FixYa.com
Tags:
Jenn-Air JCB2280HES Side by Side Refrigerator
WARM AIR
posted by GABBY5 on Jun 08, 2008
FREEZER AND FRIDGE BOTH WILL NOT GET COLD,THERE IS A LITTLE WHITE ELECTRICAL BOX ,WITH WIRES COMING OUT OF IT, ON THE SIDE OF COMPRESSOR ,THAT CONSTANTLY CLICKS .BUT NOTHING HAPPENS.THE LINES GOING IN AND OUT OF THE COMPRESSOR STAY WARM.I THINK ONE OF THE LINES COMING OUT OF THE COMPRESSOR SHOULD BE COLD...LIGHTS AND FANS DO WORK...
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 08, 2008
Helpful (85)
fixum1
Rank:Guru Guru
Rating: 87%, 416 votes
either you have a deffective compressor or the overload that is clicking on the compressor is bad
the easiest way without a volt meter to tell if the overload is the issue is to remove the relay from the compressor and shake it if it rattles it has a burned out relay inside the white box
if you shake it and no rattles then it could be a stuck compressor or a bod relay
it will be one of the two
if betting i would be on a bad relay
Rating Locked! (?) GABBY5 has rated this solution as Helpful
Solution #2
Helpful (85)
worldvet
Rank:Guru Guru
Rating: 89%, 219 votes
Are the wires coming out of the electrical box connected or disconnected.
The clicking sound you here is the temperature sensor tripping the relay that drives your compressor.
Would you say the air coming out is warmer than usual or about the same?
Keep in mind that these things are dust traps and when dust gets wrapped up around motors they can interfere with the function of the system. It is always a good idea to vacuum out the dust you can get to and then reverse the vacuum tube and blow out the rest. A service tech will do this anyway should you have one come by.
With this being a Saturday and the food in your unit at risk there isn't a whole lot of choice for you right now. And, based on your trouble form a few days ago I think its time to call for service. You'll have to do what ever you can to save your food, a chest freezer can take care of the freezer contents and ice chests and bagged ice can handle the other, though I wouldn't suggest saving things like mayonnaise and mayo based dressings.
Sorry to bring you this bad news, although let me know about the box and give blowing the area around the compressor out just to .
Unless this fixes you, which I doubt, please don't bother rating this. I don't mind requests and will always respond at my earliest when ever that may be.
Regards,
Worldvet
Can you Help with these Refrigerators problems?
Jenn-Air JCB2280HES wasn't...
Came home and found JENN-AIR... Answer This...
bottom half freezes food, top...
Bottom half of freezer and... Answer This...
Jenn-Air side by side water/ice...
I have ice and water dispensing... Answer This...
Jenn-Air 48" Side by Side...
The refrigerator has be running... Answer This...
Would you look over this...
Don't know why I received this... Answer This...
Repair Service
Find Refrigerator Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
