I have a PT7031 Sound bar for altec lansing. When I change the front volume, the rear volume changes as well. I can change the front and rear volumes independently.
  • 3 more comments
  • lunateric Oct 25, 2010
    I ralize that, but my problem, as i initailly described, is not that the left and right front levels increase at the same time, it is that both left and right front and back increaseat the same time. I can not increase the front and rear speakers independently, regardless of ir i use the front volume controls or the rear volume controls. (ie if i raise the front to +4 db the rear also goes to +4db at the same time.
    sorry, i see your confusion. I contradicted myself in the original problem statement by leaving out the word "not" it should have read " When I change the front volume, the rear volume changes as well. I can NOT change the front and rear volumes independently
  • lunateric Oct 26, 2010
    I am not making my comment based on my perception of sound coming from the front and back speakers. I go to the OSD and set my speakers based on the visual levels i see when i move the volume of the front and back speakers. I first raise the front spekaer level to +4db and the OSD shows me it is +4db. When I go to adjust the back speakers I see they are at +4db. I lower the back to +1db, and again the OSD shows me the back speaker volume at +1db. I go back to the front speaker volume to verify its level and it is now also at +1db. Regarless of which set of speakers I adjust, both front and back speakers move togeher. I have a friend that has the exact same unit and he is able to adjust the front speakers and back speakers independently, so I know my unit is not operating properly. What I want to know is are there a set of keystrokes on the remote that can reset this function or reset the entire unit to factory default operation? (BTW I have gone to the OSD menu and have chosen the reset from the menu but the problem persisted).
  • lunateric Oct 30, 2010
    I have confirmed all the buttons work as described. I have ensure my remote is set to audio to contol the unit. I have gone into the osd menu and have even reset the system to factory defaults. I have set it to blue ray and ensured the audio settings on the blue ray were 5.1. I then play the blue ray and go to the OSD. Th front and rear speaker volumes are still reacting together regardless of which one I increase or decrease.
  • 2,299 Answers
Yes. When you take power away from the front speakers then the back speakers will take the power. That is why the back changes with the front.
Posted on Nov 01, 2010
  • 2,069 Answers
Unfortunately, the truth is the controls change the output level of each channel of the front and rear outputs, such as is the case in a discrete 5.1 system. But this is not so. Raising the output of the front speakers raises the output of both left and right front speakers together. you can't adjust the left or right output individually. Raising the output of the rear raises the output of both left and right sides simultaneously as well. So, the adjustments are not as great as anticipated.
Posted on Oct 25, 2010
  • 656 Answers
I think the connections to your sound system is correct the sourrond sistems works in full when you play a filim you can see the variation in your speaker if you play music the effect will be low the sourrond system is fully functional when there is different noices for example in a filim the sound of a guy near to to sceen can be hard from the front speaker and the guy far from him can be heard from the rear speakers if in a film a car chase is there you can see the differance you can hear the sound of the car from rear speaker when it passes round automatically the front speaker gets its full volume till then the front speaker low sound will be heard
Posted on Oct 26, 2010
  • 3 more comments
  • rajesh raman
    rajesh raman Oct 26, 2010
    the tyoe of song or movies you playing can be different you may think the sound of the rear is decrease becuse the music or the filim is not working in sourround systems it may be labbeled so the sourrond system have seprate aplifier for all the speakers its indipentant amlifier so there wont be any defferance in sound mixing up the problem is with dvd or the cd you are using if you insert an old cd or dvd you will know the defferance which is not recorded in sourround system just sterio
  • rajesh raman
    rajesh raman Oct 27, 2010
    check wether any button pressed to mkal sliders to move together in some system its used so the desired sliders can move together
  • rajesh raman
    check this 1. POWER Use to toggle between On and Standby modes.
    2.VOL /–
    Increases or decreases the overall volume level
    of the unit.
    3.3456
    and OK
    Move to highlight items in the on-screen display
    (OSD) setup menu. Press OK to confirm.
    4. AUDIO
    Sets the remote to control the PT7031 as
    opposed to DVD, TV, SAT/CAB or AUX devices.
    5. INPUT
    Press to cycle through inputs – DVD, TV/SAT,
    AUX, DVD digital, TV/SAT digital and AUX digital.
    6. MUTE Press to turn off or restore sound.
    7. FRONT, CENTER,
    REAR /– LEVELS
    Increases or decreases the volume level of the
    individual channels for the system.
    8. BASS Enhances low frequency or bass output.
    9. MODE
    Use to select virtual or stereo mode of system
    depending on the sound modes available from
    your audio source.
    10. OSD
    Press to enter or exit the on-screen display
    (OSD) setup menu.
  • rajesh raman
    rajesh raman Oct 31, 2010
    check the speaker line if correct i think the problem might be in the circuits don t go for remote try it manually to increase or decrease the volume first try the front speaker remove the connection then the rear speaker by changing the front and back volume control
  • rajesh raman
    try the cariation by conecting one speaker front and increase and decrease the volume and check wether the volume increase or decrease now decrease the volume to minumun then increase the back speaker volume if there is veriation in sound you have problem with the system
SOURCE:
No sound out of my Altec Lansing ADA 745. Computer Sound card is fine.
If other speakers are working, then 745 is defective or the volume switch is set to mute. Please check that, repair it if required.
Aug 27, 2012 | Altec Lansing Technologies Audio Players &...
I am running windows xp on a desktop computer with a INT D945GNTLR motherboard which I believe has a built in audio for 5.1. The speakers are Altec Lansing VS3151. They worked fine for years but now I...
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Sep 10, 2011 | Altec Lansing VS3151 Computer Speakers
My problem is when i turn up the volume of the speaker it will just turn off. tnx
Your altec lansing need to be open, because it has a loss connection on the power supply part of its circuit board. that is why when you turn up the volume it turns off because it produces vibration enough to shake the circuit board which has a loss connection.
1. Prepare the following tools:
* soldering gun/iron / soldering lead and a magnifying glass
* open your altec lansing cover enough to see the circuit board
2. Try to examine the leads on the circuit board, try to share some of the spare parts make sure it is not plug to live outlet to avoid electric shock.
3. if you see some spare parts shaking try to resolder it.
4. Then close back the cover.
5. Then test your altec lansing
Jul 11, 2011 | Altec Lansing ACS 45.1 Computer Speakers
Sound breaks. have to fiddle with volume button
hope this helps
Jun 27, 2011 | Altec Lansing VS2121 Computer Speakers
Altec Lansing PT7031 - ''Panel Key is Locked''
With the unit turned on...
Press the following front panel buttons in sequence within a 10 second span:
[Vol+] / [Vol-] / [Vol+] / [Vol-] / [Vol+] / [Vol-]
Successful unlock is indicated when the front panel led's flash.
Apr 04, 2009 | Altec Lansing PT7031 Computer Speakers
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Jan 29, 2009 | Altec Lansing VS3251 Speaker
Altec Lansing Altec AVS 500
If you are using windows media player check if your player is configured to have an echo. If it is configured remove it. If it is not configured to have an echo and if you are using any soundcard have that sound card check by an expert or by your vendor and let them check it out if it is still under warranty.
Jun 24, 2008 | Altec Lansing AVS 500 Computer Speakers
Dynex soundcard is installed however my pc still has no sound!
Hi Sammantha78,
I had a similar problem with my computer and I went and bought new sound card and installed it and I still had no sound. I then went and bought a new set of speakers and now i got sound. I suggest you test another set of speakers on your computer to see if it’s not your Altec Lansing speakers that is not working.
Sincerely,
Agent Xiong
Apr 15, 2008 | Dynex DX-SC5.1 Sound Card
Altec lansing ada 745
need to check your control center,then if thats not the one"it should be set @ 3/4 volume....
if no diff,,,,,then you need to go over checking every program that shares it,,,has their own volume control,,,somewhere there is the problem,,,maybe real player,,,media player,,,flash player etc...
thnks ttyl
[email protected]
Mar 10, 2008 | Altec Lansing Multimedia Computer Speakers
103 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
