Question about Dell E207WFP LCD Monitor
Monitor problem just bought a dell (refurbised) monitor off Dell.com. Had it for about maybe a week, and i've been having some problems. Im running the monitor at optimum resolution and i know for sure my video card can run the monitor. Even all my drivers are updated. Im running Windows Vista. For example, my desktop background is "bliss." Part of the green grass is showing a brown color. The blue sky...parts of the blue show up neon blue, and there is always some sort of static-y movement. Pretty much it shows small tiny specks of really bright colors, and most of the colors showing are neon bright, always "flickering." It's kinda hard to explain....
  • 3,940 Answers
You didn't specify the card you are running but here is how I would approach the issue.
#1 refurburished Monitors have at a minimum a 90 day warranty, so be prepared to call Dell Tech Support and troubleshoot if my information doesn't help, if the monitor is defective, then they will have to exchange it.
#2 The optimal Resolution is 1680 x 1050 60 hz, you need to ensure that setting (You didn't specify, so I mentioned it)
#3 Sometimes color issues are caused by cabling issues. Try both DVI and VGA connections, see if there is any difference between them (digital or analog, the picture should look the same) If one looks ok, the other doesn't. then it may be a bad cable.
#4 Does the issue occur on more than one system. If it does, then the monitor is bad. If you have individual pixels stuck on (Red, Green or Blue) and you have more than 6, that in itself is justification for replacement.
#5 If all the above doesn't work, contact Dell Tech support for an EXG
Posted on Jun 08, 2008
No Bios No Windows help how to install.
http://search.dell.com/searchcom_redirect.aspx?c=us&l=en&s=dhs&cs=19&k=Search+Dell+PowerEdge+1800+Server&tdc=311&p=1&rpp=12&cd=3&cat=sup&sfp=web&dtype=downloads&did=R92113&redp=http%253a%252f%252fsupport.us.dell.com%252fsupport%252fdownloads%252fformat.aspx%253freleaseid%253dR92113%2526c%253dus%2526l%253den%2526cs%253d19%2526s%253ddhs&redpe=4346f473-5614-bad0-c5ea-1957eaad8304
May 25, 2012 | Dell PowerEdge 1800 Server
Help, can't seem to get the USB ports on my monitor to work again. I have the following dell monitor 1704fpt 17in. running windows XP Pro sp. 2
Since the USB ports on this monitor are just the powered USB Hub, you should try it with another PC if you know for sure that the USB port of the PC taht is feeding this Powered USB Hub on the monitor are OK, also check the cable.
The USB board replacement for thsi will not be woth it. Also check for 5vdc on PIN1 of the USB port.
http://s807.photobucket.com/albums/yy352/budm/DELL/Dell%201704FPT/
May 05, 2011 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Hello.I;ve bought a dell 1558 about for about one week.and I have two problems.my mouse icon gets bigger.and for two times my system hanged and I have to turn that off. please help me soon.
Since it is "brand-new", take it back, and show the problems to the manager of the computer-store, and exercise the warranty to get it repaired/replaced.
Oct 20, 2010 | Dell Studio 15 Laptop
Dell inspiron laptop screen colours inverted (negative)
if the same issue occurs in the BIOS your soluton is to have your LCD screnn replace or have your LCD inverte cable checked/replaced ^_^ this has nothing to do with the BIOS vodeo card drivers do not function in the BIOS to be able to do such in the BIOS screen
Jun 04, 2010 | Dell Inspiron E1705 (DNDWGA3) PC Notebook
I bought a computer didnt come with a monitor. my dell monitor wont plug & play any suggestions?
try to plug the monitor in other computer. maybe the monitor has a problem
Aug 21, 2009 | Dell 1800FP Monitor
Dell 17" lcd manufactured 2004 wont turn on.
Well first off if its that old the warranty is up im sure. Second they won't deal with you since you are not the one who bought it. I'm sorry I had a similar problem to that altho I had bought the screen and it did the same thing a week after the warranty was up.
Jan 04, 2009 | Dell E176FP 17" LCD Monitor
NEED DIAGRAM
Monitors are disposable items and not normally repaired. Technology moves on and High Definition Flat screen monitors are the way to go. The only place you would get a schematic for it is from Dell themselves. Unlikely you will find spares for it. If it has no power, then it is a power supply unit problem. I suggest you get a new electrical mechanic :>)
http://www.dell.com/support/home/ca/en/cabsdt1/Drivers/DriversDetails?driverid=4291F
Apr 04, 2017 | Dell M782 Monitor
Dell E207WFP LCD Monitor Logo
173 people viewed this question
Alun Cox
