Question about Archos 605 Digital Media Player
Archos 605. yesterday it showed error code 104. i downloaded firmware and put it into the route directory and booted it up. it looked like everything was fine but now it continually shuts down after anout 5 seconds of getting to the main screen. the battery was fine yesterday so i dont see how it can be the problem.
6ya staff
SOURCE:
Anonymous
SOURCE: Firmware upgrade results in arclibrary boot failure
I managed to overcome the problem by doing a factory reset. Unfortunately doing this initially created more problems in that on reboot the main screen appearance looked as it should but was almost inoperable. When the usb cable was connected to my pc the disc did appear on My Computer . The system folder was only 1MB. By good fortune I had copied and saved my Archos files before I carried out the factory reset. Copying the original system files ( about 20MB) back to my Archos returned normal behaviour. Further, two additional buttons appeared. One was a manual arclibrary update button and the other a USB setup button . I cannot get file transfer to operate under windows media player mode and Windows media player 11. No problem though. I use PC hard drive mode and carry out a manual arclibrary update. None of this was possible prior to the factory reset. I believe I would still be having serious problems had I not saved and restored my system files
Posted on Feb 11, 2008
Anonymous
  • 5 Answers
SOURCE: Archos 605 battery replacement
I just found a place to buy a replacement battery (http://www.newmp3technology.com/605-30-battery.htm) and I was wondering if I can change it myself?
Posted on Sep 02, 2008
Anonymous
SOURCE: How do I download games on the Archos 605
you can download games from any flash games website like www.flashgames247.com, breaktaker.com etc.
Posted on Oct 14, 2008
Anonymous
  • 8 Answers
There are a lot of games you can download for Archs, but most games aren't created for it, so they won't work. Touch works and the game must be in the flash folder (you don't need to install it).
In he widgets -> flash it says empty also on my archos, but go to Files -> then the Flash map.
There you can find all the files, just select and run, Suc6!
Posted on Nov 04, 2008
Anonymous
  • 3 Answers
SOURCE: Web Browser Plug-in Archos 605
There is a seller on ebay (name is luhahaca) that says he is an Archos official Plug-ins reseller. Just search for 605 Plug-ins on ebay. He sells a four pack for only $38.00. I bought and installed them and they work great. Really makes the Archos functional - the way it should come out of the box. Actually, (sadly) the way it does seem to come out of the box - I was disappointed when I received my plug-ins download. All 4 plug-ins = 2kb. Web browser with widgets, extended movie and music capabilities and Real player mode. It seems to me that all of this is already in the Archos, they simply charge extra for a key to access it. It's a shame. Totally worth the price if you have an Archos, but really too bad they feel the need to force their hand into your pocket after you've just given them hundreds of dollars. I think the unit would be reviewed better, and Archos wouldn't look so petty, if these features were just enabled right out of the box. (my opinion anyways)
Anyhow, I hope that answered your question!
Posted on Jan 16, 2009
Code 104
Make a search on ebay for archos firmware issues somebody has a video on sale shows step by step how to fix it.
Jun 21, 2010 | Archos 605 WiFi Digital Media Player
How to fix archos 605 code 102
I was think maybe there is something was wrong with the Firmware so i decided to download the new firmware that was available at Archos.com. at the white screen wen you see the white screen keep hitting no rapidly until it starts up to your regular screen. If you must try the recovery. Anything to get to the main screen. Then try putting the updated fimware into the root directory after you connect via USB. Then try rest settings.
I hope this helps
Sep 09, 2009 | Archos 605 WiFi Digital Media Player
My archos 605 wifi is stuck in recovery
I fixed my son's 605 4 GB had Recovery code (104) on it These are the steps i followed
* Use the computer for this process that you always used for this archos
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white screen comes up do format
* Wait until all done then put the firmware in to the root sector of the Archos
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug in back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving wait until it is all done and it will shut off. Turn it back on Your archos will be back to normal.
When you go to download from Archos site it will explain how to download depending upon how your device pops up on your Pc.
Hope this helps
Jul 29, 2009 | Archos 605 WiFi Digital Media Player
Recovery code 104 appears on my archos 605 wifi 4gb
recovery code 102 and 104 appear in archos screen. it doesn't work.
Jun 07, 2009 | Archos 605 Wifi Portable Multimedia Player
Archos 605 wife (wife firmware)
If you chose any of these options already your Os is gone..
try this solution
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in to Pc before starting the process.
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
Mar 20, 2009 | Archos 605 WiFi Digital Media Player
My archos 605 has got recovery code 102 and i cant get it to conect to my pc to fix it can u halp
* Use the computer for this process that you always used for this archos Archos should be plugged in toPc before starting the process.
Mar 19, 2009 | Archos 605 WiFi Digital Media Player
After formatting the archos5 ,the device doesnt get recognised
* When the white option screen comes up, just pick the format disk
Mar 16, 2009 | Archos 605 WiFi Digital Media Player
Archos code 104
Make sure you have the correct model # for your Archos, or these suggestiosn from other experts will not work for you:
hotlyq:
Rank: Apprentice
Rating: 96%, 10 votes
Try the steps below:
1. Select 2nd option "Repair" or 3rd "Format the disk"
2. Connect 605 to PC using USB wire and find the Driver named "a605" or similar words
3. Copy a firmware to the ROOT directory on the driver mentioned above
4. Keep the USB connected and select "OK" on 605
5. Re-calibrate the screen under Display menu on 605.
Hope Everything is ok.
posted on Aug 27, 2008
alcalc:
Rank: Apprentice
Rating: 95%, 3 votes
Just a little FYI: hotlyq's solution works just fine, but the firmware file needs to be name exactly as it is downloaded. I downloaded both OSv2.1.0.4 and OSv2.0.1.0 firmwares to the same folder on my PC. Obviously enough I had to give them different names on the disk, I tried both and neither worked. It turns out the recovery system will not use any firmware unless it is named "firmware_a605f.aos". So if you're like me, copy the firmware over to the root of the USB-drive and then rename to firmware_a605f.aos.
Jan 07, 2009 | Archos 605 WiFi Digital Media Player
It shows-recovery error-102 & error-104
Hi
i had same issue. nothing worked until i saw a guy who fixed his by dropping it on floor?
i dropped my archos in the protective case from 2 feet off floor. the bloody thing when came back to life, 100% good. i think the hard drive was stuck and the fall fixed it!! it cannot hurt as yours is broken still i guess. hope it works for you to
Recovery code 104
Same issue on my Archos 605 wifi 4GB
The Repair didn't work so here's what I did.
1) connected via USB and got all my Picture, Videos and Music to a safe place.
2) Downloaded firmware update.
fouund it here - http://www.downloadplex.com/Drivers/Firmware/Archos/Download-Archos-605-Wifi-4GB-Firmware-2.1.04_109044.html
3. Copied update to root of archos drive and rebooted
4. Archoes installed the update and rebooted and came up to desktop again
5. reinstalled plugins (thank god I saved them) copied plug-in to root.
6. Back on the road again
Feb 23, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 Digital Media Player Logo
48 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
 Mike M
Mike M
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
