Question about Dynex Wireless-G Broadband Router
Cannot connect wi through dynex wireless router
  • Dynex Master
  • 7,733 Answers
SOURCE:
I attempted to add a password to my wifi and now my laptop does not recognize the router or network.
Go into your laptops wi fi connections and try deleting the wi fi connection from your laptop. Then search for the wi fi from your laptop and connect as a new connection. This should resolve the issue.
Please rate if this helps
Mar 15, 2011 | Dynex Computers & Internet
My computer is not connecting to my Dynex wireless router. I've called my locate cable subscriber and they told me that it's a router problem. I've disconnected the router several times and it shows that...
First off, verify that you can connect to your cable modem directly. After that, hook up your Dynex wireless router and reboot your cable modem. After this, directly connect your computer to the Dynex router (using a cable). If you cannot get an Internet connection, then there is some issue with your Dynex router configuration. It's possible that there might be an IP address conflict with the cable modem. It would be best to contact support for configuring the Dynex.
If you can connect to the Internet with your computer connected directly to the Dynex router, then there must be some router configuration problem affecting your ability to connect wirelessly. You'll have to check the configuration--might be a good idea to completely reset the router and start over. If that doesn't help, you should contact Dynex customer support, as each router has its own configuration specifics. Good luck.
Nov 07, 2010 | Computers & Internet
Need disc for dynex dx-wegrtr
You can confiure your without disk too .
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 07, 2010 | Dynex Enhanced-G Wireless Broadband Router
Computer cabled to Dynex enhanced G wireless will not connect
Unplug the router for ten seconds and plug it back in, it needs to reset. Some routers have a reset button. I often wait longer than ten seconds, I find a beer is usually the right amount of time. Sometimes the modem needs a reset also; unplug everything, then plug back in sequence, with the modem first, the wait, then the router, wait, then turn on your computer. That system works for any brand modem and router.
Jun 09, 2009 | Dynex Enhanced-G Wireless Broadband Router
Cannot connect with dynex wireless g adapter
YOur system is having wi-fi device.Did you setup wireles n/w?If yes you will activate it & check wheather u will get the wireless connectivity or not?If no check the power supply for bothe g adaptor & your wi-fi device activation.If ok then it must shows wireless connectivity.
Jan 04, 2009 | Dynex Wireless-G USB 2.0 Network Adapter
Can  Dynex 4 Port Router DX-E402 be used to connect internet on a notebook without using cable to notebook?? i.e. Can it be used like a wireless g router??
Unfortunately, the DX-E402 is not a wireless router, so it can not transmit its signal without a physical cable connecting the router to your computer. If you want a wireless router that can also connect to your ISP, check out the Dynex Enhanced Wireless G Router:
http://www.dynexsupport.com/product/?pid=DX-WEGRTR
Nov 28, 2008 | Dynex 4-Port Ethernet Broadband Router...
Siemens router & Dynex adapter
Double check if there is any wireless security enabled in your router. Verify if the type of security enabled in your router is already supported by your wireless adapter. If the wireless security enabled in your router is not supported by your adapter, change the security to something that will work with your adapter.
Try connecting your computer with dynex Wireless G USB to different wireless network for further isolation.
Oct 02, 2008 | Dynex Computers & Internet
Wep key for dynex router?
put new router dynex good signal no internet on laptop
Sep 27, 2008 | Dynex DX-E401 Router
Need help with best connection type for college student in dorm
The enhaced version just give more range of signal over the normal dynex, regarding the internet provider it depends because sometimes you'll need a password and user to connect to the wireless signal. The dynex is used to connect from a cable signal (RJ-45)internet and then it will transfer the connection to wireless so it can be use from any laptop with wireless connection. So for example you DSL internet connection is a cable (RJ-45) then you connect that cable to the dynex router, then the router will automatically transmit the signal to wireless so any nearby pc can connect to it. If the laptop doesn't have wireless, then you'll have to buy a card to be able to connect to wireless signal or you could by also a (RJ-45 straight-through cable Cat 5e) to connect from one of the ports from the DYNEX to the laptop. Hope it helps.
Aug 19, 2008 | Microsoft Xbox 360 Console
Dynex Wireless-G Broadband Router Logo
67 people viewed this question
Top Dynex Computers & Internet Experts
gggg
Prashant M
Prashant M
Mike
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
