Question about Music
How to record beat on the r8 - Music
    President:
  • 1,140 Answers
Is this the R8 you are talking about:http://www.midisolutions.com/prodr8.htm
Posted on Oct 24, 2010
SOURCE:
Why zoom g2 point blinking ?
There is damage/burnt at Transistor Q4 or Q3 or both. Usually followed by R8. Replace it.
Q3 = BC337 (SMD marked as 6C) NPN.
Q4 = BC327 (SMD marked as 5A/B/C/D) PNP.
R8 = 470 ohm (SMD marked as 471).
May 06, 2014 | Zoom G2 MultiEffects Guitar Pedal
Im Using Acid Music Studio 8.0 With & Xenyx502 Mixer. Every Time I Record It Sounds Fine But When I Play It Back When Im Finished Its Off Beat How Do I Fix This??
check the "buffer" setting - set to the lowest number possible. You can't eliminate the "latency" but you can reduce it a lot. Also 0 try to monitor what you are recording with "live" sound (input instead of output) - also, you may need to download a different driver for your audio card, try ASIO4ALL
Oct 13, 2013 | Lexicon Alpha Personal Recording Studio
When I record & play it back my recording take is off beat
you have too much latency in your setup. Try using ASIO as your audio engine in your recording program. Also, shut down all unnecessary programs running on your computer to get better performance.
Roland r8 has flashing green light
Are you using the correct AC adapter? An aftermarket unit will do this if the power is insufficient, or the polarity is wrong (- / +). If you're using an aftermarket unit, it may not be providing the right amount of Amps and Voltage to the unit; causing the display to blink. You can try this cord to help: http://www.powerpayless.com/ac-power-adapter-for-roland-r-8-r8-drum-machine.html
Jan 13, 2013 | Music
When i record i can hear me very well but the beat has like a funny bass sound to it what can i do to stop it
If your mic can "hear" the beat, it will record it as well with a reverberation that will NOT be pleasing. Maybe you can use headphones to avoid that.
Jul 13, 2011 | Yamaha Mg82cx Stereo Mixer
I recorded drums to the internal click track/metronome and drums are in time with metronome when i play it back with the click from the start of the song. BUT, if i stop in the middle of the song and...
I'd say the click track starts from exactly when you hit play even if you've hit play not right on the beat. There might be a setting or preference that can fix this.
Try rewinding back to be right on the beat and see if it syncs with the click
Jul 01, 2011 | Tascam 2488mkii 24 Track Recording...
I have the Simmons SD9K electronic drum kit. I really love it, but I have two seperate issues. First, I sometimes get a snare pop out of the blue while playing a beat and sometimes just after I stop...
With the sensitivity set very high, you might be getting false triggers from static discharges. It sounds like your snare trigger is either bad or possibly the cable from it may have a problem as you should NOT have to set the sensitivity so high.
It will take an oscilloscope to test the pad unless you can find a system to do a sensitivity comparision. The second problem regarding the recording/overdubs I cannot help you solve.
Mar 27, 2011 | Simmons SD9K Electronic Drum Set
Can i hook the alesis drum machine up to my computer and use it to make beats?
Are you talking about recording the beats from the Alesis or are you talking about designing beats on your computer to load into the Alesis? If it's the latter, try this link:http://www.squest.com/Windows/Instruments/AlesisSR-16/index.html This link might also be useful:http://www.synthzone.com/alesis.htm Please let me know how you make out.
Nov 25, 2009 | Alesis Sr 16 Stereo Drum Machine
Music Logo
53 people viewed this question
Top Music Experts
Michial Gueffroy
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
