Question about Toys
How do you put the aaa battery in the happy hamster
  • Pam Warner Feb 26, 2013
    OOPS! I messed up when writing this solution. Completely edit out the first 4 lines of the solution. You do not remove any screws from the bottom of the happy hampster. Just pull out the white battery compartment and remove the screw the you find on on the side of the hampster that has the velcro. Sorry for the mistake!
Turn the hampster over so that the battery cover is facing up. Then unscrew the battery cover. It is the screw in the top left corner of the hampster. This is the only screw that you remove from the hampster. Do not remove the screw that is next to the on/off switch! Once you have removed the right screw, pull the battery cover off. Then you need to remove the whole battery compartment from the hampster. Do not be afraid of damaging the toy, because the plastic undercarriage of the toy is held in by velcro. Turn the battery compartment over. The actual compartment where you put the AAA battery is on the opposite side of the hampster undercarriage. You will need to then unscrew the battery flap and insert 1 AAA battery. I hope this helps!
Posted on Jan 25, 2013
SOURCE:
My remote wont take a standard aaa BATTERY what type do I buy?
maybe it is a AA battery that you are trying to put in or are installing the AAA wrong
AAA and all batteries come in standard sizes and there are no special sizes for your remote
Jul 04, 2017 | Televison & Video
Replace batteries
Marcia Boal... hello,
If our battery has corroded it may be impossible to get the end (opposite the light) cap to come off. The light is designed to be moisture resistant... Likewise even penetrating oil cannot get in...
To guarantee long reliable service it is best to put a tiny dot of grease on the threads on assembly.
Maglite Solitaire makes a wonderful little flashlight...
(all metal construction... single AAA battery)...
((Mini = 2 AAA batteries... opens the same)).
Basic colors included black, red, silver & blue
but this particular light was also quite popular for commercialization... often displaying many BIG NAME
COMPANY LOGOs.
The initial closure of the end cap can be quite loose to be effective because of it's O-ring design... however some folks put the end cap on too tight...
The
It might take some serious force to get it open again.
Consider using a piece of leather in a pair of pliers to avoid marring the case. Reassemble without over-tightening.
Hope this helps!
Maglite Solitaire Incandescent 1 Cell AAA Flashlight Black Basic Handheld...
Amazon com Maglite Solitaire Incandescent 1 Cell AAA Flashlight Blue Home...
Maglite Solitaire LED 1 Cell AAA Flashlight Red Basic Handheld Flashlights...
Maglite Solitaire LED 1 Cell AAA Flashlight Silver Basic Handheld...
Aug 19, 2016 | Camping, Backpacking & Hiking
How do I change the batteries in the Zhu zhu pets?
Changing the Batteries
A. Turn the pet over and unscrew the
motor box
B. Remove the motor box.
C. Replace the two AAA batteries matching the
polarity shown inside the battery compartment.
Be sure the batteries are firmly seated.
D. Replace the motor box and screw snug.
Jan 05, 2015 | Cars & Trucks
How do you take off and put hamster chews on kabobs
Hi Adriana,
I offer this link so you can explore a bunch of possibilities Google . Here is an Amazon link as well Amazon com super pet kabob Pet Supplies . I would cut the end. Splice through what you can, leave one less & tie knot with Para-cord. Hope this helps. Fare. Well.
May 21, 2014 | Super Pet KaBob Wood Chew Toy
My hamster keep escaping
don't worry, my daughter's hamster used to escape all the time. Take a look at this website. It has some really great info that you can read to understand hamsters a bit better and to learn some tips to stop yours from escaping.
http://www.hamster-club.com/behaviour.asp
Sep 06, 2012 | Pets - Others
Are the plastic balls for hamsters cruel?
It is totally notcruel to put a hamster in a ball and let it roam around, it is great exercisefor the hamster and its better than it being locked in a change.
May 13, 2012 | Pets - Others
I brought a remote and put in 2 AAA batterys and it was small
what was small, the remote you brought or the 2 AAA Batteries? if the 2 AAA batteries are small try the medium size batteries. GOOD LUCK!!!!
Oct 05, 2011 | Televison & Video
The base unit for my Philips VOIP3212S is not charging the phone I need to buy a replacement base unit. I put ordinary batteries in the phone and the base unit no longer works
Wilson - The phone was not made to use regular (AAA) batteries. Unless you install AAA NIMH rechargeables it will not work. Regular AAA batteries cannot be charged by the base unit.
In case you meant AAA NIMH batteries as "ordinary batteries" then your charger may be the problem, but I wouldn't assume that until I've taken a pencil eraser and vigorously cleaned the base contacts and tried the base again (with the right batteries.)
Good Luck, Mikeywaf
Mar 07, 2011 | Philips VOIP3212S/05 IP Wireless Phone
Toshiba remote uses lots of aaa batteries
Dear please buy and put new AAA Battery.
Jul 03, 2009 | Sony RM-TP501 Remote Control
Open Questions:
Toys Logo
1,877 people viewed this question
Top Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
