SOURCE: power to tv is good but no picture?
I have the same problem... powers on, but black screen, flickers a bit. Any ideas
SOURCE: No picture on a Westinghouse lcd tv model ltv-20v4
The simplest problem would be the failure of the backlight.
In case you don't already know it, there is one, and they may or may not last forever.
Also, there is an extra power supply to produce the high voltage the lamp needs to fire that may have failed.
Sometimes, you can look at the screen from an angle to see if there is any sign of movement.
If you can see program material causing a change in the faint image, then you can be pretty sure it is one of the two problems mentioned.
SOURCE: I need an instruction manual for a Soniq 32
Go to retrevo. Boat loads of manuals and drivers.
SOURCE: how to remove stand on vivo 32 inch lcd tv
if you send picture to [email protected] , i can try to help you
SOURCE: I need a remote code for a westinghouse LCD TV,
Hello, if the remote is a universal remote you will most likely need to input the Sony codes. Another option is to purchase an original remote at [email protected], the price for the remote is $15 plus $5 shipping and handling.
