Question about Briggs & Stratton Garden
My B&S Intek OHV 9.0hp engine started a couple of weeks ago but I can't get it to start or even tease a start now. Spark plug looked fine - attached sparkplug cable, grounded the plug and pulled the starter cable - saw/heard no spark.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Briggs & Str... Master
  • 1,917 Answers
Pull plug to see if it is flooded and to check for spark if ok squirt some starting fliud in it and start it if runs and shuts down check for water in gas and the other thing is too rebuild carb its dirty
Posted on Oct 03, 2014
SOURCE:
  • 819 Answers
SOURCE: starts runs min. or two then stops....
Go to toro.com then click customer care, then click manuals and parts. Type in model no. and download the owners manual. This should get you the spark and flywheel gap. Probably still something in the carb. Some orifices are very hard to find and to clean but they must be clean. Also check for dirt dopper nest in the muffler.
Posted on Apr 06, 2009
  • 35 Answers
SOURCE: Featherlite will not start
first never let any one browe your tools or your wife thay could break eather of them noe get a small screwdriver find the air adjutment screw on carb turn it in count the turns till it stops then pull it out by turning it counter clock wise dont louse any spring that might be there its out get carburator chock cleaner use the little tube put it in hole were the screw lived at and let it have a good blast or 2take out spark plug and pullthr start rope 10 or 15 times put plug back put air screw back 1 3/4 out from bouttom i think if you had dif number try it first if that dont fix it you may need to take carburator off take it apart and clean there is two gas lines that go to tank if one of the lines has a filter on it inside the tank if thay get water in there threeeere pluged up might get new one there fun to get out of tank or take to shop if you dont have all the tools or homedepo and buy good luck
Posted on Apr 09, 2009
  • 87 Answers
SOURCE: NO SPARK TO SPARK PLUG
Check the safety switch where the vacuum tube connects to the unit or disconnect Ignition switch to find failure. (Never operate unit with safety switches disconnected!)
Posted on Apr 10, 2009
  • 77 Answers
SOURCE: I have a Troy-Bilt 31cc 2-Cycle Gas Powered that doesn't start
Coil bad or wire to coil bad. I tell everyone what Ill tell you,when it comes to small engines,troy bilt,poulan,weedeater brand all JUNK,JUNK JUNK! Theyre made cheap,not built to last,theyre throwaways. Carbs are made in china. If youre ever in walmart next time go back to the garden section and pick up a weedeater or poulan brand chainsaw or trimmer. Look at the package good and look at the factory life expactancy. Its not in months,not even days,but in hours. If I was you I would tell myself NO MORE! I would buy a dolmar or stihl,pay the extray,cause you wont be aggrevated in the long run. P.S. Dolmar offers a 100% coverage for ONE YEAR on all equipement.
Posted on Aug 11, 2009
  • 7 Answers
SOURCE: Tecumseh LV195EA Starts then dies.
If the engine is running at all then your sensors should be ok. It sounds to me like its starving for fuel? Once the engine runs out of prime then it starves. Does the fuel system have a shut off valve? How about an inline fuel filter? Either could be plugged. I think what you will need to do is remove the carb from the engine and check to see if its clean and if fuel from the tank is flowing easily to it. Once you have the carb off the engine, remove the bowl from the carb by removing the bottom bowl nut. Use a small can or an ash tray to hold the small pieces. Shake the float back and forth to see if there is anything in it. Some floats are plastic and some are tin. If there is any liquid inside the float there is your problem. Otherwise continue on with your diagnosis by using a bread bag wire, minus the outer covering, and a little jet spray to probe and clean the internal jets. Pay particular attention to the center main jet which will have a small perpendicular air bleed hole near the bottom and to the air vent hole that is on the face of the carb where the air cleaner mounts. Any tiny piece of chaff will cause these to plug. For reassembly, the inlet needle slides into the float, and they are held to the casting by a pin. You can push the pin out with a small screwdriver and then grab it with a pair of needle nose pliers to get access to the float. Finally, check the O ring for cracks that goes between the bowl and the casting. This is an easy job, just take your time. Lawnboys are one of the better machines.
Posted on Aug 31, 2009
I have recently purchased a Morrison classic lawn mower it has B & S 430 series 148cc engine. It starts fine but it seems to run at about 85% with a slight cough/ splutter. Do you have any suggestions,...
it usually isnt the spark plug but it doesnt hurt to change it and the filter and the oil it is the carb they are not hard to rebuild most of the time you dont even need a carb kit although there only about ten bucks i suggest acid dipping it for 45 min i use chem dip about 25 dollars for a gallon then blowing out all the little holes with your air compressor shell run like new again
Aug 16, 2012 | Briggs & Stratton Briggs Stratton Intek V...
B&S Model: 303447-1078-31 16hp stops running after warm-up
bad coil it will seem like a fuel issue and the spark will look fine threw the spark plug but with a real spark tester you will see it is a yellow spark instead of blue replace coil and thank me
Jul 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
No fire to spark plug
If you have no spark on either spark plug then more than likely the coil is defective. Check all wiring before proceeding. The coil looks like this. 28596c2.png
Apr 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engine wont start. remove spark plug re attached cable to spark plug, ran engine saw no spark at spark plug.
I'm sorry for asking more questions, but doe this engine have points for ignition?? Look for cracks in the wire that may allow spark to jump to ground before reaching the spark plug. Also make sure the kill switch is not activated wile attemping to start the engine. I realize this may be knowledge already known, but I have to start with the basics before proceeding.
Jan 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
24 hp briggs intek vtwin won't start
This same thing happens to me and I resolve it by taking the gas line off in front of the carb and blowing air through it.....then it will run fine. I realized I could do this when I took the air cleaner off and fed it gas manually and it ran fine....and I also had gas pumping through the fuel pump. I'm not sure of the problem....either the fuel pump is losing power or their is something blocking the carburator intermitantly
Jul 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
103 people viewed this question
Top Briggs & Stratton Garden Experts
John Trevino
wadingriver
wadingriver
JOHN LAPIER
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
