressure and sensor,
Nov 07, 2012 | Caterpillar Electrical Supplies
BRAND NEW ENGINE. USED THE FIRST TIME DURING HURICANE IRENE. OIL LEVEL IS FULL, USED REGULAR GAS AND HAS BEEN CHECKED FOR IMPURITIES. PROBLEM IS THAT AFTER 32 HOURS, THE ENGINE WILL ONLY RUN FOR 15...
Hi, if it re starts immediately and requires choking it is a fuel related problem. If it has to sit for a while before restarting, check for lost spark as soon as it stops. If no spark make sure the unit is level and oil is full when sitting level otherwise the oil cutoff switch will shut it down. If oil and unit levelling are ok and there is no spark the cdi unit is most likely faulty. Hope this helps, regards Phil.
Sep 06, 2011 | Gentron Electrical Supplies
Runs for awhile shuts down and will restart but will run awhile and shut down
Check your oil, you have a low oil sensor on your unit and if the low oil sensor will shut the engine down,
Aug 28, 2011 | Dewalt DG6000 Heavy Duty 6000 Watt Gas...
Dewalt DPD3800 pressure washer starts and runs fine. After 5-10 minutes of washing the engine quits. It will not start until it cools. The engine will start after a 10 minute cool down. It will run and...
I have the exact same pressure washer and have had the same issues with it. The cure for me was to simply run the washer with the gas cap loose. For some reason the fuel gets vacuume locked and stops flowing into the carb. The fuller the tank is it seems the shorter the time is between the time it starts and the time it shuts off. Or you might find a way to vent the cap. Hope this helps.
Jun 06, 2011 | Dewalt 3800 PSI Pressure Washer
I have a powermate 5500 that shuts off after 10-15 minutes. I changed the oil, gas, spark plug and the filters. Help!!!
If the unit has a low oil shut down make sure the oil if filled to the proper full level.
If you have the proper level then you can locate the low oil shut down wire and remove the wire to test and see if the unit will run.
If the unit runs with the wire off then you either have low oil or a bad oil sending unit.
Oct 07, 2010 | Coleman Electrical Supplies
Onan generator dies after 2-3 hours of running , wiil not restart rigt away wait 10 minutes starts no problem then runs for 15 minutes shuts down and keeps reapeating on 15 off 10
This sounds like overheating. These small generators don't have overheating protection, but if a low oil pressure or low oil level is present it may be the reason for stopping.
Check the oil level in the starting conditions and again when it stops. It may become under the "stop" level and after some time the precipitated oil has reached the "start" level. The same may be with oil viscosity and oil pressure.
Try to add some oil or change the oil with bigger viscosity.
Jul 07, 2010 | Watts Onan Portable Generator - 4000 ,...
Onda generator engine starts and then 3 or 4 seconds later stall
Oil pressure switch. Check it and make sure oil level is correct. The oil switch will cause this
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 31, 2009 | Electrical Supplies
Add electric start to dg7000 generator by Dewalt
This is really not an option. The engine would need a starter motor and battery and starting key switch. You will probably have to replace the unit with an electric start option.
Mar 08, 2009 | Dewalt 7,000 Watt 13 Hp Portable Generator...
Dewalt 7,000 Watt 13 Hp Portable Generator With Electric Start #DG7000E Logo
528 people viewed this question
Top Dewalt Electrical Supplies Experts
Sheldon Dedek
Jay Plesset
John Trevino
Are you a Dewalt Electrical Supply Expert? Answer questions, earn points and help others
