Question about Pentax Program Plus 35mm SLR Camera
Cannot advance film, lever won't move 35mm Pentax program plus. replaced batteries
SOURCE:
poolseman
  • 206 Answers
SOURCE: film advance lever
Your camera is cocked but since the shutter is not working you cannot release it and hence your film advance mechanism does not work. ME-super will work without batteries in full manual mode so set your shutter to B and try to release it. If the shutter will not release in B mode then the shutter/mirror box will need servicing : rubber components in the mirror box mechanism have perished and need replacing. After that your camera will be fine for another couple of years.
Posted on Sep 23, 2007
  • 85 Answers
SOURCE: 35mm Film Camera Ricoh XR-2
You can replace it with the available lever.Most of the cameras lever can suit
Posted on Apr 02, 2008
  • 185 Answers
SOURCE: Ricoh XR-10 35mm SLR camera
stevdan,
take the screws off the bottom cover. there is a small lever pointing toward the front of camera with a black screw on it. gently move it to the left, this will release the lock lever. Now advance the lever and the shutter should fire. if not, it is not repairable. no parts
Posted on Dec 14, 2008
SAFFOTO
  • 78 Answers
SOURCE: Film Advance lever stuck
When you press on the shutter release does it "click"? A few hard taps with the end of your finger onto the shutter reelase button may unjam it if it is stuck...
Posted on Jun 15, 2009
  • 302 Answers
SOURCE: The film advance lever is stuck on my minolta
Here are the most likely:
A. Lever will not move on some models if the shutter is already cocked. If the shutter is cocked, and will not release with new batteries INSERTED CORRECTLY, then the most likely is this...
Two capacitors in these Minoltas die over time. If you are handy at such things, you can buy the caps, remove top and bottom covers, remove the dead caps and solder in the new ones. Don't Panic.
You can find instructions on the web for this well known issue, and you can also opt to send it to a camera repair place. Garrys camera repair in Niles, ILL does it for about $58 incl return shipping. He will also clean, lube and adjust it for ya. Something they all need eventually.
Posted on Oct 11, 2009
Asahi pentax sv film advance lever stuck
Without film in the camera it may well read before zero, my K1000, K1000Se, and K2 do that. Press the film rewind button, maybe that will release it for you.
For camera repairs look to:
Eric Hendrickson: http://www.pentaxs.com/index.html
Oct 02, 2012 | Pentax K1000 35mm SLR Camera
Pentax ME Super
Does the film advance lever lock in place when the lever is returned ? if not, the lock spring broke. This is a common weak point in the ME Super. the camera must be partially disassembled to be repaired. get a cost estimate first. there are no new parts for this model Pentax.
Jan 04, 2010 | Pentax ME Super 35mm SLR Camera
I have an old Asahi Pentax, release lever and shutter are stuck.
The Pentax is a easy fix, maybe.. If you feel comfortable removing the bottom cover, then remove the 3 cross point screws. The battery, if installed will be loose. Looking at the bottom section of the camera, locate the tripod socket. On on side is the battery compartment, the other an L shaped lever. Under the L shaped lever is a brass plate with a slot in it. In that slot is another lever that has a spring going through the end eyelet. Move that lever toward the front of the camera until it latches on the L shaped lever above. Then try the release.
The first thing to try on the X700 is fresh batteries. Clean the battery cap and contacts with a pencil eraser.
Jan 04, 2010 | Pentax K1000 35mm SLR Camera
Pentax me super camera, not working wind on lever
The clip spring broke jambing the advance gear. by forcing, the tab on the advance shaft broke.
take or send your camera to a camera repair shop for an estimate cost to repair.
there are no new parts for this model so the repairs could be expensive.
there should be no cost for an estimate.
Dec 10, 2009 | Pentax ME Super 35mm SLR Camera
The film advance lever on my ricoh kr-5 broke
plenty of these cameras are on ebay sold for parts
Jan 05, 2009 | Pentax ME Super 35mm SLR Camera
Film advance lever stuck
The shutter parts are most likely broken. That is usually the tell-tale sign of a broken camera, not advancing. Repairs for film cameras are very expensive and if parts are needed, it may be impossible for a 20+ year old camera. My suggestion is to find a replacement film camera system. Your Ricoh lenses will fit on a Pentax camera, but not work in Auto Mode. Prices of used Pentax cameras with built in motor drives are around $100. Check on line cameras stores. They have lots of use cameras/lense. A lens to use on that is another $75 or so. Only Nikon and Canon make new film cameras anymore. If you want an indestructable K-mount, find a Pentax K1000. Many lenses are available but no motor drive nor auto exposure on that model.
Apr 09, 2008 | Ricoh KR-30SP 35mm SLR Camera
Film will not advance
Pressing the rewind button wind the film advance lever,if it is free It will set to its place. Release the rewind button, press the shutter release button.Once again try wind the film.( provided your camera is not fitted with motor wind )
Then your winding gears need cleaning
Jan 18, 2008 | Pentax ME Super 35mm SLR Camera
Film advance lever
Sep 18, 2007 | Pentax ME Super 35mm SLR Camera
Film advance lever
Yes this is fairly common with K 1000 and the Spotmatics : although the shutter is cocked and hence you cannot advance film you cannot release shutter because mirror box is not cocked. Remedy : remove bottom cover and locate mirror box lever which protrudes slightely and is movable up and down and is spring loaded. Move upwards until it licks in position ( moving up against spring tension ). Now release the shutter and camera should let you advance the film .
Sep 17, 2007 | Pentax K1000 35mm SLR Camera
Pentax Program Plus 35mm SLR Camera Logo
406 people viewed this question
Top Pentax Photography Experts
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
