Question about General Refrigerators
My GDL20KCSABS fridge is out. The lights are on, but the compressor nor fan are working.
  • General Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101 .
Posted on Oct 25, 2010
SOURCE:
When we shut the fridge door a loud continuous humming noise comes from the fridge. This seems to be activated by the door light switch at the top. Thank you
There are 2 possibilities I can think of for the hum. When you activate that door switch it activates 2 fans and the compressor. There is one fan located on the compressor and one located in the vent system in the fridge. The second fan is used to circulate cool air evenly through the fridge. I would recommend holding your finger on the door switch and listen carefully whether the noise is coming from inside the back of the fridge or from the lower bottom. Lower bottom could indicate compressor cooling fan or compressor. They would need to be inspected. If it sounds more like the other fan mentioned above it would again need to be inspected. The compressor cooling fans can get stuck or become noisy due to bearing failure. The vent fan can get stuck or noisy but also in some cases if the defrost circuit is not working can chock up with ice and create a buzzing noise as the fan blades strike the ice.
Jan 13, 2017 | Refrigerators
Rl41WGIH fan on but no light and fridge isn't very cold
Bad news for you. I've had the same symptom. The problem was compressor. It seem it will not work longer as about 5 years. To buy another one and repair was expensive. I have now new fridge similar to this but I hav for compressor 10 years waranty.
Mar 29, 2014 | Samsung RL41WGIH Bottom Freezer...
Neff fridge/freezer has stopped cooling
pull the unit from the wall, remove the bottom back panel , see if the small fan is working ,if the fan is , there's probally alot of dust back there,unplug the fridg. and vacuum the area real good,use a flash light to make sure you get it all, if the fan is not working and the compressor is running the fan is the problem ,the fan keeps the compressor and coils cool so the freon can cool down so the unit works like it should,if the freon is hot ,the air the fridg.will be blowing will be hot. this should fix your problem, and YES its worth fixing.alittle p.m.saves alot of $$$$$$$$$
Dec 03, 2013 | Neff Freezers
Ge refrigerator dead
i don't suspect its h20 contamination. i've never seen that issue on a unit yet. is the fridge doing anything at all other than light up?
Aug 05, 2013 | Refrigerators
My fridge wasnt cold yesterday but the light was on and the freezer worked but this morning the freezer has started to defrost and everything was warm in the fridge
If you cant hear the compressor running and he fan under the fridge and in the freezer compartment are not running. The problem would be your defrost timer has quit on the defrost mode. Your defrost timer should be located in the fridge side behind the back plastic liner or if your controls and light are in the center top it will be there. The timer is plastic with a metal motor on one side. There is a shaft in the center that a flatblade screw driver will fit in turn it and you will hear audible clicks and the fans and compressor should kick in. I hope this helps. If the fans are working but the compressor is not the compressor is bad or the start relay on the compressor may be bad it is located under a plastic cap on the compressor and is about the size of a nickle and is connected to one of the 3 prongs coming out of the compressor. Remember to always unplug the fridge before working on it. good luck
Aug 18, 2010 | Refrigerators
My Whirlpool side by side fridge and freezer not working
Most likely, if you can hear the compressor running, the fan inside the freezer is not working. When the compressor is running, open the freezer and listen for the fan running. If you don't hear it, locate it and, with a voltmeter, test for voltage across the terminals. If you have voltage present, replace the fan. You can buy replacement fans at a local appliance parts store, internet parts suppliers, even ebay.
Jan 29, 2010 | GE Refrigerators
Freezer not freezing, fan in rear bottom of unit not running, condenser extremely hot to touch. ge gdl20kcsabs
Hi, If the compressor is running but the fan is not, you will need to replace the fan motor. First make sure that there is nothing stopping the fan blade.
If you have a window or box fan, let it blow on the compressor to cool it down. This will help you get by until you can replace the condensor fan motor.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 13, 2009 | Refrigerators
Refrigerator compressor not working
unplug the fridge,remove the electrical cover on the compressor to see if any wires are burnt off.you may have a defective start relay,wire off or compressor seized,that age not cost wise to replace compressor
Apr 09, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
FFA60 Hotpoint fridge/freezer Red warning light
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling. there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
Mar 11, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
208 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
gerry bissi
Joseph Mueller
Joseph Mueller
Are you a General Refrigerator Expert? Answer questions, earn points and help others
