Question about InFocus Televison & Video
What does invalid unit SN mean? When I am adjustign the picture, or on Menu, the pricture is clear. as soon as I log out of menu the following message appears on the bottom left hand of the screen: INVALID UNIT SN Any idea what this means? How do I get rid of it? Thanks ASHLEY
SOURCE:
  • 105 Answers
SOURCE: menu 42PF9630A 42
go to www.ceusasupport.philips.com and upgrade your televisions software to the latest version. this is a very common issue.
Posted on Jan 15, 2008
SOURCE: navman f10
Hold down on/off button till screen clears,this should reset navman F10 .Turn back on and it should be working normally.this worked on mine.
Posted on Jun 19, 2008
SOURCE: Zenith Z42P3 "Invalid Format" message from upconverter DVD
Ran into the same problem with this DVD player and my LG tv. Try this:
Open the DVD tray, with the DVD tray open press the HDMI select button until the proper resolution for your tv is illuminated, put the DVD back in, close the tray and try again. Simple fix -- worked beautifully for me.
Good luck
Posted on Jul 11, 2008
  • 18 Answers
SOURCE: Invalid Imaging Unit and Toners
Sorry about my last post. I didn't realize that it would be placed unter solutions. BUT I did get a resolution from Samsung. They passed me to the advanced team and they suggested I use a special code they gave me to reset all the machine. As I said before the machine was giving me an error that all the toners and the imaging unit were invalid. Samsung said to try this and if it didn't work they would send me a new (refurb) unit. They said to press in sequence <menu><#><1><9><3><start (b&w)> then when the unit cycles it will ask to imput the country, in my case I entered the US. The machine will then reset itself and all the cartridges and imaging unit should be reset to work. IT WORKED!! The machine said to wait while it re-installs the toners. When it did the red warning light turned off and the printer is working great. Hope this helps.
Posted on Aug 18, 2008
SOURCE: INVALID DIM
on a calc that's work properly, in the 'y=' screen, none of the 'Plot#' things are highlighted. try pressing 'y=', and if you have a 'Plot#" in a black box, go up to it and press enter to un-highlight it.
either it will work as soon as you press 'graph',or you have another problem
Posted on Oct 19, 2008
How to clear notification transfer roller needs to be replaced soon.
1. Touch Menu.
2. Touch [Counter].
3. Touch [Display Keypad].
4. Press the following keys in this order.; Stop -> 0 -> 0 -> Stop -> 0 -> 1
5. Enter the CE password and touch [END]. (IF required)
6. Counter
7. Life
8. Transfer Roller Clear
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 19, 2015 | Genuine Konica Minolta Konica Minolta...
Samsung clx 3175fwreplace imaging soon flashing
do the following menu #1934 menu tech menu enter / ok clear settings password 1934 reset imager enter/ok restart machine
Oct 26, 2012 | Samsung CLX-3175FW Multifunction Laser...
Replace Imagine unit Soon
Log into the service menu Samsung CLX-3175 without a numeric keypad similar to the unit Samsung SCX-4623F/FN:
Consistent set of combinations of
"MENU" - "COPY ID" - "LEFT" - "RIGHT" - "MENU" - "BACK" . Samsung CLX-3175XX/X with a numpad press: Menu, #1934, Menu
The unit switches to English, if you installed any other.
In the menu appears TECH MODE.
In
Samsung CLX-3175 to enter the reset require a password 1934. The numbers by pressing "LEFT" - "RIGHT",
After each number press the "OK"
Good luck in the reset.
Have any questions, you here http://skit-ltd.narod.ru/
Jul 04, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
The picture I took look grainy. Just started doing this.. do you have any suggestions Thanks susie
If the pricture was taken in low-light then it just will look grainy. If not then make sure you're zoomed all the way out (i.e. not using Digital zoom as opposed to Optical Zoom) and make sure the resolution settings on the camera Menu are set to the highest setting.
Mar 02, 2011 | Canon PowerShot A95 Digital Camera
How do i delete my call log on a nokia x3-o2 phone
To delete the call log of Your nokia x3-o2 is very simple, all You need to do is follow the steps below:
  1. Go to the menu,
  2. select the call log from the menu,
  3. From the call log, You have call log, missed call, received calls, dialled numbers, and others,
  4. From the list You have "clear call log", select it
  5. A option will will come up asking what You want to clear, just select call log,
  6. It will instantly delete all call log.
Hope this helped. Thank You for using FixYa!!!
Jan 21, 2011 | Nokia X3 Cell Phone
Can i set the printer to print black only
Hi ethelinebake.
I thing the right way to ask would be..Can i print without colour, and the answer is, yes in Greyscale
I am from Denmark, mayby some of text and pictures not look simular to yours, but i think you can see what i mean - ok
Go to controlpanel ->Printers (or Printers and fax), right cklick on your printer -> click on "Print Preferences"(see pricture Fig. 1 ("Udskriftsindstillinger" = "Print Preferences"))
Now you get a new menu, cklick on "Adwanced" (see picture Fig. 2 ("Avanceret" = "Advanced")), then select "Greyscale" ("Gr?skala" = "Greyscale"), and then "OK".
All what i printed out after that, was in greyscale "colour".
...now you also have learnd a little bit danish too :o))
Oct 11, 2010 | Brother DCP-330C All-In-One InkJet Printer
Fax log full HP Officejet 8500 error; Delete not
Please press the set up menu on th eprinter which is like a tool(wrench)-----Arrow keys-----TOOLS-----OK-----Arrow Keys------Clear Fax Log------OK.
This will clear the fax log.
If still the issue persists, please follow the below steps.
1. Touch the Setup icon.
2. Scroll to and touch Tools.
3. Scroll to and touch Restore Factory Defaults. A Defaults Restored message displays.
4. Press the Cancel button to return to the main menu.
And then, again cleasr the fax log by following the below steps.
This will fix the issue.
Apr 11, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Log on/off windows XP home edition
I think you should have been little more clear about your question.
I think you might be facing the problem with logon and logoff .
If the Icons are not displayed in the start menu. Then follow the steps below.
Right click the start
select properties
in this pop up menu click on Classic start menu.
Then click on customise icon.
in this list check(select) the log off text.
click ok
again click Apply and Ok.
Now you go to start and see there would be a log off icon in start menu.
Nov 19, 2009 | Microsoft Windows XP Home Edition
Trying to fax and the following error appears " Memory is full".
Please perform the steps given below to clear the memory log.
* Press Setup Button
* Scroll to Basic/Advanced Fax menu
* Under that check for the option Clear Fax memory or Fax Logs
* Select that and check
If the issue persists then perform a rest on the unit
* Turn ON the unit
* Remove the power cord from the back of the unit
* Press and Hold #(Pound) and no. 6 button on the unit simultaneously while connecting the power cord back to the unit.
* Check for the results
Wish
Jul 31, 2009 | HP LaserJet 3050 All-In-One Printer
Cordless phone EnGenius SN 920
. A new handset arrives with a handset ID number of 00, to register this handset to your system take the following steps:
  1. On the EnGenius base unit press and hold down both the "Volume" & "Intercom" buttons for about five seconds. You will hear a beep from the base unit. You can now release the two buttons.
  2. On the EnGenius handset (00), press the following buttons: "menu", "6", "1".
  3. A new handset ID number (ie: 12, 13, 14…) is automatically assigned by the base and registration is complete.
Feb 29, 2008 | EnGenius SN 920 Ultra Cordless Phone
Televison & Video Logo
164 people viewed this question
Top InFocus Televison & Video Experts
Donni Steen
rostit
Are you an InFocus Televison and Video Expert? Answer questions, earn points and help others
