Question about Toto Promenade, 1.6 GPF, Elongated Two-Piece Toilet, Cotton - CST424SFG
My toto power gravity siphon won't stop running. Suggestions as to how to fix would be greatly appreciated. Cheer, Mark
    New Friend:
  • 70 Answers
You have a problem with your flapper not seating all the way so the water is not filling in the tank to lift the ball **** to shut off the water first make sure the flapper is ok
Posted on Oct 26, 2010
SOURCE:
The water does not squirt out of the bidet wand
My Toto Washlet has stopped squirting water. Any ideas for fixes?
Dec 02, 2010 | Toto Washlet S400 for Power Gravity...
My Toto Carlyle toilet with Gmax valve CONSTANTLY runs...It runs for about 3 mins, stops, then runs for 3 mins, stops, and on and on this goes!!!! I need step by step instructions on how to fix the...
Sounds like your losing water out of the tank. check to see if flapper in tank has good seal (The rubber device that fits over the whole at bottom of tank, its attached to the handle by a chain or plastic rod). Make a mark when the water shuts off to reflect the water level watch the level of water over the time you specified. If the waterline drops the you definitely have a faulty flapper. Replace with new flapper which can be purchased at most hardware stores and DIY stores like Lowe's, Menard's, Home Depote. I hope this has answered your question, please rate the answer given. Good Luck and have a great day. Jeff
Apr 04, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
Gmax flushing system won't stop
WATER LEVEL IS NOT PROPERLY ADJUSTED. REDUCE WATER LEVEL TO FILL LINE
Jan 07, 2010 | Toto Drake Tank W/GMAX RH COTTON WHITE...
After flushing water will not stop running it has a power gravity value in it
Bad flapper seal needs to be replaced or too much tension in the chain.
Nov 22, 2009 | Toto Toilets ST784S 12 Sedona Beige...
New Toto toilet continues to trick water
check the water level in your tank if it is filling ,ajust the float in your tank so it stops before going over the overflow. if not your flapper is the culpret
Sep 14, 2009 | Toto Washlet S400 for Power Gravity...
Toto toilet Power Gravity intermittently running
You need to either bend the arm that connects tot he float down (if it is the type with the ball float) or adjust the height of the fill valve assembly. THis accomplished by slightly twisting the valve assembly carefully and sliding down a half of an inch or so and then twisting back to lock it in place.
This should fix you up right.
Apr 29, 2009 | Toto Round Carusoe Two Piece Toilet, 1.6...
I suggest that you replace the cap with the new seal, it sounds as tho the valve is not shutting off and the bowl fill tube continues to run. Have you adjusted the water level to 3/4 of an inch below the overflow tube. If not, try that.
Mar 16, 2009 | Toto Promenade, 1.6 GPF, Elongated...
Did you replace the flapper with a genuine Toto replacement flapper? If you didn't, they are slightly different. Toto toilets are fantastic but you do need to use OEM parts for repair.
Mar 13, 2009 | Toto Washlet S400 for Power Gravity...
Toto Promenade, 1.6 GPF, Elongated Two-Piece Toilet, Cotton - CST424SFG Logo
889 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
