Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
My zero turn mower will not steer and the blades will not turn The only numbers i can find are MOSS 18C010041 SST18 W/48C
  • 3,074 Answers
On the inside underneath the mower by the handles there is a bolt , this bolt allows you to push the mower when it is not running, so take brake off and see if you can push the mower if you can then the bolts need tighten. The blades are engaged by the PTO..... wait a minute sounds like you have a belt problem. check the belts make sure they are on all the pulleys. Hope This helps Tim
Posted on Oct 24, 2010
SOURCE:
While mowing the blades disengage and engage ?
your battery might be going bad if the unit has an electric PTO clutch
Nov 15, 2015 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
Wheels won't turn, runs and blades work
if by turn you mean they wont rotate, then check if parking break is on, if you mean you cant turn the steering wheel, or cant make make it go around corners, then check the linkage
Apr 20, 2013 | Cub Cadet Riding Lawn Garden Zero Turn...
Blade number for Ariens Zero Turn Model 1840. Need
Depending on which version of the 1840 you have and when it was built it could be several blades...
Please get your model and serial number and then enter them into the following site's search engine. You should then be able to identify the parts you need.
http://partsradar.arinet.com/scripts/EmpartISAPI.dll?MF&app=ariens&lang=EN&TF=Empartweb&loginID=ariensc&loginpwd=consumer
John
Jan 18, 2011 | Ariens Zoom 42 In 165 HP Briggs Stratton...
How do i change blades on the husqvarna zero turn mower model number LZ6127
Jack up your machine safely and unscrew the bolts holding the blades on..then reverse this order..
Aug 30, 2010 | Husqvarna Zero Turn Mower Z5426
Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Jul 20, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
245 people viewed this question
Top John Deere Garden Experts
Dave
Joseph Mueller
Joseph Mueller
john h
Are you a John Deere Garden Expert? Answer questions, earn points and help others
