Question about Heritage Pool and Cover Pump
I have a 2010 viking heritage 2 spa. the owners manual says that for the primary pump, there are low, high, and off settings, but mine only goes from low to high. no matter what setting it is in, the pump wont turn fully off. how tdo i get it to turn off?
    New Friend:
Theres nothing wrong with the pump! i have a 2008 model and it does not turn off until it is done cycling (stays on low). This may be 15 minutes after you try to turn it off depending on the power mode you have ST is standard and will run the pumps more even when you are not in it.
Posted on Jun 16, 2011
  • 990 Answers
If you have a timer and it is on a maintenance cycle that will keep it on low, A freeze control that will keep it on under about 38 degrees. If the thermostat is controlling the pump it will keep it running also. If it has a cool down mode to let the heater cool that will keep it running. These are some reasons it will stay on and their may be more. I would turn the thermostat down and if it's cold out run a heater under the cabinet and make sure that no timer is controlling the pump. Set it to low and walk away for half an hour if it won't shut down turn it up to high and back down again. One of these low speeds should be off. Good luck.
Posted on Oct 25, 2010
6ya staff
SOURCE:
2010 Harley Davidson FLSTC Heritage Softail Classic oil drain plug locations
Hi, Robertrubi for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can not find the best tool you ever bought for your Harley, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at [email protected] Good luck and have a wonderful day.
Harley Davidson Heritage Softail Oil Change
2010 Harley Softail Service Manual pdf
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
2010 Harley Davidson Heritage Softail Classic Owner Manual
Instant Repair Help over the Phone to speak to me personally $4
Sep 19, 2018 | 2010 Harley Davidson FLSTC Heritage...
2010 Harley Davidson FLSTC Heritage Softail Classic primary oil
Hi, Charles, for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can not find the best tool you ever bought for your Harley, despair not, for a mere zero $0 you can download another one.
Harley Davidson primary drive Mobil Motor Oils
UPDATED how to chang the primary fluid on harley softail
http://mybikemanuals.com/harley-davidson/2010-harley-davidson-owners-manuals
Instant Tech Relief To speak to me personally for only a mere $6
May 03, 2018 | 2010 Harley Davidson FLSTC Heritage...
Where's the oil drain plug for 2010 low fatboy harley
Which of the three drain plugs. Primary is on primary case below derby cover; transmission is on right side middle bottom of transmission, engine is at bottom of right rear frame down tube intermediately forward of rear tire. ALL are 5/8 inch hex plugs with 1/4 inch Allen socket in the middle of the plug.
Apr 13, 2014 | 2005 Harley Davidson FLSTC - FLSTCI...
Can't figure out how to set the LOW speed part of the 8 hour cycle
the 2 speed pump uses 2 auxilaries set low for low hour and high for high hours have to go into set up and assign them
Sep 28, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Heritage spa what does HL stand for on control panel
According to the Viking heritage manual, this says A significant difference between temperature sensors has been detected. Could be a flow problem. Check water level, re-fill if necessary, If ok, make sure the pump(s) have been primed. Take care and good luck, Andy
Mar 09, 2011 | Home
Heritage Pool and Cover Pump Logo
1,157 people viewed this question
Top Heritage Pool & Spa Experts
john h
ray gallant
ray gallant
Tom Chichester
Are you a Heritage Pool and Spa Expert? Answer questions, earn points and help others
