Question about eMachines W4620 Notebook
Wireless connection 10 not connected how do i connect
  • eMachines Master
  • 7,733 Answers
Go to network connections and check if the wireless connection is enable.To enable right click and select enable.
Posted on Oct 25, 2010
SOURCE:
How many devices can connect via wireless to D-Link DI-624?
It can connect as much as 10 computers or wireless networking devices. As long as your base connection is good you can connect as many devices as you can. Because the wireless technology is unlimited and limitless.
Jun 19, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
Router works OK with ethernet connection, not OK with wireless
There are several problems that can cause the wireless connection to drop.
Please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
Apr 01, 2010 | NetGear WGR614 54Mbps Wireless Router...
Dell Mini 10 problem connecting wirelessly
please update the wireless drivers fromo the support website that is www.support.dell.com and also update the latest version of bios, check for the setting with router , if still dosent connect,
Feb 12, 2010 | Acer Aspire One PC Notebook
TOSHIBA EQUIUM WIRELESS PROBLEM
You might deleted your driver to wireless connection or you perhaps upgraded Service Pack to higher version. If your wireless connection will work on lower SP then that device won't work or vice versa.
Another thing, try to check connections. Click menu and look for connections and try to enable wireless connections.
Thanks
Jan 11, 2009 | Computers & Internet
Unable to go online
I want to tell you that before making wireless connection you have to ensure that are you able to go online with the netgear router using wired connection if yes i will provide steps to configure wireless on the router.
WIRELESS SETTINGS, you can follow directly to solve teh wireless part of the router :
Once its done follow the same steps to make you wired connection working. Once its done, Lets move on to the wireless connection
a. click on the wireless settings under the heading of setup
check out another screen shot below :
a. Change Name SSID : name of your network that you want to have
b. CHANNEL : Change to 11 and if uts 11 change it to 06
c. Mode : change to G&b
d. Sceurity : Select WEP
e. Key1 ; type any 10 digit number or you can type 1020304050, as mention above as the password for your wireless network
Till now we have set up the wired connection and wireless connection on router and now lets connect your wireless computer with it
you will able to see your wireless network name on your computer, simply select it and it will prompt you for password that will be your 10 digit number you punch in Key1
connect with it and you are ready to go with your wired and wireless connection
I believe these steps help you to resolve your problem
Thanks & Regards.
Jaspreet Singh Saini
Jan 10, 2009 | NetGear WGR614 Wireless Router
Will a computer with 10/10 LAN connect to my wireless LAN?
The 10/100 LAN is a wired connection. If it is connected to the wrt54g through an ethernet cable yes it will see anything on the wireless connection but if you want the computer to use a wireless connection then you will need to get an 802.11B or 802.11G wireless adapter. The wireless adapter does not have to be Linksys but it does generally make thing easier if you use all the same brand.
Nov 29, 2008 | HP AdvanceStack 10:10 LAN Bridge MB...
Wireless in dell lap top
It has something to do with the use of your wireless connection especially if it is an open access service. It is possible that there are many users in your area and you have to share the bandwidth of the wireless connection that reduce the efficiency of your laptop. Try finding another source where only few people connect.
Oct 10, 2008 | Intel PRO/Wireless 2200BG 802.11g/b
Wireless connections showing up as ethernet connections
just change de wed key
go 192.168.1.1
user admin
password password
Jun 18, 2008 | Actiontec GT704WG Wireless Router...
2Wire router
if your wireless connection is not working even if the wireless light is lit up on ur 2wire modem/router....try to delete the 2wire network from the prefered list...go to network connection, right click on wireless netwrok connection, go to properties and click on wireless network..select the 2wire netwrok on the prefered list and remove..reconnect to the network by clicking on view available wireless netwrok and select the 2wire network again...if its asking for a WEP key or password take a look at the bottom on the modem a 10 digits number enclosed in brachets..thats the network or wep key. access 192.168.1.254 and click on home network, got to wireless settings---edit settings...change ur wireless channel to 10 adn power settings to 10, save ur changes=)...ohh and by the way make sure that the wifi switch of ur laptop is turned on=)
Jun 01, 2007 | 2wire 2700HG-B Router (2700HGB)
eMachines W4620 Notebook Logo
61 people viewed this question
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Thomas F. Schneider
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
