Question about Toshiba Televison & Video
Focus problems - Toshiba Televison & Video
  • Toshiba Master
  • 8,617 Answers
Need the model number of your set in order to help you. also is it a focus problem where its blurry or is the image outof alignment such as convergence?
Posted on Jun 08, 2008
While driving my 2012 Ford Focus it acted like it was in neutral when it was actually in drive I pulled over put it in park and the motor quit and now won't even turn over
2012 Ford Focus Recalls - Cars.com
www.cars.com/recalls/ford/focus/2012/
Cars.comLook up all NHTSA vehicle safety recalls for your 2012 Ford Focus, and contact a nearby service center for free repairs.
2012 Ford Focus Problems, Defects & Complaints
www.carcomplaints.com/Ford/Focus/2012/
The 2012 Ford Focus has 1605 problems & defects reported by Focus owners. ...October 28: Ford Recalls 131,000 Vehicles, Mostly SUVs For Fire Risk ...Transmission - ‎Focus Recalls 3 - ‎TSBs - ‎AC / heater
Nov 08, 2015 | Ford Cars & Trucks
Sx40 hs not focusing for all shots
Hi Brian. First you have to narrow the problem down. Is it your camera or the lens that's producing the problems. Can you try a friends' lens on your camera to see if it still malfunctions? if it does then it's your camera body. Alternatively you could try your lens on a friends' camera to see if he gets the same problem.
Are you using all the focussing points? If you are then this might be the problem because the focus points are spread across the viewfinder and if one of the points sees an object that is nearest to the camera, it will focus on that.
Try usng only the centre focus point and use the focus lock to try and get good focus. Hope this helps.
Nov 02, 2013 | Canon PowerShot SX40 HS Digital Camera 2GB...
Where is power steering resevoir on focus 2006 1.6 diesel
There was an issue with the steering in that 04-11 focus... let me see if I can find the problems they've had for you.
Ford Focus fuel pipe leak (2004-2011 cars)
Cars built between July 2004 and February 2005 could have had problems with their fuel return pipes leaking. The pipes were made from material that degraded over time, allowing fuel to seep out.
Ford Focus wiper motor problem (2004-2011 cars)
On early second-generation cars built between April 2003 and March 2005, there were issues reported with the wiper motor. Water could enter the motor through the arm spindle, and if it contained salt, could short-circuit it and cause the motor to overheat. This could lead to trim melting around the motor.
Ford Focus engine failure problem (2004-2011 1.6 TDCi cars)
1.6 TDCi Focus models built between February and June 2004 might have problems with their engines, causing them to cut out. Misaligned oil feeds between the cylinder heads and camshaft bearings reduced oil flow, causing premature wearing of the camshaft bearings and engine seizure.
Ford Focus brake pedal problems (2004-2011 cars)
Cars built between November 2005 and December 2006 could have developed problems with their brake pedals. In particularly cold weather, the pedal could become stiff, as the non-return valve in the pump began to stick.
Ford Focus roll-over protection problems (2004-2011 CC cars)
On some Ford Focus CC models it was found that there were issues with the roll-over protection system. Securing bolts holding the system in place were either loose or not fully tight. Therefore the protection would not be fully effective. Ford should have fixed this for free, so make sure the work has been carried out.
Ford Focus cooling fan problems (2004-2011 1.6 TDCi estate car)
On some Focus 1.6 TDCi estates built between July 2004 and December 2006 there were problems with the cooling fans. Where roads are particularly salty, corrosion could easily occur, reaching as far as the control module. In extreme cases this could cause it to overheat, which could lead to fire.
Ford Focus rear hub bolt problems (2004-2011 cars)
On some Ford Focus models built between February and April 2007 there were problems with the rear hub bolts. They could come loose because they weren't made to the correct design specification.
Ford Focus power steering problems (2004-2011 cars)
Ford Focus models built between April and May 2008 could have had problems with their power steering. Some of the hoses fitted were not to the required specification. The hoses could degrade and allow hydraulic fluid to seep out, which could either cause the power steering to fail or, in more extreme cases, cause fire when the fluid became hot.
Ford Focus risk of fire problem (2004-2011 cars)
Hatchback and estate 1.6 TDCi Ford Focus models, manual and automatic, built between January 2006 and January 2007 may have a risk of fire unless they've had their cooling fans checked. Salty roads could lead to corrosion, overheating and fire if not sorted.
Ford Focus water leaks (2004-2011 cars)
On second-generation cars, some owners have reported water leaking into the cabin. Check any sunroof or window seals before you buy. Also look for damp carpet inside, because it could have become mouldy if left untreated.
Every one of these issues should have been remedied by Ford for free, so make sure the work has been carried out.
Mar 26, 2013 | 2006 Ford Focus
Problem with focus when taking video
read your owner manual troubleshooting section for to see what
is the exactly problem. They contain many tips for help
God bless you
Sep 24, 2012 | Canon PowerShot SX210 IS Digital Camera
My Panasonic PV-GS150 is having an autofocus problem. It will be focused on a target and then will go out of focus and then come back in to focus. It does this repeatably. It used to stay focused on the...
The solution is never buy a Panasonic DV camera. Tons of users complain of focus failure and Panasonic pretends the problem does not exist. Great cameras otherwise but out of focus does not cut it.
PV GS250 $1000 brick
Dec 08, 2009 | Panasonic Video Cameras
The auto focus and the manual focus are not
I have a similar problem. The focusing joystick has just stopped working. Been trawling the net for weeks trying to find a solution (out of warranty, typically). Have you had any luck solving your problem?
John
Oct 19, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
My konica minolta Dimage z2 doesn't focus
Your problem may be that the camera is "locked" on manual focus. If so, you will need to go to the menu, scroll to "2" menu in "P" mode, and click on "focusing mode". From there, hit "single focus or continuous focus." It should correct the problem. Also, is the lens dirty? A dirty lens will not benefit the camera. The light may be too low, also. Try using a flashlight to focus, then take the picture.
Jun 12, 2009 | Konica Minolta DiMAGE Z2 Digital Camera
Finder focus problem
is there a little slider type bar/switch/button on the finder, most cameras have them to compensate for different peoples eyesight. if there is, look through it, put camera in auto focus and when its focused, look through finder and move bar/switch... til pic is clear
Sep 21, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
More info for poor focus problem
I don't know about any misaligned focus feature on the D80. Have you checked to see what focusing mode you are using, ie. single auto focus, closest subject, or wide area focus. Closest subject can really throw off your focus. I would switch to single auto focus mode. Another reason for poor focus would be dust on the auto focus sensor which is located under the mirror box.
Check on the focus mode, if it's not a mechanical problem, I'd be willing to bet that's what it is.
Jul 22, 2008 | Nikon D80 Body Only Digital Camera
Bosch LTC 0938/25C Autodome focus problem - need advice?
Hi krajesh52,
Have you tried with in finding any fault in the electronics PCB.
Ananth
Aug 10, 2007 | Bosch Ltc 1461-21 Weatherproof Flexidome...
Televison & Video Logo
32 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
