Question about Garden
How to replace primer bulb on homelite blower
  • 3,074 Answers
Remove the two screws, lift metal oval plate off, remove cracked bulb and replace with new bulb, put plat back on with screws prime new bulb. Note when you remove screws whole assemblage will want to come apart. Good Luck Tim
Posted on Oct 24, 2010
Testimonial: "Thanks for this tip. Its just what I was looking for! Jim"
SOURCE:
Backpack II. How do I replace the primer bulb?
  1. Homelite Blower UT08072 User's Guide ' ManualsOnline.com
    lawnandgarden.manualsonline.com > ... > Homelite Blower OPERATOR'S MANUAL. BACKPACKER II. UT08072 and UT08572. SAVE THISMANUAL FOR FUTURE REFERENCE. Your blower has been engineered and ...
Jul 20, 2015 | Homelite Garden
How do I replace the fuel bulb?
Homelite and Ryobi appear to be made by the same manufacturer. Home Depot now carries a "Fuel System Tune-Up Kit, AC04122," that includes 2 replacement fuel lines and a replacement Primer Bulb for 25cc, 30cc, and 26cc 2-cycle engines. Cost is $7 +.
Aug 27, 2012 | Homelite Mighty Lite Blowervac
How do i remove the primer bulb on my homelite mighty lite 26cc blower
The primer bulb should be attached directly to the carburetor. There will be a plate with 4 screws, once on each corner, which you will have to remove to get the primer bulb off of the carburetor. You can find replacement primer bulbs at PartsBuggy.com.
Sep 29, 2011 | Homelite Mighty Lite Lawn Trimmer
I have a handheld blower/vac: The primer bulb is new and will not pump fuel,not even fill the bulb. I checked the fuel lines to make sure they were correct.(homelite)
I was working on a neighbor's homelite chainsaw and I replaced the primer bulb, it was not intuitive, and I hooked up the lines backwards. Also if you are replacing the primer bulb, maybe you have old fuel lines that are deteriorating and need replaced. Did you check the in tank fuel filter? If it looks dark, it may be time to change it.
I hope this helps get you going again.
Sep 01, 2011 | Homelite Consumer Products MightyLite...
My Homelite Mighty Lite 26b Leaf blower has a punctured primer bulb. Homelite doesn't list the part number. Model number UT08520A Can you help? Thanks, Ed Mckinney,Tx
Homelite wants to sell you a new carburetor assembly. Your blower came equipped with a RuiXing brand carb. RuiXing does not offer any repair parts for their carbs, only replacement units.
Now for the good news....a Zama brand primer bulb fits perfectly on the RuiXing carbs. Check with your local small engine repair shop for a Zama primer bulb. The blower requires removal af the carb to get at both of the screws that hold on the bulb. It is not difficult, just one nut holds on the outer airbox cover...don't lose the little washers. Then one long stud and one short screw will take the carb off. Replace the primer bulb and reinstall everything the same way it came off.
Dec 21, 2010 | Homelite Garden
Primer bulb is cracked on my Homelite Blower/VAC Model HB-180 Gas is leaking, I need replacement parts. Blower purchased in 1990
www.homelite.com to buy parts online
1.800.242.4672 customer service #
both will give you your local shop. Home depot also sells homelite products.
Apr 24, 2010 | Garden
PRIMER BULB WONT PRIME
I would recheck the carburetor to make sure you put the diaphragms next to the carburetor and not the gaskets.
Please if it is not priming you may have the fuel lines hooked up wrong. Also check the fuel cap to make sure the vent assembly is there. If the tank is not venting, the tank will get a vacuum in it not allowing fuel to flow.
HTH
Good Day.
Nov 11, 2009 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
420 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
