Question about Nikon Coolpix S3000 Digital Camera
MY camera is saying lens error and battery exhausted? What do I do
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Jan 25, 2011
SOURCE:
Showing lens control error fuji finefix HS 30 exr
Does it say Lens control error, or does it say Focus error, turn off the camera and turn it on again?
The last can happen when you touch the lens barrel. When the lens does not retract when you shut down the camera, perhaps the battery is exhausted or the barrel got stuck.
Try to recharge the battery and start all over again. If nothing goes, try carefully to pull out the lens a little Less then one millimetre. or gently press it back a little. Be aware the camera is a very delicate piece of equipment, so don't use force, because that could damage the camera definitive.
In the manual, it says you should contact FujiFilm, when the error comes back after you switched off and on. So if nothing helps, that is the last option. Visit a repair shop from Fuji, or bring a visit to your dealer.
Dec 27, 2013 | FUJIFILM FinePix F300EXR Digital Camera
Samsung NX11 Error 00
Low Battery, or exhausted ones, also gaves error 00, due to inability to provide high power to the lens.
Jul 05, 2012 | Samsung NX11 Digital Camera
Says-please turn camara off and then on again...........doesnt stop getting same message
Sorry you have to get it serviced.... (1) Usually this type of message comes when the there is a lens error that means lens does not retracts.. the main reason could be that the motor has stop functioning or the lens is stucking somewhere... Light tapping near the lens may help you... Or (2) your current battery has exhausted the whole life, then this case the inserting the new battery will solve the problem.....or (3)in the rare case the cam's firmware has been corrupted...
Hope this has helped you... Please rate the answer... Thanks..
Jun 15, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Lens error :0x01110000 That's what it says when
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Jun 12, 2010 | Pentax Optio 60 Digital Camera
Lens won't open, & it says lens error, restart camera.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try
Jul 24, 2009 | Canon PowerShot A560 Digital Camera
My EX-S5 says lense error
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jun 10, 2009 | Casio Exilim EX-S600 Digital Camera
The screen keeps saying lens error 14 then its says lens error 22
pls tap the bottom of camera and see if it works i mean tap hard it might come out or not it is stuck with dust and sand or something like that or the GEAR might be broken then i will suggest buy a new one dont waste time in replacements
consider FUJIFILM.com they are good in cameras
Pls rate me WELL !
Regards
Zohail
May 28, 2009 | Kodak EasyShare C330 Digital Camera
Says lens error restart camera
Jan 06, 2009 | Canon PowerShot A590 IS Digital Camera
Battery Problem
These cameras have a internal battery that holds data for the camera to keep its settings. These batteries can be replaced but the camera has to be disassimboled to change it they should be able to be changed at a local camera shop pretty cheap.
Mar 21, 2008 | Nikon COOLPIX L12 Digital Camera
Nikon Coolpix S3000 Digital Camera Logo
162 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
