Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Brush won't turn - Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
    New Friend:
  • 102 Answers
Belt is broken. You will need to re[lace the clutch. Here is a video on how to do that.
http://www.videojug.com/film/how-to-replace-the-clutch-on-a-dyson-dc04-dc07-and-dc14
Posted on Oct 25, 2010
SOURCE:
Bissell powerforce brush won't turn when powered
Hey, you may want to have check if the brush turns by hand without the belt in place. If the brush doesn't turn manually, you'll need to replace the brush.
Here's a quick link to the BISSELL website to assist you.
http://www.bissell.com/default.aspx?cid=ccsocial
Feb 12, 2013 | Vacuums
Brush won't turn on my Panasonic MC-CB467
There should be a safety reset button. So like if you suck up a rug it will shut the power to the brush roll off, then reset it.
Nov 14, 2012 | Panasonic MC-CG467 Bagged Canister Vacuum
Dyson dc25 off button won't turn off, brush button won't engage brushes
Hi ... did u get this fixed cos mine is the same hve to switch off on the wall?
Sep 22, 2012 | Dyson DC25 All Floors Bagless Upright...
Why won't my brushes turn
most likely stripped gears on the end of the brushes. (beltless model?)
Nov 21, 2011 | Hoover WindTunnel V2 U8148-900 Upright...
Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
Oct 21, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Brush won't turn
There is a good chance the belt is broken. The reason belts break is because the brush seizes up due to hair wrapping around tight at the ends of brush. Inspect closely with a flash light to check for this.
Aug 18, 2011 | Sebo X4 Bagged Upright Vacuum
Brushes aren't turning. switch is on
Remember that the brushes turn best when the handle is tipped back. If this does not work, remove the brush assembly and insert a flat screwdriver into the square hole that the pin on the brush usually fits into. Try to turn the fitting. If it won't turn, the air driven turbine has seized up and will require replacement.
Jul 26, 2011 | Hoover SteamVac F5914-900 SpinScrub...
The brushes won't spin. I put new brushes on and it still doesn't spin.
Usually when the brushes won't turn it is due to a bad turbine. Insert a screwdriver into the square hole that the pin on the brush fits into, and see if it turns. If it is seized up, the turbine assembly will need to be replaced.
Jun 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
My hoover carpet scrubber the brushes won
(1) Remove the brush block and assure the presence of the square drive pin on top of one brush. It should be about 1/4 inch square, two inches long to connect o the drive mechanism.
(2) Remove and clean the filter screen from the base, behind the brushes. Squeeze the two red tabs together, and pull down from the base. Clean the hiar/debris from the screen.
(3) Assure the Brush Speed knob on the hood is NOT set to the OFF position.
Aug 30, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Rotating brushes will not turn
If belts are ok then possibly needs new front brush motor replaced.
Nov 05, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
83 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
